ABC delete 335d USA drivers - how has reliability been after delete? Costs?
05-03-2016, 09:47 AM | #1 |
95
Rep 308
Drives: 2011 335d M-Sport, Nav/Blinds
Calling all 335d owners who have done an emissions delete - I need your input please !!
My daughter's 2011 335d is constantly in the shop for various emissions issues, and even a non-emissions repair now and again. We are both getting sick of having to take it in and drive loaners all the time, and we are on the verge of wanting to trade this thing - problem is, we are upside down on the loan, so... I know the "ABC delete/emissions delete" has been done by a lot of you. The common wisdom on these 335d in the USA is that once the emissions system is gutted or bypassed, that the reliability of these cars improves and supposedly they hit the shop less often. My questions to people who have done it is: Do you find this to be REALLY true? What have been your repair/maintenance costs on engine and drivetrain AFTER the delete compared to before? Significant? Minor? Non-existent? Do you really see less shop time now? Please fill me in. I have two of these, and if I see a good financial savings to performing the delete on BOTH of them, I will try to figure out how to afford it. Thanks much !! |
05-03-2016, 01:33 PM | #3 |
Rep 234
Prior to the delete and tune, the work I had done to the car included 6 injectors, a new ECU, and a new DEF. After the tune and delete, I've only had regular maintenance and the dreaded vibration damper.
Edit: The smoke is not too bad but forget about driving with the windows down. |
05-03-2016, 02:00 PM | #4 | |
95
Rep 308
05-03-2016, 02:25 PM | #5 |
66
Rep 365
Along with the emissions delete, the crank case ventilation should be addressed along with an EGR block. This will significantly reduce your carbon build up in the intake manifold and the head. This carbon build up or CBU is not inherent to diesels, but a direct injection engine issue.
The amount of smoke post emissions delete varies based on the tune. Some tunes out there JRTuning and BPC for example, have various stages that involve an emissions equipment or "alphabet soup" delete and so will the smoke/ soot amount. The diesel exhaust fumes may be reduced somewhat with the introduction of a high flow cat in the down pipe once you go emissions free so that you can roll with the windows down. Prior to all this I had an SCR metering valve replaced. Post all this, in my case, no issues at all. Efficiency increased, fun factor increased, reliability increased and potential emissions issues avoided. |
05-03-2016, 07:09 PM | #7 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
Damn! You're having the same dilemma that I am. Car has been in the shop 7 times in 4 months for emissions related items. I drive loaners more than my own car. I too am upside down, and trying to decide if I should buy an extended warranty, or delete.
I've had cars with down pipes etc before. 4 things I don't like about modded cars, the exhaust smell (I'll get a cat), the noise (dp are louder maybe add a resonator), it won't pass emissions, and the cost/lack of people who can service it. With that said once you get it to work it will make the emissions more reliable. Especially if you have a shop that knows the recipe. Let me know what you decide. I'm deciding the same thing. |
05-03-2016, 08:47 PM | #8 | |
Rep 67
05-03-2016, 08:54 PM | #9 |
Rep 1,191
Apart from the glow plug module and the FRM going dead on me, I had 0 issues with the car. I'd recommend the EGR delete and in my opinion the crankcase ventilation does not need to be tampered with.
You should expect the vacuum lines and vibration damper pulley to go bad sooner or later, so that's something to take care off before they happen. Other than that I think this is a very reliable car. $0.02 |
05-03-2016, 09:12 PM | #10 |
Warrant Officer
375
Rep 1,341
It was cheaper for me to get the deletes than to replace the DEF tank for a faulty level sensor. NY requirements for the inspections are no CEL and readiness OK so this was a no brainer for me lol.
Deleted, ATM I/C and tuned by B.R.R.
05-03-2016, 10:01 PM | #11 |
Rep 218
I was surprised just how bad the smell and smoke is post delete. I never leave the car running anymore when it sits. People I know who know nothing about cars always comment about the smell. Kinda insecure about it at this point. Punching the gas peddle is fun though!
05-04-2016, 12:26 AM | #12 | |
144
Rep 316
I did the ABC's as preventative maintenance and haven't had any issues other than rear brake pads and front tires getting sidewall bubbles. I'll be doing the harmonic dampener in the near future as PM also. |
05-04-2016, 12:47 AM | #13 |
Rep 432
Can't drive with the windows down? Its really not bad at all, the only time I notice is when I'm sitting at a light with the window down and the wind is coming from directly behind me. Even then its faint.
Maybe you should buy a gasser and pay for spark plugs / coil packs if you're worried about this... |
05-04-2016, 02:20 PM | #14 |
25
Rep 363
I wouldn't be surprised if the EPA really starts cracking down on emission control deletes. I was around one the other day and the smoke wasn't bad but at idle it still had that diesel stench. Cat or not, if you delete the DEF, it will smell. Gross.
05-04-2016, 02:57 PM | #15 | |
95
Rep 308
There are literally hundreds of thousands of pickup trucks which have been chipped/tuned/deleted. And most of them are gun owners. |
05-04-2016, 06:18 PM | #16 |
Rep 3,556
Whitbread, maybe I'm the only one to notice. You have the slip ring (not sure what proper term is) on back of DP and front of Y pipe too. Pretty slick. I used the same 2 into 1 collector. A lot cleaner than some of the others used. So, you just use 2 V band clamps instead of 1. I'm guessing that is an "in house" DP you made for yourself as I've seen your primo welding. Would you mind sharing the P/N and maker of that Cat please?
05-04-2016, 07:08 PM | #17 | |
Rep 1,146
Drives: F10 550i
Mandatory emissions testing is already hitting trucking companies, I suspect it will hit consumer vehicles as well. The reason it hasn't happened to diesels yet is there are few of them on the road compared to gasoline. Even most trucks are gas, cept the bro dozers. I still think it was stupid Texans ever agreed to allow legislators to mandate vehicle inspections I mean taxes... A lot of states didn't. Last edited by Thecastle; 05-04-2016 at 07:14 PM.. |
05-04-2016, 08:00 PM | #18 | |
95
Rep 308
My point is as a Texan, IMHO they will not start limiting diesel emissions on passenger cars any time soon. |
05-04-2016, 09:28 PM | #20 | ||
144
Rep 316
Yes, that was an in house dp for a gentlemen's race car that arrived and departed on a trailer. It's a magaflow, PN 59959. My personal dp is missing the feline. Last edited by Whitbread; 05-04-2016 at 09:35 PM.. |
05-05-2016, 07:45 AM | #21 |
Rep 3,489
Drives: Montego Blue 335d
ok ok Im at over 20k with the abc delete and no problems as of yet, car runs smoother and better mpg, downside the smell but who cares I always have the a/c on anyway
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
05-05-2016, 07:45 AM | #22 |
25
Rep 363
