In regards of my coolant problem! White creamy coolant
05-09-2016, 06:54 AM | #2 |
559
Rep 1,502
Drives: F36 435xd
Could be. Normally when it turns creamy its because of a blend of oil and water
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
05-09-2016, 07:35 AM | #3 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
So I thought I had the same issue. Did you check in the resivour by looking or with a flash light. The tank,plays havoc I find with the coolant appearance, look in with a flash light shining on the coolent to,see if it looks frothy. Then take a sample out.
05-09-2016, 08:00 AM | #4 |
389
Rep 1,623
Post pictures. Have you overheated the engine? Quite a few of us are running a lot of boost/ power and haven't experienced head gasket failure. If your head gasket is bad, it had to be heat related.
05-09-2016, 11:19 AM | #5 | |
Rep 1,362
05-09-2016, 11:35 AM | #6 |
Rep 1,362
I also found out that when I shut the car off
The temps continues to rise. For example when I park, my tempos at 89, I gouttierealco@gmail.com inside for like 10 mins and when I start the car back, temp is at 95 |
05-09-2016, 12:07 PM | #8 |
Rep 3,556
No disrespect meant here. I thought this too once. The float thing is reservoir is white and it threw me off. I agree with other poster. Go get a cheap turkey baster from Walmart and extract some coolant from reservoir and put in clear cup. To be fair, my car wasn't running at 100C though.
Here is an idea if you really want to maje sure. You can put ultraviolet dye into oil. Home Depot has UV bulbs for $4. You could see if dye is getting over to water side. Does oil look like root beer float? |
05-09-2016, 02:16 PM | #12 |
Rep 2,615
05-09-2016, 06:15 PM | #14 |
389
Rep 1,623
05-10-2016, 01:13 AM | #16 | |
Rep 2,615
05-10-2016, 02:06 PM | #17 | |
Rep 3,556
We still don't know why he is running at 100°C. I vote thermostat (T/S) has broke and isn't allowing enough flow from radiator. On a different thread, a member showed a pic where his T/S mechanically broke and he was running hot too. |
05-10-2016, 05:21 PM | #18 |
Rep 1,362
Okay!
Heads up! Second biggest dealer in Montreal and same verdict! 100C is within standards and even beyond that Coolant is fine, temperature are ok No problems, no check engine nothing! WTF ??? They are even charging me 90$ because no fault or problems were found !!!! I'm on platinum extended warranty Stock at 146 000km |
