Radio wiring harness
05-13-2016, 08:26 PM | #1 |
Rep 276
So want to up grade my sound with plug and play speakers . And I want to amp the two subs under the seat and a small one in the trunk. I need help finding a wiring harness that's fits the stock radio with some RCA so I can run them to the back for the amp. This guy Technic I wish I can get in contact with him but he can't receive PM . Does anyone else know of a place .
Ps. It's a 2010 e90 328i |
05-13-2016, 09:09 PM | #2 |
Rep 807
Drives: 2011 335is 6MT
Base, Hifi, or HK?
05-13-2016, 10:01 PM | #5 |
Rep 807
If you can't get a hold of him, you can make a similar harness to his 2/4 setup for about the same price by buying the male and female versions of the oem underseat woofer connectors. Using that with an LOC will give you the signal you need to amp the doors, underseats, and an additional sub.
If you also want to amp the rears and maintain HU fader capability you would need to step up to his HU harness, not sure that would be affordable to replicate with BMW parts. |
05-13-2016, 10:17 PM | #7 |
Rep 276
You know what my be no Sub in the trunk. Just some nice plug and play speakers and the subs under the seat.
Now, they say the earthquakes sws 8 are great as long as they are amplified. Does anyone know to confirm. And well my new question is, should I amp the door speakers too? With that make a nice combination? Not to much but just enough. Any suggestions. |
05-13-2016, 10:37 PM | #8 | |
Rep 807
05-14-2016, 12:12 AM | #9 | ||
Rep 276
The thing I don't want to do is run all the wires of the speakers all the way to the back . And I'm running all this on the battery. I don't want to install a capacitor. The Bavsound it's one of the main plug N play option what else is good that u guys know |
05-14-2016, 09:56 AM | #10 | ||
Rep 807
When you replace your speakers, you loose those filters if you don't add them back in with the crossovers on the amp. And further, you wouldn't gain much (if any) benefit on the underseats with out much power. Note, with the parrallel configuration in the stock wiring, you wouldn't be able to install the 2 ohm version of the Earthquake as it would reduce your channel load to 1.3 ohms vs 2 and would not be good long term for your head unit. Note that all the speaker wire you would need to run would be to an from each underseat. You can connect your door signals right back to that location (like the technic harness does). Capacitors are useless, don't worry about them. Today's amps are extremely efficient, don't worry too much about the extra draw on your electrical system. Don't start counting out your money yet, I think there are some better options to accomplish your goals without $500 component sets. This is my staged plan that I'm currently executing, minimizing outlay of cost until i find the sweet spot for my listening preference: Quote:
