335d Manual Conversion
05-16-2016, 03:01 PM | #1 |
Rep 148
Hi Guys,
I am planning to convert my car to manual this winter, I was just wondering if anyone could think of any parts I may need / have forgotten. List so far: 330d 6 speed gearbox single mass flywheel stage III clutch CAE shifter 330d diff with quaife LSD?? 330d propshaft, or can I used the existing one? Pedal Box Master cyclinder Anything I have missed please let me know, as I will be doing this myself and therefore making mistakes along the way lol. Cheers, Aaron |
05-16-2016, 03:52 PM | #2 |
Rep 114
I really hope you do this! I dont think I have any answers for you, just more questions.
Will the 330d transmission hold the torque? I know that you are planning on an uprated clutch, is the rest of the transmission strong enough? Is your intention to retrofit a factory bmw clutch pedal/hydraulics, or use race parts like tilton pedalbox? Also that all sounds really serious, what suspension setup will you be running? Finally, any reason your going with a quaife? I dont mean to suggest i think you are doing anaything wrong, just curious. |
05-16-2016, 04:07 PM | #3 | |
Rep 148
The 330d gearbox is built like a truck gearbox and there is a race team near me who run one in their VLN 135d race car and haven't broken it. Hopefully retrofit factory items as the car is still used as a daily between track days. I am currently running 3 way adjustable coilovers, polybushed front end, thicker sway bars, camber arms and big ass brakes. I am planning to solid mount the rear end when I do the conversion to help get the power down more effectively. I have heard drexler diffs have a tendency to send the car sideways whereas the quaife allows more slippage before locking in turn hopefully being quicker on the track. |
05-16-2016, 04:10 PM | #4 |
95
Rep 308
Drives: 2011 335d M-Sport, Nav/Blinds
Just be careful...
BMW's excuse for not offering the 335d in manual is "too much torque" so I would just make sure your components are bulletproof. |
05-16-2016, 04:39 PM | #5 |
Rep 148
They do state that however, Id probably rephrase that as too much torque for ham fisted drivers who ride their clutches. I can imagine I will probably find the weak spots if there are any after a few sessions at the track. But with a manual box a tuned 335d will rip! I can imagine it being a bit of a monster.
05-16-2016, 04:51 PM | #6 | |
864
Rep 642
05-16-2016, 05:06 PM | #8 | |
144
Rep 316
Tuning for Garzy should be much simpler as there are edc16 manual diesel files to start with from bmw, correct? |
05-16-2016, 05:19 PM | #9 | |
864
Rep 642
05-16-2016, 08:01 PM | #10 |
Rep 130
That would be an awesome option! When I converted my 01 F350 to manual, I luckily found that all it really took was a re flash/chip and some wires jumped out. But that is a 01 Ford, it would be great if the BMW swap was similarly as easy.
05-16-2016, 08:38 PM | #11 |
Rep 3,553
Iaknown started similar thread a while back wondering how NA 335d could be converted. It sounded like the gearing was going to be too tough to match up properly and cause too high RPM at high speed cruise. I'll see if his thread can be found.
EDIT: found it but don't know how to copy link on phone. It is called Manual trans conversion? He states final gear in 330d manual is .84 versus 335d top gear is .69. Not sure about differential ratio in a 330d but 335d is 2.81:1 Last edited by BB_cuda; 05-16-2016 at 08:54 PM.. |
05-16-2016, 09:14 PM | #12 | |
864
Rep 642
05-16-2016, 10:11 PM | #13 | |
418
Rep 1,040
Here is the link gents: http://www.e90post.com/forums/showth...t=manual+trans |
05-16-2016, 10:32 PM | #14 | |
144
Rep 316
The consensus of many involved in the other thread is that if you were go through the hassle of manual swapping, using the a tremec 6 speed which is rated to 700lb/ft is the most logical choice for both strength and serviceability. Downside is a custom flywheel, adapter plate, and driveshaft. That way, if you already have an lsd, you don't have to mess with the rear end at all either. |
05-16-2016, 11:12 PM | #15 | |
Rep 130
I was already semi guinea pig for my truck swap, not willing to follow suit on the bmw, but may be interested. |
05-17-2016, 02:34 AM | #16 |
Rep 148
I believe the shorter ratios in the 330d box would be beneficial for the track, ECU wise will be something I will have to work around. A local race team have done the conversion in their VLN 1 series BMW. I believe they are running a bosch motorsport ecu. I am going to pop in and see them next week to pick their brains. I will try and get some picks of their car whilst there.
I honestly think the benefits of this conversion would outweigh the head aches of getting it right, plus once its been done successfully the knowledge could be shared with others to in essence make it a straight forward job. Another reason for using the 330d gearbox is they are readily available in the UK and far from expensive. |
05-17-2016, 11:06 AM | #17 |
Rep 114
Does tr6060 fit without modifying transmission tunnel?
Also, wanted to add that I imagine youd need a brake fluid resevoir from a manual car, as it feeds clutch also. Id like to know more about that bosch ecu they use on the 135d, would it play nice with all the factory bmw stuff like cluster, sensors and emissions crap like scr and dpf etc? Edit: Also, they mention a different steering rack, any idea which theyre using? |
05-17-2016, 12:08 PM | #18 | |
864
Rep 642
05-17-2016, 01:36 PM | #19 |
Rep 114
Their site says its the Bosch Motorsport 15.2, and quotes like 10k. Could that be incorporated into an otherwise stockish car? Or would you need to still use the factory ecu to run chassis functions?
Bob do you know anything about steering rack swaps? Anything to watch out for? |
05-17-2016, 02:56 PM | #20 | |
144
Rep 316
05-17-2016, 03:54 PM | #21 |
Rep 148
I think the standard ecu would be fine with a little fettling, Id like to use my car as a track biased road car so wouldn't want a motorsport ecu and tbh I think it would be tad over the top for something like a manual swap. Definitely need a reservoir for the clutch fluid. But I imagine the holes and mounting points would all be on the car anyways.
On the subject of steering racks I'm fairly sure they said it was an M3 item, will definitely ask the question as may pop in to them tomorrow. |
05-17-2016, 07:31 PM | #22 | |
Rep 114
