2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications How to disassemble 3rd brake light?
      05-17-2016, 03:38 AM   #1
SrCocozo
SrCocozo's Avatar
Spain
Drives: BMW 2 Series Coupe
Hello, I am trying to remove the third brake light, but can not find the way to do it. The light is glued to the glass or is there another way to remove it?
(2 series Coupé 2015)
This is the part that I want to disassemble ↓
      05-17-2016, 10:39 AM   #2
jeffery_stearns
jeffery_stearns's Avatar
Drives: Mineral White BMW M235i, X5
2015 BMW m235i  [0.00]
2015 BMW X5  [0.00]
You trying to achieve the ///M look?
      05-17-2016, 10:43 AM   #3
SrCocozo
SrCocozo's Avatar
Spain
Yep, just like this:
      05-17-2016, 03:34 PM   #4
dansu
Drives: 16 M235i
I'm going from memory here but there are 2 plastic clips around the area that I circled which either pull out or slide out. Once the clips are out, the entire assembly should come free.
      05-17-2016, 04:16 PM   #5
SrCocozo
SrCocozo's Avatar
Spain
Okk thanks! I'll try it
If I can't, I will try to make a more detailed picture of the area that you told me.
      05-17-2016, 04:21 PM   #6
Michall
Drives: 15 M235i
I think it should be similar to this
      05-20-2016, 03:51 PM   #7
jeffery_stearns
2015 BMW X5  [0.00]
Any luck?
      05-20-2016, 05:10 PM   #8
Drpoomanchu
Drpoomanchu's Avatar
Drives: AW M235i Man FBO
You pull the square tabs to the drver and passenger side of the car... Mine were very hard to get snapped out... Took a good bit of force...
      06-04-2016, 07:49 PM   #9
SrCocozo
SrCocozo's Avatar
Spain
Ok, I've done as you said to me, pushing the square tabs to the sides ← →
      06-04-2016, 07:50 PM   #10
jeffery_stearns
2015 BMW X5  [0.00]
Progress
Ok, I've done as you said to me, pushing the square tabs sideways ← →
How's the progress coming along?
      06-04-2016, 07:53 PM   #11
SrCocozo
SrCocozo's Avatar
Spain
What do you mean?
      06-04-2016, 07:55 PM   #12
jeffery_stearns
2015 BMW X5  [0.00]
M Brake Light
What do you mean?
Did you complete and perfect the look? Or are you still in the process?
      06-04-2016, 07:58 PM   #13
SrCocozo
SrCocozo's Avatar
Spain
I have already done, the only 'problem' is that only you can see if you look from the side, if you look right from behind the logo is not visible.
      06-04-2016, 08:00 PM   #14
jeffery_stearns
2015 BMW X5  [0.00]
Share
Care to share some pictures? Curious to see the turn out.
      06-04-2016, 08:04 PM   #15
SrCocozo
SrCocozo's Avatar
Spain
Ok no problem. Tomorrow I will shot a couple of photos and I will upload here.
      06-04-2016, 08:08 PM   #16
jeffery_stearns
2015 BMW X5  [0.00]
Bimmer Post App
You should consider the BimmerPost App its convenient and easy to use. Makes it easy to upload pictures and stay connected with fellow 2'ers.
      06-04-2016, 10:09 PM   #17
Drpoomanchu
oh my, never knew such an app existed
      06-05-2016, 05:08 AM   #18
siwo
siwo's Avatar
116
Drives: 2016 M235i RWD 6MT
Ditto. Imma download it now.
2016 M235i RWD 6MT - Current! as of July 28/16
2015 ES350 6AT - Traded In
2004 RX330 5AT - Sold
2004 Civic Coupe Si(EX) 5MT - Retired
1993 Civic Coupe Si(EX) 5MT - Retired
      06-05-2016, 05:10 AM   #19
siwo
siwo's Avatar
116
Sorry for the hijacking lolz, got carried away. Question: Is the top mounted brake light an LED light or regular halogen/incandescent? (I'm still waiting for my car from Germany so no idea here)
Tags
2 series coupe, brake light
2addicts
