Any Arizona ABC deletes?
05-23-2016, 01:03 PM | #1 |
Oil Burner
11
Rep 28
Pardon my ignorance, but I am seeing some conflicting information regarding passing emissions testing with ABC deletes. I am in the Phoenix, AZ metro area, which does require testing, but my understanding is that it's an OBD-II test only (perhaps a cursory visual inspection)? The whole process takes like 5 minutes.
Is there anyone here who has been through the AZ test with coded-out EGR, DPF, and/or SCR deletes? I'd like to unleash this beast but I'm not super interested in swapping out components every two years just for emissions testing. Also, is anyone aware of any good local shops for doing the exhaust system work? I'd rather not do the under-car stuff myself (I'm old and lazy). Thanks in advance!
2011 BMW 335d M sport
05-23-2016, 04:55 PM | #2 | |
Rep 128
I'm I AZ but don't have the deletes. If you look at ADOT's site though you will see that they do an opacity test on diesels as well. So it is not just OBD that you should be concerned with. Hope this helps.
05-23-2016, 04:59 PM | #3 | |
Oil Burner
11
Rep 28
Thanks. I did just run into that info:
