E90 Base Audio - strange behaviour
05-26-2016, 10:55 AM | #1 |
Rep 70
Hi Guys,
After some advice here. I have a 2006 E90. Car has CCC and base audio. Currently fitted, I have Morel Front speakers (driven by Amp) Morel Underseat Midbass (driven by Amp) Standard rear speakers, driven by headunit. Audiocontrol DQL-8 which provides equalisation, and Speaker level to Phono signal conversion Its wired so Head-Unit front speaker output connects to Audiocontrol. Audiocontrol runs in 2 channel mode, which provides front, and subwoofer phono out. So heres the problem. I decided to connect the head unit underseat speaker out to the Audiocontrol, so I could run the Audiocontrol in 4 channel mode. However it doesn't work - I don't get any output from the phono's which are paired to the underseat speaker input. The Audiocontrol is normally auto-switched-on from speaker level inputs connected to "main" input. When the Front is connected, it turns on As a test I connected the underseat speaker output to the main input of Audiocontrol, and it won't turn on. This to me indicated that the underseat speaker output was not working, so I connected a pair of speakers and got audio. So, kinda stumped - has any got any experience of this? Thanks! |
05-31-2016, 05:12 AM | #2 |
Rep 70
Just gonna answer my own question here. Since front channel will turn on the audiocontrol, I decided not to worry about the using the underseat signal wires.
I did replace the original poorly fitted midbass units under there with a pair of MB Quarts, and now am finally happy with the sound. Next job will be to get a 6 channel amp to replace my 4 channel, then I can correct the level from the rear speakers. |
