Logic 7 retrofit/swap (from a donor car)
05-27-2016, 12:18 AM | #1 |
Rep 1,173
Hey folks,
So I've found a wrecked E90 that will soon be stripped for parts. Id like to go and remove the full Logic 7 audio system and retrofit it into my car. My car came with Hifi/Professional/iPod/Aux/Bluetooth. I will most likely install it the same time I do a NBT retrofit, so a lot of the interior will already be taken out or disassembled. My question is, what all do I need to remove and source from this donor car?
Thats a total of 13 speakers. However, last but not least is the wiring harness. Does this harness start in the trunk and lead to each and every speaker? Or could I somehow re-use my existing wiring? Are there any other modules needed for the Logic 7 system? Is there somewhere that I could find diagrams and schematics (I haven't fully searched for them yet). NBT is a whole other story, I'll worry about that later. I mainly want to know what all I need to remove from this donor car. I appreciate any guidance you may have to offer. Thanks, Tom. Last edited by TomTomTuning; 05-27-2016 at 12:40 AM.. |
05-27-2016, 01:17 AM | #2 |
1911
Rep 13,103
FYI
http://www.e90post.com/forums/showth...light=retrofit
Looks like you would have to do the rear deck for speaker locations there to. Most aftermarket stuff for audio is better than logic 7 though. |
05-27-2016, 01:23 AM | #3 | |
Rep 1,173
Did I miss something? That thread only covers the navigation retrofit, not Logic 7. |
05-27-2016, 02:26 AM | #4 |
1911
Rep 13,103
Almost nobody in the US does a logic 7 retrofit
sometimes a European does it . Yes it doesn't show the logic 7 part but is does show the idrive part. but its at least some of it. |
05-27-2016, 11:18 AM | #5 |
Rep 1,173
From what I've gathered it's a pity, but for the right price I wouldn't mind doing the retrofit. I'm guessing the harness is the biggest hassle.
Does anyone know where I could find a wiring schematic for the audio system? That may help tremendously with determine what is needed and how to uninstall/re-install everything. |
05-27-2016, 03:25 PM | #6 |
Rep 5,002
Do non hifi cars have the MOST wiring structure installed from the factory that supports the logic 7 system?
If not, bail fast and bail hard, otherwise this is going to be a time sink. Stealing all the speakers, except for the underwear woofers is a good idea, tho. Do that. |
05-27-2016, 04:26 PM | #9 |
Rep 807
OP, I have logic7 but to be honest, it's okay sound IMO so I am not sure if the retrofit is worth it.
Garage: BMW i3 Giga World BEV | BMW E70 X5 |
05-27-2016, 05:23 PM | #10 |
Rep 1,173
I've had it in a previous car and although it's not the best, it's certainly better then the base hifi. I am mearly trying to take advantage of the opertunity.
05-29-2016, 10:00 AM | #12 | |
Rep 4,121
05-29-2016, 04:13 PM | #13 | |
Rep 2,749
speaker wires to the doors connectors front dash speaker grille cover MOST circuit to the rear concentrator these wires are combined with main audio harness, but you have to remove front seats, central console tunnel and all details attached to dashboard to remove this wiring you also need rear door trims if you have base audio system
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
05-30-2016, 09:50 AM | #14 |
Rep 3,969
This is a REALLY bad idea. Seriously.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-30-2016, 11:04 AM | #15 | |
Rep 16
05-30-2016, 04:15 PM | #16 |
Rep 1,173
Yeah, that harness swap is really starting to sound like it's not worth the effort. I'll probably just skip the Logic 7 retrofit, and just upgrade the base components.
I'll install the front tweeters near the window trim, and add tweeters to the rear deck. However, I'm wondering if I could add the rear door panel speakers? Would that screw up the acoustics of the car? |
06-15-2016, 02:33 PM | #17 |
Rep 2,749
if you have good soldering skill you can cut harness near amplifier and get most circuit part to most concentrator
after that you can run new cables in car and solder them to amplifier harness
