BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > BMW Subwoofer Swap Question
      05-27-2016, 07:33 AM   #1
meith23
Drives: 2007 328i e90
Im think about replacing my 2007 328i e90's subwoofer with a "Earthquake Sound SWS-8Xi 8-inch Shallow Woofer System Subwoofer". I want to know if I have to replace both underseat sides or can I do just one. Also, do I have to replace the amp? Should I get 2 or 4 ohms? Thank you, delete if not allowed
      05-27-2016, 07:57 AM   #2
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
Replace both, if you are hi-fi get 2ohm and you can keep your stock amp, if you are Logic get 4 ohm and keep your stock amp, regardless of whether or not to keep the stock amp, it is always best to upgrade
      05-27-2016, 08:35 AM   #3
meith23
Replace both?
thanks so much, but is it absolutely necessary to replace both. can I replace one now then another in like a month?
      05-27-2016, 09:27 AM   #4
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
You are obviously on a tight budget. Without an external amp, the SWS-8 will not do anything for you. Even with the amp, they still sound terrible, but some people like them, most others end up replacing them with true mid-bass woofers and adding a trunk sub. If you don't want to spend a lot of money, and just want some more bass added to your existing set-up, just get a cheap trunk amp/sub/box combo. It will not blow you away from an SPL or SQ perspective, but it's probably the most bang for your buck upgrade you can do. Another option would be to put an amp on the existing OEM woofers, but you will run the risk of blowing them if you're not careful, and the added amount of bass is limited. You will definitely gain mid-bass, but not so much sub-bass. The trunk sub is all about sub-bass.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
      05-27-2016, 09:40 AM   #5
meith23
I've heard that replacing the underseat subs even without an amp make quite the difference. and also i've heard that trunk boxes make no difference because of the trunks installation.
      05-27-2016, 09:44 AM   #6
6spdcoupe
tends to get irritable
6spdcoupe's Avatar
Drives: 14 F15,18 M550,20 Highlander
With all due respect, if you have 'heard' such things, then why ask here if you're only going to apparently disregard the advice that is trying to be given ?
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile
      05-27-2016, 10:07 AM   #7
meith23
sorry but I never asked for any advice on putting subs in the trunk. Only about underseat, one person said one thing and another said another. Its confusing.
      05-27-2016, 10:36 AM   #8
6spdcoupe
6spdcoupe's Avatar
I was referring to your first statement about the underseats, not a trunk sub.
      05-27-2016, 10:51 AM   #9
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Under seats give an improvement. Trunk subs a vast improvement depending on what subs you use and how you fire them into the cabin. I'm hampered having an e93. But I plan on a 10inch w3v3 jl audio with 300w nominal firing into the cabin through the ski bag pass through. This will blow the doors literally off any under seat options. With an e92 or more money there's even better options.
      05-28-2016, 04:12 PM   #10
OveN
Norway
20
Drives: '18 F22 230i
In my opinion, the OEM amp is the weakest link by far. Replacing the amp is a way better upgrade than just replacing the underseat woofers.
I replaced the OEM amp in my car, then replaced all speakers about a month later. The biggest improvement of the two stages was definitely the amp upgrade.
      05-29-2016, 04:11 PM   #11
tlow98
Drives: 2009 E91, 2014 F15 x35i
Nice A/B comparison.
Your stock system hifi, L7 or ESP? What amp did you go with, if you don't mind me prying... Guessing you used a Tachnik harness or similar.
Thanks
      05-30-2016, 01:09 PM   #12
OveN
Norway
20
Thanks
I have 676 HiFi.
I put in JL HD900/5, then replaced front mid&tweeter with Morel Hybrid 402 and underseat subs with SWS 8X.
Channel 1-4 powering FL/FR/RL/RR. Ch. 5 powering the SWS's in parallel.
Unfortunately I could not get hold of Technic harness in time from Norway so I cut the signal wires coming from HU at the connector going into OEM amp and soldered phono plugs onto those wires to plug into JL amp.
I have sold the OEM amp so the fact that I cut the wires doesn't bother me too much anymore. Nobody with a sane mind would ever want to revert this to OEM
(This summer I will pull extra wire to each front door to go full active, install Mosconi DSP 6to8, replace SWS with Jehnert XE200, install trunk sub and ditch rear speakers. Haven't decided on amps yet...)
OP: Sorry for all this off topic
      05-31-2016, 01:58 AM   #13
tlow98
No need to apologize, I like hearing how other people are doing things!
Also, I agree, pnp functionality is great but with the age and usage of these cars, who on earth would go back to OEM?
I am guessing that you are lacking some mid bass based on your future mods? The morels can pull a lot, but I suppose 4" just can't play what the 8" could. (All twss jokes aside!)
Until next time...I've got to get an amp and a power wiring kit in Order to be fully on my way.
