Speakers Rattling
06-01-2016, 03:14 PM | #1 |
Rep 277
Drives: 08 e92 335i
Speakers Rattling
Alright so I have an 08 e92 with the logic 7 system and every once in a while my front passenger speaker would rattle with bass but it would always stop after a second. Recently, however, that speaker won't stop rattling. I thought it was a loose screw or something so I opened the door panel and tightened all the screws holding the speaker. And it helped a little but not much. Is there any way to fix this or is this a blown speaker?
06-01-2016, 03:40 PM | #2 |
Rep 277
Drives: 08 e92 335i
Also want to note that whenever it begins to rattle I can actually hear that speaker a little more than usual
06-01-2016, 07:15 PM | #3 |
1911
Rep 13,103
Looks like you need to swap it to tell.
You could reverse sides (from door to door) if you want to know for sure before buying another speaker. |
06-02-2016, 07:24 AM | #4 | |
Rep 277
Drives: 08 e92 335i
06-02-2016, 09:03 AM | #5 |
Rep 277
Drives: 08 e92 335i
Update
So after switching out my speakers I've found out that both my speakers look fine and sound Normal in the driver side door so I sat down with the speaker and played bass heavy music while sitting in the passenger seat so I could figure it out and turns out that it's my right underseat sub woofer that is the problem. Can I take it out for the time being? Is this a good excuse to upgrade to get some bavsound ghost subs? (I want something PnP)
06-02-2016, 11:09 AM | #6 |
1911
Rep 13,103
There are better and cheaper things to put in
than bavsound under seats and doors. You can get a set of the mbquarts right now from vm innovations for around 230 on the cheap side. And they include doors and floors. there are probably close to 10 companys that make plug and plays or near it for these now. |
06-02-2016, 11:09 AM | #7 | |
Rep 277
Drives: 08 e92 335i
06-02-2016, 11:37 AM | #8 |
1911
Rep 13,103
It would be better with and amp but
https://www.vminnovations.com/Produc...wD7xoCUx3w_wcB
It would be better with and amp you might try them without one. I would look to see if there are any reviews of them with a stock L7 amp. They are advertised as plug and play. |
06-02-2016, 11:38 AM | #9 | |
Rep 277
Drives: 08 e92 335i
06-02-2016, 11:50 AM | #10 |
1911
Rep 13,103
Depends on how carefull you are?
Depends on how careful and patient you are ?
If you managed to the do the door swap without screwing things up the floors are simpler. So that's the mechanical skill part. If you understand how to put together a home stereo system the wiring is no more difficult. The only wiring you have to think about is the crossover in the doors factory wiring to crossover . crossover to tweeter and mid. If you are doing and aftermarket amp in an L7 system that is a different subject depending on what you want to amplify. You would need a Technic Harness to do that without messing with your factory harness and probably have to modify it a bit to do the front doors. |
06-02-2016, 11:58 AM | #11 | |
Rep 277
Drives: 08 e92 335i
06-02-2016, 12:03 PM | #12 |
Rep 277
Drives: 08 e92 335i
Also can I disconnect my right underseat woofer for now? Will it cause any problems if I play music with it disconnected? The sound it makes drives me insane
06-02-2016, 12:09 PM | #13 |
1911
Rep 13,103
I know nothing about subs
but here are some links subwoofer threads http://www.e90post.com/forums/showpo...2&postcount=66 http://www.e90post.com/forums/showth...t=Ultimate+Sub http://www.e90post.com/forums/showth...ight=subwoofer getting in contact with Technic seems hit or miss. http://technicpnp.com/product_purcha...eries_E90.html http://technicpnp.com/contact.html I would discuss this with him if possible if you want to do the doors with and amp also if you get and amp there are better speakers like Jehnerts, Morels or Gladens if you have the bucks to spend. My installation procedure for a Hi Fi kit shows the door and underseat installation procedure in the high Fi section of the audio build thread. http://www.e90post.com/forums/showthread.php?t=641323 Last edited by ctuna; 06-02-2016 at 01:35 PM.. |
06-02-2016, 12:42 PM | #14 | |
Rep 277
Drives: 08 e92 335i
06-02-2016, 01:33 PM | #16 |
1911
Rep 13,103
I don't think it will it might just be loose in the
I don't think it will speaker might just be loose in the
speaker housing or have something loose on top of the speaker to. Last edited by ctuna; 06-02-2016 at 07:51 PM.. |
