European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3 / M4 Photos and Videos
      06-01-2016, 10:32 PM   #1
Rocnic
Drives: M5
Xpel due diligence
I am scheduled to receive my f80 early next spring. I plan on installing xpel ultimate. Not going overboard...just the front bumper and lower portion of the hood. I am particular when it comes to swirls and washing, so when my car arrives at the dealer, should I have them leave all the plastic on and bring it directly to the installer? Or have car detailed first then send it to have the xpel installed?
      06-02-2016, 12:21 AM   #2
idyfohu
Drives: 09 E92 335i
Leave the plastic on...detail it yourself (or have a detailer do it) and decontaminate/prep for the Xpel, then have Xpel installed.
      06-02-2016, 12:41 AM   #3
MadZarBMR
MadZarBMR's Avatar
Drives: Current: '18 M3 ZCP - 6MT
Next spring as in 2017? You sure are planning well in advance...
Anyhow, any reputable installer will know the proper way to prep before install. Should not really need much since the paint is new. Having it professionally detailed before install is wasting money and perhaps creating more work for the installer since the surface needs to be naked for a proper install. Detail after XPel is installed since you will want to have all residue from install removed.
      06-02-2016, 08:46 AM   #4
te37
te37's Avatar
545
Drives: F80 SS/SO 6MT
If the XPEL installer cannot prep before applying the film... walk away lol
      06-02-2016, 08:54 AM   #5
qspring
qspring's Avatar
105
Drives: 2016 M4
Don't let the dealership touch it. Keep the plastic on and take it straight to your detailer.
I
2016 BSM M4 - BBS FI-R, Hex tune stage 2, JRZ RS1, DP/CP/Intake/exhaust
Follow me on Instagram @qs_m4
      06-02-2016, 11:50 AM   #6
XPEL
XPEL's Avatar
343
Drives: M3
Congrats on the new F80! If you are not wanting swirls, I'd recommend at least a full front end of XPEL. If you do just the front portion of the hood, the area where there is film applied, will not have swirl marks due to the films self-healing properties.
Regarding the care/prep, regardless of what you choose, the installer will wash, clay and wipe the vehicle down where they are installing XPEL ULTIMATE before applying the paint protection film. This is required to make sure it is smooth and has a clean surface to bond to. If you have any questions, please let us know
      06-02-2016, 12:05 PM   #7
alexc93
Drives: na
Just out of curiosity, when clay barring it can often cause some light swirls in the paint work. If a car is polished etc prior to an install, then the installer washes, clays, wipes down and causes some light swirls in the paint, are these visible through the xpel film?
      06-02-2016, 12:31 PM   #8
XPEL
XPEL's Avatar
343
Drives: M3
Not at all, that's the great part of XPEL ULTIMATE. It actually masks swirl marks during the installation process. At our corporate install centers we don't do any sort of paint correction, just wash, clay and wipe down and then install XPEL. One of our installers in Atlanta, Detailed Designs Auto Spa made a youtube video showing how well it masks the swirl marks.
      06-02-2016, 12:33 PM   #9
SpeedandTechM
49
Drives: e36 M3s, e46 M3
100% correct. Any certified Installer will do the prep work, but if paint correction is needed, there may be additional charges. Number 1 rule, leave the film on from factory, number 2 use a reputable shop that is certified for warranty purpose, number 3 enjoy the new car everyday and have fun.
      06-02-2016, 03:04 PM   #10
alexc93
Drives: na
Very cool thank you for the info!
      06-02-2016, 11:53 PM   #11
Sergm3
Drives: 2014 f10 m5 comp
Will xpel ultimate still perform self healing properties if it's coated after install with Modesta coating? Thinking on doing both on the hole car.
      06-03-2016, 09:25 AM   #12
XPEL
XPEL's Avatar
343
Drives: M3
Ceramic coatings should not interfere with the self-healing properties of the ULTIMATE and STEALTH paint protection films
      06-03-2016, 09:39 AM   #13
Bch53211
Drives: 2015 M4
2015 M4  [0.00]
2015 M4  [0.00]
2015 M4  [0.00]
Why go through the expense and have to look at the ugly clear bra the cars entire life? If you get a small ding or scratch on the front just get it touched up, would probably still be less expensive. I've had my M4 for almost a year now and would say the paint holds up very well.
      06-03-2016, 09:56 AM   #14
alexc93
Drives: na
You can't see a clear bra if installed properly...I agree on not wanting half a hood clear bra'd etc. but if the entire panel is covered you wouldn't even notice
      06-03-2016, 09:56 AM   #15
Sergm3
Thanks
      06-03-2016, 10:00 AM   #16
TheIceStormOf06
Drives: BMW E93 Sold
Sorry to Threadjack. Can someone tell me how Expel Would affect the sheen, gloss, transparency or reflective qualities of BMW metallic finishes? I am wanting to do Shakih Orange and then wrapping it. I have no intentions on touching up paint for chips.
If it's affected, would I need to wax/polish after applying the wrap? SO is a chamillion kinda paint that changes in varying light. I'd hate to loose that due to a wrap. Need honest feedback
Thanks-Any help is greatly appreciated.
      06-03-2016, 10:09 AM   #17
XPEL
XPEL's Avatar
343
Drives: M3
It doesn't affect the sheen/gloss or transparency, as the film is optically clear. All the metallic flake you see, will come through as normal. It nearly matches the factory clear coat. So much so that you can't typically tell between a covered surface vs a bare surface. The only thing you would see is that where there is film, there would be no swirl marks. (Thanks to the self-healing nature of XPEL ULTIMATE)
You CAN wax or using a coating/sealant on it, but just regular wash and dry is the regular maintenance. If you want you can apply a sealant or wax and that will do the same thing it does for regular clear coat.
      06-03-2016, 10:11 AM   #18
te37
te37's Avatar
545
Xpel will not change your paint appearance at all. Xpel naturally has a slight orange peel to it so from 3 feet away you cant even tell it is there.
      06-03-2016, 10:20 AM   #19
XPEL
XPEL's Avatar
343
Drives: M3
Tried finding examples of how clear the film is, these are some recent BMW's that have been at our shop in San Antonio
Full Front End XPEL ULTIMATE 428i
Full Wrap XPEL ULTIMATE M3
Full Front End XPEL ULTIMATE M3
Full Front End XPEL ULTIMATE M6
XPEL ULTIMATE M3
This was done at on our independent installers, Full Wrap XPEL ULTIMATE M3
      06-03-2016, 10:22 AM   #20
XPEL
XPEL's Avatar
343
Drives: M3
An up close look at a M235i
      06-03-2016, 05:55 PM   #21
TheIceStormOf06
Awesome!!! This is what I wanted to know. And the pictures confirmed it. Perfect
Thank you
f80post
