06-09-2016, 11:43 PM | #1 |
Catch me if you can
63
Rep 679
Issue with the AutoTecknic shift pedals
AT, FYI...
Issue with the AutoTecknic shift pedals Was trying to install AutoTecknic CF shift pedals and they are too tight in their own plastic 2pc housing. Tight to the point where the springing is none existent, i.e. I cant click it at all in order to gear up or down. Its both of them left and right. On top of that the plastic pin that should hold them together will not fit through. Whats up with that? For the price I expected perfection. When I put the two plastic peaces covers together (spring in the middle), there is no spring affect. Its too tight. And the plastic pin that should hold those two together, well does not fit... Did I get a bad batch or is it common and some filing is required? Emailed AutoTecknic for an explanation... |
06-10-2016, 09:24 AM | #2 |
BimmerPost Supporting Vendor
966
Rep 13,780
have they answered yet? i haven't seen anyone have any issues to be honest.
If there is a an issue with one of there products they are very good with replacements |
06-10-2016, 08:12 PM | #3 |
Catch me if you can
63
Rep 679
They did! they asked for the order##
In progress ... Thank you! I will keep everyone posted... |
