TUC; ULF, MULF, MULF2, MULF 2 High... My Heads spinning
06-16-2016, 04:30 AM | #1 |
Rep 176
Drives: E90 2009
Guys,
I have a 2009 E90. I have Bluetooth telephone, but no Bluetooth Audio. I have the Eject box with a Snap-in adapter for a stone aged Nokia in my center console arm rest. I wanted to get some OEM or retrofit way to get the Bluetooth audio steaming. So i started reading. And read some and more reading and some more and now i am confused to the point that i am planning to give it all UP.. This is my last try and cry for help for some info from you experienced addicts there to solve my dilemma. So My VIN says I have 6AA Bmw Teleservices 6AB Control Teleservices 609 Navigation System Professional 612 Bmw Assist 614 Internet Preparation 615 Extended Bmw Online Information 616 Bmw Online 620 Voice Input System 633 Prep.mob. Ph. Business Bluet.interf. 672 Cd Changer Bmw For 6 Cds 698 Area-code 2 7RS Comfort Package 7SP Navi Professinal W.handyprep.bluetooth I already have maxed out my Audio storage on the Harddrive. So what All do i need to do to Get me some Bluetooth audio streaming? Should i remove the CD changer and use something else instead? Or which MULF do i need or do i need one? I already have a blackberry gateway on my Wishlist on Amazon, if all else Fails. thanks to all in advance. Hope someone can give me some valuable info. All Ideas welcome Regards Kaputme |
06-16-2016, 05:14 AM | #2 |
Rep 260
i would suggest a combox retrofit.. that's the most OEM way to get bluetooth streaming in a CIC unit. you can also from there add the 6FL option which is the USB in the arm rest.
you could also use an aftermarket product like a Denson Gateway but the costs to do the OEM option with a combox would be similar. to add a combox you would need the following; bmw combox retrofit harness (can be made and there is a good guide on here to do so) coding you can then add all maner of extra options such as BMW APs, USB in armrest, media cradle. take a look at the below; http://www.bimmerfest.com/forums/sho...d.php?t=772784 |
06-16-2016, 09:19 AM | #3 | |
Rep 176
Drives: E90 2009
Lets see if anyone has some better solutions.. What about the GROM stuff.. Does it work ? Last edited by kaputme; 06-16-2016 at 10:02 AM.. |
06-16-2016, 10:13 AM | #4 | |
Rep 260
If you can get a PNP harness or even have the skill to make one the swap in its self is really easy as the wiring will already be in the boot. just a simple case of unplugging the old unit, replacing with the combox and plunging all the connectors back in. the hard part is in the coding, but there are many people who can help you out with this and charge less than £100 (or Dolla/Euro) to do so. i have priced to do this including the combox and usb socket for less than £300 and will be getting someone local to code it for me to work. |
06-16-2016, 10:23 AM | #5 | |
Rep 176
Drives: E90 2009
Does my CIC not take the combox as it is? How do i check this? |
06-16-2016, 10:32 AM | #6 | |
Rep 260
09 was when the CIC unit was introduced so you should be ok.. does the controller in the center console have the options like radio, CD, nav or does it just have a menu button and a big silver wheel? |
06-16-2016, 03:31 PM | #7 | |
Rep 176
Drives: E90 2009
http://www.ebay.de/itm/BMW-Combox-Te...cAAOSwKfVXJL42 I don't know if its worth ... i'll keep looking Last edited by kaputme; 06-16-2016 at 03:38 PM.. |
06-17-2016, 02:18 AM | #8 |
¯\_(ツ)_/¯
170
Rep 425
30FF
06-17-2016, 03:03 AM | #9 | |
Rep 260
about 60 euro for the wiring adapter and 100 euro for coding |
06-17-2016, 06:03 AM | #10 | |
Rep 176
Drives: E90 2009
Will An F series Combox work as well it says "BMW F01 F02 F07 F10 F11 F25 X3 BLUETOOTH COMBOX TELEMATIK BN2010 ECE 9244189" I was seeing some stuff about replacing the CD changer and installing some emulator which lets you play USB and bla bla.. Any ideas on that?? Also I have the Ejectbox in my armrest, but it doesnot show up on my Idrive. Last edited by kaputme; 06-17-2016 at 06:32 AM.. |
06-17-2016, 07:24 AM | #11 | |
Rep 176
Drives: E90 2009
06-17-2016, 08:06 AM | #12 |
Rep 260
correct has to be an Exx combox...
the thing that plugs in to replace your CD changer is a denson gateway; its a sort of aftermarket combox http://www.dension.com/products/car-...ateway-500s-bt |
06-19-2016, 12:13 PM | #13 | |
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
06-22-2016, 06:02 AM | #14 |
Rep 176
Drives: E90 2009
06-22-2016, 06:33 AM | #15 |
Rep 260
06-22-2016, 09:28 AM | #16 |
Rep 2,202
Not sure if it I'll be the same for you but when I bout mine from the dealer, it seemed I lucked out on getting it cheaper than eBay sellers. But Josh is right.. More variety on the west than here in the states. Good luck
06-22-2016, 10:00 AM | #17 |
Rep 176
Drives: E90 2009
Just wrote my dealer an E-mail Lets see what they say
06-23-2016, 06:41 AM | #18 |
Rep 176
Drives: E90 2009
Ok this is what she says
eine Nachrüstung der Combox ist bei ihrem Fahrzeug nicht möglich. Dem Auto fehl die Ausstattung S6VC Steuerung Combox. Mit freundlichen Grüßen Means Not possible i don't have S6VC.. What is that? |
06-23-2016, 10:29 AM | #19 | |
Rep 260
just get the latest part number for a Exx combox and ask for a price on it or failing that just buy one from Ebay like i will be doing at the end of the month |
06-24-2016, 09:00 AM | #20 | |
Rep 176
Drives: E90 2009
Meanwhile i lifted up my trunk carpet and found the TCU alright, bit i saw that only 3 connectors were connected ( no connections on the blue one) i Have seen in most pictures all four connectors connected. Can anyone shed some light ?? |
