Base stereo help
06-25-2016, 11:51 AM | #1 |
78
Rep 360
Base stereo help
I'm am looking in to getting my base stereo upgraded and after hours of reading I can't figure out if I am able to code my base stereo to hifi or should I get something like a clean sweep ?
2010 335i Rwd 6spd
MHD Wedge tune, VRSF Exhaust,FMIC, DP and CP, PR Inlets 2014 X5 50i BMS stage 1, Dinan intake, F85 Knee Bolsters |
06-25-2016, 11:18 PM | #2 | |
Rep 4,121
06-26-2016, 06:08 AM | #3 |
78
Rep 360
Ok,
Just try to upgrade the easiest and best way without over spending Thank you
2010 335i Rwd 6spd
06-26-2016, 09:32 AM | #4 |
Rep 2,365
Drives: 2007 E90 323i (Cdn)
Coding is much cheaper and allows you to introduce fewer aftermarket components for a cleaner install and a bit less power drain.
Code to hifi, technic harness, JL 600/6 amp, MB quart 3-way kit, and done. Sub optional.
06-26-2016, 11:56 AM | #5 | |
78
Rep 360
2010 335i Rwd 6spd
06-27-2016, 05:23 PM | #6 | ||
Rep 2,365
06-27-2016, 06:35 PM | #7 |
1911
Rep 13,103
Also Bimmertech can do it.
Also Bimmertech can do it.(coding)
They were charging about 160 plus a security deposit on the cable . You have to have a laptop and work with them on it. On the later model cars after 09 or 08 you need a icom cable to code the radio rather than the simple coding cable most use. |
