M2 Technical Topics > Suspension | Brakes | Chassis > F87 M2 share your alignment specs
      06-28-2016, 11:18 AM   #1
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I thought I would start a thread for everyone to share specs or any thoughts regarding factory or track oriented alignment settings.
Edit : This first alignment was with lowering springs only and no camber plates. I had a bit too much toe in at the rear.
When I installed coilovers/camber plates I settled on 1/16 total toe in the rear as recommended by HPAutosport.
0 toe with -2.8 degrees of camber front and
-2.0 in the rear. Car felt great on the street and track.
      06-28-2016, 11:34 AM   #2
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
There is a thread already where I posted mine.
http://f87.bimmerpost.com/forums/sho...ight=alignment
      06-28-2016, 11:49 AM   #3
HP Autosport
BimmerPost Supporting Vendor
Drives: F80 M3
From what you posted the rear has way too much toe-in, am I reading that right?
      06-28-2016, 03:21 PM   #4
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Thanks
      06-28-2016, 03:27 PM   #5
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I believe the total toe would translate to just about 4mm of total toe in. .37 degree of total toe.
I was put off that the m4 spec called for almost 0 toe in the rear. I've never ran so close to 0 on a rwd car. So I went in to about 4mm, equal to other f80 track alignments I've seen. Although I'm not running much camber at all.
What's your setup? I could be totally wrong but I didn't think it was overkill.
It doesn't help reading a alignment in MM and trying to translate/convert over from Swedish haha.
      06-28-2016, 03:38 PM   #6
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Most of the alignments should be easy to understand the names of.
The numbers are in the order Before // Accepted range // After adjustments. So Börvärden is what the allowed specs are for each item.
      06-28-2016, 03:41 PM   #7
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Yeah I took a look at it and figured it out. Thanks for posting that btw.
I've just heard of the f80 problems of squirm under braking with the almost 0 toe in they call for. I believe IND and others pushed it to around 4mm total to help the problem.
      06-28-2016, 03:53 PM   #8
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
I haven't pushed the car to notice anything like that (or it doesn't with the MPS) under braking.
      06-28-2016, 03:56 PM   #9
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I'll see in a month or so at the track. I'm new to track driving but I'll share anything I come across.
      06-28-2016, 04:17 PM   #10
David@ActiveAutowerke
Drives: M2
We're currently setup with -2.5* camber up front with 0 toe and -2* camber in the rear with 1/16" total toe-in.
      06-28-2016, 05:16 PM   #11
HP Autosport
Drives: F80 M3
I was put off that the m4 spec called for 0 toe in the rear. I've never ran 0 on a rwd car. So I went in to about 4mm, equal to other f80 track alignments I've seen. Although I'm not running much camber at all.
zero toe front and slight toe-in in the back is what you want. If that what you have, you are good to go.
      06-28-2016, 06:43 PM   #12
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Thanks guys. I'll dial it back a little bit
      06-28-2016, 08:35 PM   #13
clubsport
204
Drives: LBB
Mine, with just camber plates are:
Front -2.3
toe 1/64 in
back -1.9
toe 5/64 in
      07-04-2016, 09:21 AM   #14
MR.
MR.'s Avatar
4398
Drives: BMW M2 CSL Turbomeister
Guys, what is your preferred alignment setting for a stock car? Any thoughts on that?
I might have my tuner look at the set up since I have vibrations under heavy braking, and I do not think my brakes would be the main issue here with only 10K km driven.
MR
      07-04-2016, 09:48 AM   #15
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Anyone, how much front camber can be dialed in without aftermarket camber plates?
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      07-04-2016, 11:30 AM   #16
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
None over stock at -1.5
      07-04-2016, 12:50 PM   #17
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
MR
I probably dialed in a little too much rear toe. But my preferred settings are front 0 toe, rear-more toe in than it calls for, just a tiny bit.
Camber for me as well as everyone is -1.5 up front unless you have plates. No pins to pull here.
I set the rear at -2.
      07-06-2016, 05:52 AM   #18
MR.
MR.'s Avatar
4398
Excellent thanks!
MR
      07-07-2016, 04:55 PM   #19
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
So stock camber up front is 1.5? Shouldn't it change to something like 1.7 after being lowered?
Current
AW BMW M2
Past
VO BMW 1M
      07-07-2016, 10:52 PM   #20
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
It should once settled. It didn't Initially, at least without me in the car.
      07-11-2017, 07:18 PM   #21
chillindrdude
chillindrdude's Avatar
1161
Drives: anything with 4 wheels
Getting my camber plates done tomorrow. Anyone else with numbers?
My Trackable Street Car
2016 BMW M4 GTS
      07-11-2017, 11:03 PM   #22
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
TC Kline plates on coilovers here. Fronts are at -3 and rears at -2.3/4 on stock alignment eccentric bolts and stock arms. The front can go one degree more or all the way back to stock adjustability wise.
The only other suspension mods are H&R sways and adjustable links.
have a feeling I might be dialing back those camber figures but I have yet to see tires temps on track with the new setup. The car feels great though.
0 toe front
And a little more than factory toe in rear
m2
