For those that
06-30-2016, 07:28 PM | #1 |
Rep 64
For those that
live in a SULEV state, any valve cover gasket or eccentric shaft issues are covered by the BMWNA SULEV warranty. I just wanted to share this info. You can go to a dealer and ask them to replace these parts under warranty. Hope it helps others.
07-01-2016, 11:07 AM | #2 |
Rep 2,120
funny just had both of mine done under warranty at 133k and just over 8 years old. Was surprised it went as smooth as it did.
BMW CCA # 473001
07-01-2016, 11:29 AM | #3 |
Rep 64
that's good to hear.
07-01-2016, 01:35 PM | #4 |
mTekMods
2149
Rep 2,906
dmtl's just became a service bulletin as well.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
07-01-2016, 02:18 PM | #5 |
Rep 53
does your car have to be SULEV or the state?
17 340i, 6MT, THP, Estoril/Oyster | 16 340i xDrive, 6MT, THP, Estoril/Black (gone) | 10 328i, 6MT, ZSP, Black Sapphire/Black (gone)
@estorildan |
07-01-2016, 02:33 PM | #6 |
Rep 540
It should be covered under BMW SULEV warranty, state absolutely matter, so does the mileage and year of the car. It is not unlimited.
And Also it isn't the best idea to come asking for us to replace it. Legitimately we cannot unless there is an issue. There is a decent list of things that would actually be covered but it is more vin/age/mileage/area specific to the car then just saying its covered under SULEV/California emissions warranty |
07-01-2016, 02:44 PM | #7 | |
Do you even post BRO?
219
Rep 2,937
Drives: 330xi
E90|330xi|SGM|Terra Cotta interior|Forged1 Wheels(one side red the other city lights)|M3 Rep Front Bumper|Msport Rear Bumper|KW V1 Coilovers|K&N Air Filter|OEM Black Grille|Red Cyba Air scoops|DIY Gloss Black Side Splitters|Tee rear splitters|Monkey Air Freshener| |
07-01-2016, 02:45 PM | #8 | |
Rep 53
@estorildan |
07-01-2016, 08:37 PM | #9 | ||
Rep 2,120
BMW CCA # 473001
07-05-2016, 07:30 AM | #10 | |
Rep 540
But its possible to have em fail without faults. Still a dealer would need a drive ability issue at be able to point at that |
07-05-2016, 07:34 AM | #11 | |
Rep 540
Not everything is black and white |
07-06-2016, 08:47 AM | #12 | |
Rep 53
@estorildan |
07-06-2016, 11:14 AM | #13 |
Rep 540
Technically yes. They would have to smoke test the car or should to see if there is an air leak, they should be able to check out fuel trims and see compensation as well
Working on this same issue myself right now. Car runs rough and stalls with no CEL. |
07-07-2016, 11:19 AM | #14 |
Rep 64
I am relatively certain that SULEV means
that ALL related parts have to be operating optimally. If the VCG is leaking and the Eccetric Shaft Sensor area is leaking, there is most likely a vacuum leak and everything is not operating optimally. As a matter of fact, I believe that spark plugs also have to be replaced after 100,000 miles as they affect how the car runs, and hence emissions. If dealers are trying to argue their way out of this, they are most likely not honoring the warranty correctly. That is a good time to talk to BMWNA customer relations.
