TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Need a "power with ignition only" fuse at glove box
      07-12-2016, 02:37 PM   #1
derek7467
Drives: 2010 BMW 328i Sedan LCI
I have 2010 BMW 328i and will be installing a dashcam. I plan on wiring it down the A-Pillar into the fuse block. Which of the mini fuses that are 10amp or less are ignition powered on only? I basically want my dashcam to turn on with when the ignition is turned on and off when the car is off.
I could use a MM and test it, but I figured someone here would know better. Thanks!
      07-13-2016, 09:49 AM   #2
matteblue3er
Drives: Racecar
Cigg lighter is always switched
      07-13-2016, 10:04 AM   #3
derek7467
its a 20amp fuse though and my add a circuit says only to go up to 10amp fuses...
      07-15-2016, 09:35 PM   #4
taibanl
taibanl's Avatar
281
Drives: BMW
Use an open fuse slot with a fuse tap and an inline fuse
