07-18-2016, 03:19 PM | #1 |
BimmerPost Supporting Vendor
3361
Rep 22,756
getBMWparts.com | Dinan F87 M2 Lightweight Anti-Roll Bar Set + FREE Shipping!!!
getBMWparts.com | Dinan F87 M2 Lightweight Anti-Roll Bar Set + FREE Shipping!!! Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Front Anti-Roll Bar: Add a 32mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable from 57% to 103% stiffer than the stock bar. This 4 hole bar can be mounted in 7 different positions with supplied adjustable end links. Benefits:
Rear Anti-Roll Bar: Add a 24mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time.This anti-roll bar is adjustable from 0% to 13% stiffer than the stock bar. This 3 hole bar can be mounted in 3 different positions with stock BMW end links. Benefits:
Shop Dinan Performance Parts Here!!! PM for special forum pricing!!!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! Last edited by Evan@Tischer; 03-24-2021 at 11:20 AM.. |
Tags |
dinan, getbmwparts, roll bar, sway bars, tischer |
