Just installed the BMS intake
03-24-2008, 03:09 PM | #1 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Since Im on a kick of trying different things as long as they arent expensive, I figure why not. I went from the ITG filter to the BMC filter to now the BMS intake. I think I have something for companies that use acronyms.
Regardless, the install was easy. I just have a couple complaints however. First off, you get what you pay for. Obviously this is just a filter with a couple adapters, theres no bullshit. It is what it is and you cant, by any means, assume a lot of R&D went into it. Not for the price that its at. That being said, I would have expected a bit higher level on the manufacturing process. What Im talking about is the two included pipe adapters that fit the filter to the intake hoses. Clearly, the intake hoses are a larger diameter than the included metal pipes. Also, these intake hoses are of a harder plastic, not pliable rubber, thus making a seal on these smaller metal pipes something that Ill have to keep an eye on as I drive. I have a fear I might have to take it apart and put some thickening tape over the ends of the metal pipes to create a better fit and seal. I havent driven it but I started it and revved it a few times. First thing I noticed was a "Thhmpsh" that takes place when the pedal is pushed down. Immediately an identifiable open air intake sound. Then I revved it higher and when letting off you can hear the DV's more too(Could be cus I have the Forge DV's also). Obviously while not under load Im not going to hear the turbos, have to report back on that later. Im going to keep an eye on my boost gauge and see if theres been any changes during normal and spirited driving. The following pictures are the intake installed(which youve seen before, nothing really new here) and I took a shot of the OEM intake with the BMC filter in it. Notice how tight it is between the bottom of the filter and the inside of the box. That being said, the OEM filter comes down even lower(I was too lazy to take a pic of that). So enjoy.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
03-24-2008, 03:32 PM | #2 |
BK Employee of the month! / Moderator
638
Rep 15,795
Take a test drive and let us know what you think.
As always, thanks for the write-up!
Sponsored by: Pics of the ---> Barbera Beast <--- Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America Matt@Camber-Toe (Like them on Facebook Camber-Toe) LuxAngelEyes (Like them on Facebook LuxAngelEyes) LTBMW (Like them on Facebook LTBMW) OEMconcepts (Like them on Facebook OEMconcepts) |
03-24-2008, 03:34 PM | #3 |
384
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
You state that BMS probably did not do a whole lot of R&D into this product of theirs, yet you do a review of the product without driving it, without dyno'ing it, without driving it under load.
I'm glad that you are letting others know of some of the observations that you have with the product, but I'd like to hear the reviews about the product after it has been used. True that there are probably some design issues with this version 1 product, but I wouldn't jump to conclusions just yet, as others did with the other BMS products in the past. However, it is a custom filter made to BMS' specifications. I'm sure those specifications had to come from extensive testing instead of trial and error.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
03-24-2008, 03:41 PM | #4 | |
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
-Mat
Tuned E92 335, Riss Racing downpipes! And hopefully over 400RWHP!! |
03-24-2008, 03:42 PM | #5 |
342
Rep 6,188
Exactly. Thank you for clarifying.
13 HD FatBob
03-24-2008, 05:17 PM | #6 |
Corporate Hack
Rep 288
And if a product does not fit properly, its a sign of a design deficiency. Now that does not mean it wont be corrected, or that it does not make power. Just that the OP adequately supported his statement.
New Car: 2008 335xi Coupe
Earlier Car: 2004 STi (got stolen) Earlier Earlier Car: 1995 Mustang GT (416 whp and a blown engine) Really Much Earlier Car: 1988 Mazda 626 TURBO |
03-24-2008, 05:39 PM | #7 |
342
Rep 6,188
Ok, just went on a little drive.
I cant say if theres any more power gained. I didnt really hit it through all the gears, I was on streets with rush hour traffic. Seemed to pull just the same as before. However, I will say theres definitely more noise under the hood now. When the turbos start spooling, you definitely hear them, and so does anyone else around you with their windows down. The sound is addictive. FWIW, the price is just a bit more than one of the aftermarket panel filters. If the connections show that they are sealing properly and not leaking, then Ill keep it on. I think for the sound alone its worth the price and as long as Im not losing power, Im happy.
13 HD FatBob
03-24-2008, 05:55 PM | #8 |
Rep 5,175
Hyper, I also installed the filter today. Now I have only made 4 pulls on it, so my review is worth nothing at this point. I will have a full write-up in a couple of days. With respect to the install here are just a quick couple of pointers from looking at your install...
It appears you have the filter displaced toward the firewall a whole lot. When I installed the filter, I lifted up on the diverter valves to allow the intake piping to enter the stock intake hose locations much better. It appears the intake piping on the location away from the firewall is not inserted enough into the stock hose location. I have mine inserted at least 1/2" or more into the stock hose location. Since your intake piping is not inserted far into the stock hose, it appears there is bend where the intake piping ends. I had that issue at first. Again, when I lifted up on the diverter valves and inserted the piping farther into the stock intake plastic piping (toward the nose of the car)this made for a much cleaner install. Anyway, I hope this is of use to you. |
03-24-2008, 06:50 PM | #9 |
台妹爱我
14
Rep 323
I just finished installing my BMS Filter. The whole process took me 1 hour.
My Test Drive: pull out of the driveway, put into first gear and throttled 80%. INSTANT POWER LOST ! i was like WTF Switch to second gear, still no pull !! started stepping on brake to slow down. After I stopped the car. MY BRAKES STOPPED FUNCTIONING ! I literally sat on the side of the street and was like oh man i fucked something up. Then I realized I never put the HOSE with the blue oring back in ! so after i pop the hose back in and turned on my engine. The car was back to normal. You can definitely hear the turbo spinning up its abit high pitch, it is not loud, you can only hear it well if your windows are down.
台 客
2003 BMW 330i SOLD 2008 BMW 335i SOLD 2012 Mitsubishi Evolution X Current 2013 BMWX1 xDrive28i Current |
03-24-2008, 08:11 PM | #11 | |
342
Rep 6,188
Did you notice the difference in diameters though? Oh, and if your radio is off, you can definitely hear it with the windows up.
13 HD FatBob
03-24-2008, 08:20 PM | #12 |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
So both turbo inlets draw air from opposite sides of a single filter?
03-24-2008, 08:37 PM | #13 |
Rep 6,608
There is a divider in the middle...
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
03-24-2008, 08:39 PM | #14 |
اوليسيس
198
Rep 4,678
well then that brings another question. How thick is the divider? trying to calculate surface area.
03-24-2008, 08:41 PM | #15 |
Rep 6,608
The surface area of the BMS filter is around 110 square inches, the drop in are around 85 square inches....
03-24-2008, 08:43 PM | #16 |
Rep 6,608
I misspoke....
"This setup provides similar flow to the dual cone setup in bench testing, since both sides equalize its the equivalent to a divider at the mid point" From here: (just information for everyone, not SPAM) http://www.n54tech.com/forums/showthread.php?t=656
03-24-2008, 09:28 PM | #18 |
Rep 6,608
Please look around for discussion on this. It has been had over and over....
03-24-2008, 09:48 PM | #19 |
اوليسيس
198
Rep 4,678
and over .
03-24-2008, 10:10 PM | #21 | |
Rep 4,726
Or are you referring to the stock airbox filters, or maybe one out of two cone filters?
03-24-2008, 10:12 PM | #22 | |
Rep 6,608
