Listening music from USB
07-28-2016, 08:37 AM | #1 |
Rep 135
Drives: 2008 318i 6MT
Hey..
I order from Ebay AUX USB cable for listening music from my USB But after i connect everyting in car it doesnt work at all. Here is the link i found on YB ( its simillar as mine ) Comments in this channel they said that its not possible to work it at that way..is it true? You guys have something simillar that work? |
07-28-2016, 10:08 AM | #3 |
Rep 135
07-28-2016, 10:41 AM | #4 |
160
Rep 305
07-28-2016, 12:14 PM | #5 |
Rep 135
07-28-2016, 01:09 PM | #6 |
Rep 4,121
Ok. Ill be nice but there are multiple problems.
1 there is nothing powering the usb drive 2 you would need to control the usb drive (play/pause skip etc) 3 you also need a digital to analog converter to convert the files into an audio signal for the aux. There are devices which can act as an interface but a plain adapter isnt going to work. |
07-28-2016, 01:31 PM | #7 |
1911
Rep 13,103
kenwood use to make something with a small screen
that would plug into the usb and play music through the aux don't know if the still do . It had an idrive like knob for control. Thought it was the kos 300 or something like that. There are plenty of bluetooth dongles that do strealming music although there quality may vary lot. |
07-29-2016, 05:34 AM | #8 |
Rep 135
so..this will work if i connect mp3 player?
Sorry boys, im not good in those electric stuff and how it works... I tought that its not complicated to use it..control it with steering wheel...but now i see its not possible like that |
07-29-2016, 06:12 AM | #9 |
1911
Rep 13,103
If you want steering wheel controls you need
to retrofit to a mulf-2 high module and program in the 6fl option or use something like the Dension 500s bt gateway or similar mobridge device. You could also retrofit a head unit that has all these features . |
