Hardwiring dashcam and gps tracker with a fuse tap
07-28-2016, 03:06 PM | #1 |
Rep 1
Hi Guys
I'm having trouble hardwiring my dashcam and gps tracker in my 2009 bmw E91, i'm hoping someone on here might be able to help me. I'm using a fuse tap from ebay to add a circuit: I did the same exact thing on another car and there it is working fine but on my BMW it keeps getting power even when the ignition is off. I tapped in to a fuse that should lose power when the ignition is turned off (radio) but it does not. I even locked myself in the car and measured all the fuses when the ignition was off and they ALL have power. I thought maybe it was a timer so i connected everything, locked the car and waited over an hour but still the dashcam was powered on. Can someone explain to me what i'm doing wrong? Thanks for your response! |
07-29-2016, 11:44 AM | #2 |
Rep 2,203
So use a different Fuse location. See if you can use Fuse #5. I unsure if our fuse box is wired differently so do check on the fuse diagram to make sure.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
08-05-2016, 05:00 AM | #3 |
30
Rep 305
Drives: BMW 330i E90
Use the 12v accessory fuse. I have and it works perfectly.
I have a 2006 Pre-LCI E90. Anthony |
