2Addicts
2Addicts
2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Wheels and Tires ► APEX | EC-7 Wheels Now Available!
      07-29-2016, 05:01 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3467
Drives: M3
Thanks for your interest in our EC-7 wheels! This thread has been closed, but the discussion continues on our combined Flow Formed wheel thread at: https://www.2addicts.com/forums/show...3#post25582243
We hope to see you there!
      08-09-2016, 04:30 PM   #2
ApexWheels
ApexWheels's Avatar
1417
Drives: M3
EC-7's look great on this white M235i
Feel free to call or email us with any questions you may have!
      08-11-2016, 06:10 PM   #3
ApexWheels
ApexWheels's Avatar
1417
Drives: M3
Get the most out of your wheel and tire setup! Contact us today with any questions that you may have.
      09-28-2016, 09:58 AM   #4
BPAC306
BPAC306's Avatar
Drives: M240I X
PRODUCT CODE: EC71885ET45AN
Availability: Backorder
18x8.5" ET45 APEX EC-7 Wheel
when will you have 4 of these in stock?
M240i xdrive - K&N Drop in, MPE
12.3 @ 108 Stock
      04-25-2017, 06:38 PM   #5
Expert@ApexWheels
3467
Drives: M3
These wheels are currently available for pre-order! Check them out here!
      05-01-2017, 11:02 AM   #6
BPAC306
BPAC306's Avatar
Drives: M240I X
what is the size rim and tire on the car pictured?
      05-02-2017, 10:38 AM   #7
knoteasy25
Drives: m235 white manual
Pre order when to arrive when ?
      06-01-2017, 01:28 PM   #8
Expert@ApexWheels
3467
Drives: M3
Those are our 18x8.5 ET45 and 18x9.5 ET58 wheels pictured above. We recommend going with 225/40-18 and 255/35-18 tires respectively for a direct fit
Most fitments finishes are now in stock and ready to be shipped out!
-Matt
      07-19-2017, 12:05 PM   #9
Expert@ApexWheels
3467
Drives: M3
EC-7s are the perfect complement to your 2 series.
      07-25-2017, 11:49 AM   #10
Expert@ApexWheels
3467
Drives: M3
Give us a call or email to order, or if you have any questions regarding fitment or clearances.
      08-01-2017, 04:26 PM   #11
Expert@ApexWheels
3467
Drives: M3
Don't hesitate to contact us with any wheel/tire fitment questions.
      08-29-2017, 04:26 PM   #12
Expert@ApexWheels
3467
Drives: M3
Estoril Blue M235i with 18X8.5 ET45 front, 18X9.5 ET58 rear.
      10-04-2017, 05:07 PM   #13
JSCD
Drives: BMW M240i
Spacers?
      10-04-2017, 05:18 PM   #14
Expert@ApexWheels
3467
Drives: M3
Originally Posted by JSCD View Post
Spacers?
Thanks for the post! No spacers required for this setup.
Here are a few more angles:
      01-17-2018, 12:54 PM   #15
Expert@ApexWheels
3467
Drives: M3
TIRES NOW AVAILABLE
  • Michelin Pilot Super Sport
  • Michelin Pilot Sport 4S
  • BF Goodrich g-Force Rival S
  • BF Goodrich g-Force Rival S 1.5
  • BF Goodrich g-Force R1S
View Complete Tire Selection
Add tires to your EC-7 wheels with free in-house professional mounting, balancing, and quality control inspection. Check out our tire selection and feel free to contact us for a recommendation.
      05-09-2018, 01:22 PM   #16
ApexWheels
ApexWheels's Avatar
1417
Drives: M3
Now available due to popular demand, red APEX centercaps! Use this link to check them out and place a pre-order.
      06-14-2018, 06:11 PM   #17
Expert@ApexWheels
3467
Drives: M3
      06-12-2019, 04:05 PM   #18
Expert@ApexWheels
3467
Drives: M3
Strong, light, affordable. Choose three.
      06-16-2019, 09:07 PM   #19
gerry25
gerry25's Avatar
31
Drives: bmw m240i
APEX EC-7 Wheels
APEX is proud to introduce its new EC-7 wheel. This new wheel addresses the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. With the increase of faster and heavier cars being used in racing, HPDEs, and spirited driving, the EC-7 was designed and engineered to handle extreme abuse on track and street, offer a wide range of direct fitments, while still producing a lightweight wheel.
A performance-optimized build begins with the perfect wheel fitment. Without the perfect offsets, maximum tire widths and the potential of your car are always compromised. With this in mind, the EC-7 has three unique face profiles ranging from shallow to deep concavity resulting in 14 unique 18" sizes, and 10 unique 19" sizes. This wide range of fitments allows for vehicle-specific caliper clearance, offsets, and tire widths, creating the most optimal setup possible.
Visit our website to order
The Good Stuff
1. They Fit Everything
The EC-7 adds 7 new BMW sizes not available in the ARC-8 design. The 3 face profiles offer maximum concavity and reduced weight. This avoids the common adaptation of a single face profile for unintended fitments or dependency on spacers.
2. Factory Support
Like all our APEX wheels, The EC-7 supports all OEM hardware like OEM Roundel center caps, wheel lugs, valve stems, and TPMS sensors. No centering rings are needed either, as all of our 5x120 wheels use a 72.56mm center bore.
3. Brake Clearance
If the spokes of a wheel don't clear your brake calipers, then the wheel can't be used at all. We made sure all 18" APEX EC-7 wheels can properly clear OEM steel brakes without spacers. Because of the large variation in clearance needs, we produced the EC-7 wheel using three unique face profiles. When the correct profile is used for each specific vehicle application, all big brake kits can clear the spokes spacer-free, including the Brembo 6-piston 380mm kit.
4. Concavity
Multiple face profiles are utilized to maximize spoke concavity and reduce weight on the EC-7 design. This allows us to maintain our great brake clearance and concave spoke curvature.
Designed for the Performance Enthusiast
Light-weight
Flow-forming allows for a significant reduction in rotational mass by reducing barrel weight. This manufacturing technique allows our wheels to be almost as light as a traditional forged wheel, but without the significant increase in price.
Strength
Track duty requires a wheel that can handle the punishment of high lateral G’s, hitting berms, and every once in a while, a small off track excursion. Spoke and barrel design are a major factor in wheel strength. The flow-forming technique uses high pressure disks/rollers to roll the wheel’s barrel into its final shape. This gives the barrel the same strength properties as a forged wheel, since monoblock wheels go through a similar step to form their barrels. We design our spoke dimensions to help evenly distribute loads from the barrel to the center of the wheel. The lack of a front lip, and spokes directly connecting to the edge of the wheel, also add increased strength to the outer lip of the wheel.
Chassis-Specific Fitments
Stretched rubber, narrow tires, and fender rubbing are not elements to look for in a competitive wheel/tire setup. All of our wheels were designed with offsets that allow for proper fitment of extreme summer, and r-compound tires without the need for spacers or fender rolling. This means keeping the tire under the fender, and away from suspension components. Track oriented wheel widths are also important as they provide proper sidewall support under hard cornering. Too much rubber for a wheel results in excessive sidewall deflection, which translates into sloppy and delayed turning response.
Multiple Fitment Options
Most BMWs come with a staggered setup from the factory. Some choose to keep their car this way, while others like to switch out for an easy-to-rotate, square/neutral setup. This is generally based on driver’s preference and consideration of tire costs. Most BMW chassis benefit from being able to fit both square and staggered setups with relative ease. 9.5” or 10”-wide square setups are great for budget minded enthusiasts who want to extend their tires life by rotating between events, in addition to preferring the feel of a square setup. Square setups are popular on all models for track use due to the significant increase in front grip and turn-in response. Some owners comment that due to the extra power of their cars, a square setup will lean towards oversteer. For those who prefer more rubber in the rear, a staggered setup is the way to go. Wheels up to 11" wide are available for rear fitment. These can be combined with 9.5” or 10” fronts for a bolt-on spacer-free staggered setup.
BBK Clearance
Many owners install Big Brake kits on their cars. Having a smaller-diameter wheel that can clear large calipers is a must. Due to the low-offset nature of many BMWs, there are no clearance issues with the concave spokes. Barrel clearance was increased during the design phase to accommodate both StopTech and Brembo's 380mm kit.
The APEX Standard
1. FEA Optimization
We took more time than ever before on this step, revising and iterating our design to reduce weight as much as possible. After countless iterations we removed material from the sides of the spokes in a way that allowed us to increase strength over our previous designs.
2. Always Flow Formed
All APEX wheels feature Flow-Formed construction that utilizes rotary forging to produce a strong and lightweight barrel. The EC-7 is no exception.
3. True JWL & VIA Certification
Strength needs to be certified. Our wheels were not simply FEA tested in a computer simulation, or in-house tested to an unregulated standard. We conduct real-world crush-testing and all of our wheels conform to Japan’s JWL standard, as well as being 3rd-party tested by the VIA. All of our wheels carry a 690KG load rating.
Available Finishes
Face Profiles
Sizes, Weights, and Pricing
18" Sizes
19" Sizes
Questions about tires, fenders, brakes, spacers, or suspension clearances?
Click here to get a personalized fitment recommendation from one of our experts.
On-Car Photos
Shown above: E46 M3 with 19x9" ET35 and 19x10.5" ET22 in Anthracite with 245/35/19 and 275/35/19 tires.
Shown above: E92 335i with 18x9" ET31 and 18x10" ET33 in Race Silver with 255/35/18 and 265/35/18 tires.
Shown above: F82 M4 with 18x10" ET33 in Satin Black with 285/35/18 tires all around.
Check out our extensive collection of photos on our Flickr page. See more EC-7 photos >>>
Tire Mounting and Balancing Service
Popular street and track tires are now available when you order APEX wheels. Add tires with your wheel order and get free tire mounting and balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. With our competitive tire pricing bundled with the savings of free mounting and balancing and convenience, it’s the ultimate wheel & tire package.
*Note: Tires will only ship mounted to the wheels in your order, and can not be sold separately. Tires and wheels must be purchased in the same transaction. Tire-only orders will be cancelled and refunded.
Available Tire Brands:
Ordering and Contact Information
  • Hours: Monday - Friday, 9AM to 6PM PST
  • Shipping: All orders are shipped directly from us via UPS. Local pickup also available at our Livermore, CA Warehouse. (Map It)
hi
can i mill 2mm the pancake of my ac7 wheels to increase offset?
thanks
      06-17-2019, 12:14 PM   #20
Expert@ApexWheels
3467
Drives: M3
Originally Posted by gerry25 View Post
hi
thanks
Thanks for the post! We do not recommend modifying the wheels in any way. Milling the mating surface alters the strength around the mounting pad, which is one of the most stressed parts of the wheel face. If you're looking to achieve a specific offset, feel free to reach out to us via email or PM as we may be able to find a solution that will work for you.
--Dylan
      10-17-2019, 09:44 PM   #21
235Dude
Drives: 2016 M235i
19x8.5et35 225/35/19
19x9.5et43 255/30/19
M Performance Springs (10mm)
No spacers, no camber adjustments, no rubbing!
      11-21-2019, 07:38 AM   #22
calcamonias
Drives: M235I
Hello, i want to instal 8,5x18 ET 35 font and 9,5x18 ET43 rear. I have stock suspension. Can i instal Apex EC7 in my M235I??
Thanks for all.
2addicts
