08-09-2016, 07:53 AM | #1 |
Rep 61
Rear Differential Initial Fluid change
For those that know:
2015 M235i Coupe. Manufactured 06/2015. Purchased new 03/2016 (was the dealer's demo) Current Mileage 5,300 Open Rear Differential Question: Should I change the differential fluid now, considering it the initial change or just wait till I reach 30,000 miles? Thanks! |
08-09-2016, 05:19 PM | #4 |
Rep 24
Drain plug.
Open differential applies the same amount of torque to each wheel. Limited slip differential allows more torque to be transferred to the non-slipping wheel. |
08-09-2016, 07:38 PM | #5 |
Rep 5,538
08-10-2016, 04:06 AM | #8 |
Rep 886
I think it's more likely you misunderstood he was making a joke.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
08-10-2016, 09:06 AM | #9 | |
Rep 580
08-10-2016, 11:14 AM | #11 |
Rep 886
More typically, transmission fluid at 50k (ZF's recommendation IIRC), up to 100k (BMW's recommendation). After that, you find yourself in the midst of the "Change it! / No, never after 100k if the first time!" debate.
08-10-2016, 12:11 PM | #12 |
Rep 5,538
I've got 60k on my Lexus and neither tranny or diff have been serviced. Both filled what they claim a lifetime fluids and tranny is not even serviceable, drain plug only drains 30% of fluid. Debating doing at least that 30% and maybe diff at next service.....will cost about $400 bucks and not even sure if its worth it
08-10-2016, 03:33 PM | #13 | |
Rep 61
https://www.bavauto.com/Assets/inst_pages/e90mc.pdf |
Tpeterson156.50 |
08-11-2016, 04:29 PM | #14 | |
Rep 580
