BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Free Download Rheingold 3.55.11 ISTA-P 3.58.3.003 torrent
      08-18-2016, 01:40 AM   #1
JackF
JackF's Avatar
Drives: lamborghini
BMW software is offered here to free download, to work with INPA cable or BMW ICOM A2 for BMW diagnosis and programming.
Free download
Rheingold 3.55.11 Standalone ISTA-P 3.58.3.003 torrent (being tested)
ISTA-D 3.54.12 ISTA-P 3.58.0.500 Software (tested, cracked)
Standalone versions of ISTA-D and ISTA-P.
SQLiteDBs 3.55.14, including EN, DE, RU, OTHER.
Workable device:
BMW K+dcan inpa cable
ICOM A2 emulator
Rheingold 3.55.11 ISTA P
For unpack archives use 7-zip 15.12 or Winrar 5.30 and higher ( unblock archives if needed ).
Install:
Ediabas, Java, vcredist 2010 x86 x64, vcredist 2013 x86 x64, vs90_piaredist, net framework 4.5.2 or higher.
Rheingold :
Unpack, for examle in D:Rheingold, unpack and copy SQLiteDBs in RheingoldSQLiteDBs, run RCleanerV4.3.exe from Tools folder.
Apply ISTA-D Reg Fix for your system (x86 or x64) from Tools folder.
Run D:RheingoldTesterGUIbinReleaseISTAGUI.exe.
If ask license, enter it from License.txt file. Enter 1 in ISIS field, ignore error and press ok.
ISTA-P :
Install Networktool.exe, for K-DCAN cable. (ICOM doesn’t need it).
Unpack in the root of any drive, for example D:ISTA-P.
Run BMW ISTA-P Loader V4.9.exe from Tools folder.
Choose language, resolution and expert mode options. Ignore message about resolution.
More information please donwnload file
Appreciate 3
      08-22-2016, 03:39 AM   #2
JackF
JackF's Avatar
Drives: lamborghini
How to update ICOM A A2 firmware for Rheingold 2015.11
The latest BMW ICOM A1/ A2 software Rheingold 2015.11 has been released. So what do you do for the new ICOM software? Update your ICOM firmware!! That is, users with ICOM A A2 2015.11 should update firmware system image to version 01.25.02 & application image to version 1.40.05.
Here is the ICOM firmware update instruction.
Note: please free download firmware update files first!
ICOM-ApplicationImage-01-40-05.bin
ICOM-BootImage-01-25-02.bin
1 Connect ICOM A1 / ICOM A2 to PC via wired network connection.
Connect ICOM A1 / ICOM A2 emulator to the vehicle or power on the emulator via 12V power adapter.
2 Open Internet Explorer
for icom a1/a2 common version, go to
User name: root
Password: NZY11502
for icom a2 super version, go to 
User name: root
Password: NZY1150263
http://blog.wobd2.com/2016/01/05/how...ngold-2015-11/
3 Click "Update Firmware", to get the ICOM firmware version.
4 Select file “ICOM-BootImage-01-25-02.bin”, to set image type as SYSTEM, then click "Send the file".
5 Prompt: Write the image file to the flash?
Select Yes, and the light on ICOM mux will turn red.
6 Prompt: The SYSTEM IMAGE update was successful.
Click "Update Firmware".
7 Select file “ICOM-ApplicationImage-01-40-05.bin”, to set image type as APPLICATION, and then click "Send the file".
(several minutes needed)
8 Prompt: Write the image file to the flash?
Select Yes, and the light on ICOM mux will turn red for the second time.
9 When all is ok, click "reboot".
Ps. the ICOM firmware version display
icom-firmware-update
NOTE: change the local network connection, that is, set automatically obtain local network connection
Two update files are available. Use the small-size first, then the big-size.
When using the small-size file, select SYSTEM.
When using the big-size file, select APPLICATION.
      08-24-2016, 01:12 PM   #3
dpaul
Drives: 2009 E90 335xi, 2011 E93 M3
Thanks for the download links - however, I didn't find licence.txt or RCleanerV4.3.exe in the download. Could you provide them?
Edit: Oops. There they are!! Duh!
      08-24-2016, 10:26 PM   #4
JackF
JackF's Avatar
Drives: lamborghini
Hi did you found it ?
      08-25-2016, 06:21 AM   #5
dpaul
Sorry - yes, I found the files and installed ISTA-D, which works fine. Thanks!
      10-04-2016, 11:27 AM   #6
2010e92
Drives: e92
i could not find the links for downloads can you please post them.
Thanks in advance.
      10-18-2016, 10:02 PM   #7
JackF
JackF's Avatar
Drives: lamborghini
HI You can find the text to download
Thanks in advance.
      10-19-2016, 12:20 PM   #8
ctuna
1911
Drives: 325xi 06 wagon MT
Why are you dropping this thread here instead
of on the coding subforum?
      12-11-2016, 01:49 AM   #9
Sti581
Sti581's Avatar
Drives: 2017 F80 ZCP 6MT M3
Sorry for the newbie question. But essentially I wouldn't need to buy anything but the cables from rheingold? I just bought there ista d kit with the kdcan cable, e net cable and ista d software on that jump drive. So I assume I can just download the ista p software for free and not bother buying ista p from them?
Sorry for the retarded questions,but this is all new to me...
      12-11-2016, 04:03 AM   #10
ctuna
1911
You can buy the cables in a number of places.
The links to the better ones are in the coding subforum sections.
The setups to quite a few different programs can be found
on the coding subform here and other coding websites and car
tech websites. The one stop cable is often quoted as being the best
on the local coding subforum here.
Some claim you actually need a icom cable for some stuff
I have ista d and Inpa, edibas ncsexpert running on simple k can cable because its an 06 car.
see
http://www.e90post.com/forums/forumdisplay.php?f=368
      12-11-2016, 02:46 PM   #11
Sti581
Sti581's Avatar
Hey thanks for the info. I have the cables from Rhiengold and bought ista/d. However my question remains unanswered. Can I just download ista/p above for free instead of buying it from rhiendgold?
      12-11-2016, 04:07 PM   #12
ctuna
1911
You can if it doesn't bother you to do that sort of thing
and you can get the coding software to .
Go to the coding sub forum.
      12-11-2016, 04:34 PM   #13
Sti581
Sti581's Avatar
Well it's the same software as eyeing old ista/p isn't it? Heck idiots free why not. As long as there is no difference.....I thought ista/p is the coding software.... Ah too much to learn. I've been under the coding page and reading.
      12-11-2016, 05:57 PM   #14
ctuna
1911
You have to keep the daten files and the database uptodate
if you want the latest stuff. They at least should be at or exceed
the current i-level of your car.
      12-11-2016, 06:26 PM   #15
Sti581
Sti581's Avatar
Thanks for your help. It sounds like it's going to save me an additional $100 for ista/p vs. having to buy it from rhiengold.
It is a lot to learn and the coding section does not offer once concise location for beginners in diagnostics and coding/programming. I wish there was clarity since it seems like there are a lot of platforms and termonolgy to learn!
      12-11-2016, 07:27 PM   #16
ctuna
1911
Also if you are going to update the car you need a large
regulated power supply to keep it on during the process.
I don't see the need to really update it as the changes in
software tend to be small ones.
      12-11-2016, 07:39 PM   #17
Sti581
Sti581's Avatar
Thanks for that info. I did see that when searching around. Makes sense. These things can consume some power. Luckily I bought a battery tender for the winter. I'll just make sure it's all plugged in and had the battery completely charged before I go in and perform my settings. This will sure be a steep learning curve on how to use the software too. But it'll be worth it once I get it down. Thank you again for all of your insight.
      12-11-2016, 08:13 PM   #18
ctuna
1911
I think its pretty simple with ista p its designed to be
simple but it can take several hours and there have been warnings
the current draw is significant. They are specifying a 50amp regulated
supply to do this.
      12-19-2016, 01:35 AM   #19
Juss1
Drives: E91 LCI 330d
Error
Hi,
Im getting this error after running ISTAGUI.exe:
The connection to one of the required databases could not be established. Please check DSS #00046632EN for further trouble shooting.
Does it require network connection?
EDIT: so I understand that this is not important at all.
But I have another problem: I get fault codes and milage but no descriptions. Should there be descriptions for the fault codes?
Thanks!
      12-22-2016, 01:27 AM   #20
bacon33
Drives: 335i
What does this do?
      05-05-2017, 05:57 PM   #21
rkstar9
75
Drives: '10 X5 3.5D
anyone have a new link for this ? links appear to be dead.
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune
      09-03-2017, 12:39 PM   #22
david in germany
729
Drives: 118i, 335i and 328i
in for later
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
