08-29-2016, 05:12 AM | #1 |
Rep 25
Which Stage 1 to get for my 16 M235i xDrive CV
I just bought a 2016 M235i xDrive CV (8 Speed) 1 day old =D
I read through many post including the In-Depth Guide to Tuning your M235i, However, I am unable to find my answer, as many of the mod seems to lead toward other upgrades. All I really want is to do a 1 time Mod that won't void my warranty, and I am ok with removing the cabling each time I go to the dealership if necessary. I don't plan on doing any other additional mod, so no intake, no DP, etc. Suggestions please? |
08-29-2016, 08:30 AM | #2 |
Rep 1,184
It sounds like the new tune burger running just released would be right up your alley. It's plug and play and if you do not plan on doing other mods it probably one of your best options.
A lot of other people like the A8 active Autowerks tune and the race chip ultimate. |
08-29-2016, 11:22 AM | #3 |
Rep 447
If ease of install is important then the new 1 plug solutions from either BMS or Dinan are cheap and 2 minute installs.
Next up will be 2 plug solutions, these take 5 minutes to install and may offer a slightly smoother power curve and a little more power as they are impacting additional stuff. These range from the BMS stage 1, AFE Scorcher, RaceChip Ultimate (this is in order of price) I've used both BMS stage 1 and RC Ultimate and found the RC Ultimate to be a little better in drivability. Next is stage 1.5 as they connect to the same 2 plugs as the stage 1, but add the camshaft sensor to control boost by RPM. This will be AA8 and RaceChip Ultimate w/Bluetooth. I currently run the AA8 and find it better than both stage 1's I've run in terms of power and delivery; it's also waterproof and mounts to a factory bolt for clean install. Finally, JB4 has additional sensors for EWG and flexfuel if you want to run some E85. It also plugs into the OBD port which I think is what allows you to change maps through the steering wheel. This will be longest install of the bunch, probably 45 minutes to hour first time and 20 minutes after you know what you're doing. This will give the most power with mods. If you aren't going to add any mods or run some E85, then you won't yield the benefits of this more advanced tune, so stick with the easier install options. There is no 1 tune for a definitive answer, they all work and give you more power. The Dinan is $100 more than the BMS 1 plug solution, but allows map switching via your phone, while I think the BMS you turn a dial inside the box.
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
08-29-2016, 01:20 PM | #4 | |
Rep 25
1> Is both the Stage 1 and Stage 1.5 Plug-in undetectable by the dealer if it's removed before taking the car in? 2> Do they throw out CEL? 3> How does it affect the ECO > SPORT+ mode? Or/and the M/S setting? Thanks |
08-29-2016, 05:34 PM | #5 | |
Rep 447
The higher the boost, the better chance you'll throw a code, so I'd stick to the stock settings on the 2 plug tunes as I know the AA8 I've got pushes over 5.5 extra psi of boost at some levels of the RPM range while the 2 plug tunes seem to be closer to 3-4 psi. I've gotten 1 CEL in 2 years and this was when car wasn't fully warmed up, deleted it with a cheap code reader and have had my electric fan replaced and no issues with warranty. The extra cam sensor plug is tricky to get to of the 1.5 stage tunes if you have big hands. Once you've figured out how to disconnect it, I find it easy, but others think it's a pain in the butt, so beware if you aren't mechanically inclined or good working with small spaces. The tunes have no impact at all on eco/sport m/s modes. All they are doing is upping the boost while using the BMW power band, just higher at every level. Of course comfort will feel more powerful/responsive vs prior to the tune because you're pushing more boost/power. JB stage 1 is by far the most used 2 plug tune for BMWs. You can adjust boost up/down a bit depending on what works best for your car and the quality of gas you are using. Stock setting I think it's 4 psi boost increase. Good luck
08-29-2016, 06:41 PM | #6 | |
Rep 780
Drives: 13 GT50014 AW M235i(sold)
When people say stage one is that also including the Jb+ as well? I'm in a similar boat as OP in that I'm trying to figure out pros and cons between JB+ and stage 1 and the info is conflicting a lot of the time |
08-29-2016, 08:25 PM | #7 |
Rep 5,103
The new Dinan Sport Tune is pretty decent for the money. I installed it on my N20 X3 and it's been really great. Installed in less than a minute. it's also available for the 235 N55. $300.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
08-29-2016, 08:45 PM | #8 |
Joint Chiefs of Staff
24186
Rep 190,777
Get the Jb stage 1 Harness B ... Check the vendor section some vendors including us offer it with a 14 days money back guarantee
You can also try the JB+ , it might not make as much power as the stage 1 but the increase is very noticeable, you can also adjust boost for more power and it comes at an unbeatable price
Jadar1752.50 |
08-29-2016, 09:39 PM | #9 |
Rep 439
You wont find anything that has a warranty like Dinan, you get what you pay for. I would never put a cheap 14 day warranty product in my car.
2016 ///M235ix | MP Grilles | MP Pedals | Gloss Black M235i Badge | Dinan CAI | Dinan tune | Dinmann CF Diffuser | MP CF Spoiler | CF mirrors | M2 CF interior | M2 Steering wheel
BMWZ41909.50 |
08-29-2016, 10:47 PM | #10 | |
Rep 25
http://www.dinancars.com/product/d44...ries&mid=1235/ |
08-30-2016, 09:49 AM | #11 | |
3441
Rep 79,211
The BMS Tuning products offer a 1 year warranty on the product itself. Dinan has it's benefits but other tunes have their place too. |
Alfonso235i130.00 |
08-30-2016, 10:03 AM | #12 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Their car with the jb4 and meth made 458rwhp. I can't even touch that with my stage 1 turbo upgrade on my n55..
FBO-PS1 and stuff
08-30-2016, 10:05 AM | #13 | ||
Dejan
1753
Rep 4,197
Dinan is garbage and a rip off.
FBO-PS1 and stuff
Alfonso235i130.00 Luminous743.00 |
08-30-2016, 10:08 AM | #14 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
08-30-2016, 10:32 AM | #15 | |
24186
Rep 190,777
the actual warranty is 1 year + unlimited support and free upgrades.
08-30-2016, 11:55 AM | #16 |
Rep 439
My opinion is all your cheap mods are garbage products. I wouldn't put jb4 in my car for free.
08-30-2016, 12:25 PM | #17 | |
Dejan
1753
Rep 4,197
Feel free to sit in the slowest corner of any performance realm and pay $3000 grand for your +3 psi Dinan is a has been and is hangin on by false claim of a thing called warranty that does not honor. Use the search button and see for yourself how great they are at honoring it. The funny thing is you say you wouldn't use jb4 for free and it's exactly what Dinan did with their system is tap into map and t map and wrap a pretty wire loom cover on it with a pretty box to house the board, and charge you $3,000. But yeah Dinan is great it offers so much I've installed it, uninstalled it, it's nothing more that a terrible copy of jb4... I guess we're on the same page but opposite i wouldn't use the dinatronics for free. More drivetrain errors per piggyback guaranteed m, have fun w that. And I'm flash tuned jb4 is an added bonus.
FBO-PS1 and stuff
Luminous743.00 |
08-30-2016, 12:28 PM | #18 | |
Rep 439
08-30-2016, 12:34 PM | #19 | ||
Dejan
1753
Rep 4,197
I'll stick to my dumpster low rent mods especially my pure turbo upgrade its so incredibly low rent I don't know how I can live with myself.
FBO-PS1 and stuff
crbalch472.50 |
08-30-2016, 12:38 PM | #20 |
Rep 439
As I said, I'm happy to hear that you're happy with your cheap garbage tune and mods! As long as you're happy that's all that counts!
08-30-2016, 12:40 PM | #21 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
08-30-2016, 12:44 PM | #22 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
