Passenger side speaker static
09-01-2016, 12:07 PM | #1 |
95
Rep 318
Hey guys! The Passenger side speaker is making static noises when the door is opened and closed, as well as over bumps and it persists for awhile after. I was just wondering, is there a way to just unplug it entirely? I dont use my sound system much, so I wouldnt mind one speaker not making sound.
09-02-2016, 01:53 PM | #3 |
1911
Rep 13,103
If you were going to unplug it
If you were going to unplug it you might as well fix it.
Because both would involve taking off the door panel. And this is not such a hard thing to do if you are reasonably mechanical and coordinated and can do things in order. If you have the Hi Fi system you can unpug the amplifier plug by throwing a lever and pulling the connector out of the socket. You will have no sound after that though. Install procedures http://www.e90post.com/forums/showth...ght=door+wires http://www.e90post.com/forums/showthread.php?t=911595 http://www.e90post.com/forums/showpo...9&postcount=19 http://www.e90post.com/forums/showthread.php?t=571803 http://www.e90post.com/forums/showth...ht=amp+install http://www.bimmerdiy.com/dir/e90 http://www.e90post.com/forums/showth...DIY+door+panel http://www.e90post.com/forums/showthread.php?t=553388 http://www.e90post.com/forums/showth...hlight=speaker http://www.e90post.com/forums/showthread.php?t=635672 |
09-02-2016, 09:11 PM | #4 | |
95
Rep 318
09-02-2016, 09:39 PM | #5 |
95
Rep 318
Just a quick question thats probably dumb...im trying to get that connector off with all the wires but i cant seem to remove it...how does it unplug?
09-02-2016, 10:54 PM | #6 |
1911
Rep 13,103
It has a lever that you throw
after you throw it , it will come out with very little force . When you throw the lever it comes out halfway anyway. Push on the lever from both sides. The lever goes all the way across the top and has two sides plus a cross piece it has about a 90 degree throw. Last edited by ctuna; 09-02-2016 at 11:15 PM.. |
09-03-2016, 09:41 AM | #7 | |
95
Rep 318
09-03-2016, 11:58 AM | #8 |
1911
Rep 13,103
What you didn't do is read carefully
What you didn't do is read carefully because I mentioned
in the post when I first talked about the connector. |
09-03-2016, 06:20 PM | #9 | |
95
Rep 318
