2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Maintenance Intervals
      09-05-2016, 07:42 AM   #1
123Britt
Drives: 15 M235i AT
What do you think about these for N55: Making it Last a LIFETIME
Water Pump: 60K
Coolant : 60K
Oil : 5k (Pennzoil PP 5W-40)
AT Tranny: 50k
Diff: 50k
Brake Fluid: 24k or 2 yrs
Plugs: 50k
Air Filter: 24K
Shell 93: Always
      09-05-2016, 08:12 AM   #2
Beartato
Beartato's Avatar
882
Drives: M235i
Looks solid, how does it compare to the recommended maintenance intervals? I'm just following BMW's maintenance intervals.
      09-05-2016, 09:51 AM   #3
jpnh
jpnh's Avatar
1424
Drives: NA
Whats the advantage to changing the water pump on one of these engines at 60k?
The 235 has an electric pump so the consequences of failure are a simple CEL/Temp light on the dash indicating its time to do something
The 240 has a mechanical water pump and a separate electric one for the turbo
But none of these carry the expensive/catastrophic consequences of failure that most any VAG engine carries with a timing belt driven water pump on an interference engine
Which raises a second question.....I know its a timing chain engine but is it an interference or non interference engine?
      09-05-2016, 11:39 AM   #4
123Britt
Drives: 15 M235i AT
Trend Data
WP failure rates on the N55 have show post 60k would be a good time to R&R on your time rather that at the most inconvenient event.
Think I change my N54 around 70k.
Belt drive WP on B58 -- I am not sold.
amw896582.50
      09-05-2016, 01:27 PM   #5
123Britt
Drives: 15 M235i AT
Bavauto Finding:
The BMW N-series 6-cylinder engines (N51, N52, N54 and N55 in the US) no longer employ an engine driven water pump. These engines are designed with an electrically driven water pump that is mounted as an accessory to the engine. This allows the engine management system to fully control and modulate the coolant flow through the engine, rather than being a result of engine RPM (Revolutions Per Minute, or speed). While this design surely has advantages in engine efficiency, power production and emissions, the pumps themselves have been showing failures in the 50,000 mile and up range.
Typically, as the water pump is failing, the engine management system will begin to reduce engine power due to the reduced cooling capabilities. Eventually, the engine will go into a safe mode and only allow idling and low RPM function.
      09-05-2016, 01:33 PM   #6
overcoil
Drives: M235i 6spd
Anyone think coolant changes every two years makes good sense ?
      09-05-2016, 03:00 PM   #7
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
I'm surprised at the AT fluid change at 50k. Is that normal for beemers? I typically change AT fluid around 100k in my previous cars. And brake fluid change every 24k miles? I've never fully changed brake fluid on any car, just added what was needed to bleed the brakes for new calipers.
Would appreciate some insight from you seasoned folks
      09-05-2016, 03:22 PM   #8
123Britt
Drives: 15 M235i AT
LONG READ - Intense
written by Mike Miller, BMW Roundel Tech editor
Real BMW Service Intervals: Alternative BMW Maintenance Schedule
BMW’s Free Scheduled Maintenance program means that BMW will perform scheduled maintenance free of charge during the BMW New Vehicle Limited Warranty period.
Prior to the advent of BMW Free Scheduled Maintenance, approximate BMW maintenance recommendations were: automatic transmission fluid (ATF) and filter changes every 15,000 miles, manual gearbox and differential oil changes every 30,000 miles, annual brake fluid changes, and coolant changes every two years. Spark plugs, air filter, and fuel filters were typically replaced every 30,000 miles on most BMWs (this is a tune-up) except M cars up to 1995, which got new spark plugs and a valve adjustment every 15,000. Later advances in computer engine management and spark plug technology legitimately allow 60,000-mile spark plug life if not more.
Prior to Free Scheduled Maintenance, you couldn’t change engine oil often enough according to most dealerships. And when the car was in the shop it would often be due for this service or that inspection, all at the owner’s expense.
But once BMW began paying for scheduled maintenance, lo and behold the “schedule” was revised. Now, magically, the cars hardly need any maintenance at all! The 1,200-mile break-in service was done away with except for M cars. Engine oil suddenly lasts 15,000 miles (dealers are supposed to use BMW synthetic oil). Manual gearbox and differential oil? No worries there – now BMW says they NEVER need to be changed, it’s “lifetime fill.” Brake fluid and coolant service intervals were doubled with no change in the original BMW brake fluid and anti-freeze dealers are supposed to use.
So, is Free Scheduled Maintenance all about marketing and cost reduction – BMW’s costs? Draw your own conclusions. There is no doubt that many buyers incorrectly view BMWs as “high maintenance” cars. Nothing can address that more effectively than Free Scheduled Maintenance. But the operative word in the name is “scheduled.” In my opinion, extended service intervals and “lifetime fill” came very close on the heels of Free Scheduled Maintenance.
This is an alternative to BMW’s factory-recommended maintenance schedule. It is not, “Mike Miller’s maintenance schedule.” It is actually BMW’s maintenance schedule, more or less, which was used prior to Free Scheduled Maintenance. It also represents my opinion, based upon my experience and that of my readers, tech advisors, and professional BMW technicians both dealer and independent. I have prepared it because of the large number of readers asking for this information. The fact that my opinions may differ from those of others does not mean anyone is necessarily right or wrong. You will get a different answer from every person you ask about routine vehicle maintenance.
You should also know that in my work I have observed the most common reason for BMW drivability problems in contemporary cars with over 100,000 miles is that they need a tune up – spark plugs, air filter, and fuel filter.
Break-in Service for New Cars
Traditionally, BMW performed a break-in service at 1,200 miles on new cars, which included changing the engine oil and filter, manual gearbox oil or automatic transmission fluid, and differential oil. With the advent of Free Scheduled Maintenance, BMW stopped performing break-in services except on M cars.
I have seen that the engine and drive-line oils in new modern BMWs are literally full of metal at 1,200 miles – as has always been the case with any new car. For this reason, I recommend a 1,200-mile break-in service.
Engine
Oil and Filter Intervals
BMW recommends their Castrol 5W-30 synthetic motor oil in all BMWs except contemporary M cars, for which they recommend their Castrol 10W-60 synthetic motor oil. The factory oil change interval is controlled electronically, but is presently about every 15,000 miles. If you are running BMW’s oil, I recommend an oil and filter change interval between 5,000 and 7,500 miles.
I use Red Line synthetic oil (www.redlineoil.com) in 5W-30, 10W-40, 15W-50, or 20W-50, depending on factory recommendation, ambient temperatures, and severity of service (track use, sustained high rpm use), with a drain interval – 7,500 to 18,000 miles depending on engine and severity of service. Under racing or track conditions I’d use a short interval; same for carbureted engines which tend to get some fuel into the oil. I would run the same intervals with very high end synthetics such as Amsoil and Lubrication Engineers Monolec Ultra.
All other commercially available synthetic oils, 5,000-7,500-mile drain intervals (Mobil-1 is good, we don’t know much about the factory BMW Castrol product).
Old fashioned petroleum oil, same viscosities, 3,000-to-5,000 mile drain intervals (I prefer Kendall)
The following information is courtesy of Motorwatch.com:
“Redline is Group V (polyol ester) based (POE or esters).
“Amsoil and Mobil-1 are Group IV (poly-alpha olefin) based (PAO or synthesized hydrocarbons SHC).
“Castrol Syntec and all the others calling themselves synthetic are Group III (hydrocracked slack wax).
“The petroleum motor alls are all mineral oil based and make up Group II.
”We really should group Red Line by itself, and put the others in separate categories (according to the groups) because their performance is so different.
”See motorwatch>AutoMotiveBible>Oil Change Intervals>oil classifications
http://www.motorwatch.com/images/oilclassifications.jpg
”AutoMotiveBible> Oil Change Intervals>oil change intervals
http://www.motorwatch.com/images/oil...intervals.jpg”
Original BMW filters are recommended for price and quality, or MANN, Mahle, Bosch, or Knecht filters
Spark Plugs
There is no reason to deviate from the factory-recommended Bosch or NGK spark plug specification, changed at 30,000-to-60,000-mile intervals, depending upon the car and severity of service. Basically, any BMW produced after 1993 can easily run 60,000 miles on a set of spark plugs.
The factory also has part numbers and applications for “100,000-mile spark plugs.” These are good too, and are capable of 100,000 miles of service assuming no other problems, which might cause them to foul during that time. However, in engines with spark plugs recessed into the middle of the cylinder head, oil can leak into the spark plug recesses past the valve cover gaskets. This is a hidden leak if the plugs are left in service for an extended period of time, because no one looks in there until they’re changing the plugs or chasing a problem. An oil leak in the spark plug recesses, left to fester, can cause ignition coil failure and even ECU failure. So, even if you want to leave the plugs in service, you should at least check the spark plug recesses for signs of oil leakage at least every 60,000 miles. And at the point you’re in there, you might as well replace the plugs. This is the issue with 100,000-mile plugs.
Moreover, while you may not have any problems running spark plugs for 100,000 miles in some BMWs, this does not mean the plugs will not be worn, or that that wear is not affecting engine performance. In other words, for optimum engine performance, most BMWs want spark plugs every 30,000-to-60,000 miles. M cars except the US specification S50/S52 powered E36 variants want plugs about every 15,000 miles.
Stay away from platinum plugs in BMWs. These don’t last as long as the regular Bosch copper or silver plugs and NGK plus, and have been known to fail in other ways. The regular old Bosch Platinum single electrode plug is, however, a very good choice for cars OTHER THAN BMWs.
Air Filter
Stock paper element, check every 15,000 miles, tap out dirt, replace if necessary, standard interval 30,000 miles, use Original BMW filters or aftermarket filters such as Knecht, MANN, Mahle, or Bosch
K&N oiled cotton gauze filters, clean every 15,000 to 30,000 miles depending on condition, use only K&N approved cleaner and oil, and follow K&N cleaning procedures
Fuel Filter
Replace every 30,000 miles, also replace if fuel pump is replaced, use original BMW filters or Bosch, Knecht, MANN, or Mahle.
Valve Adjustment
Perform every 15,000 to 20,000 miles where applicable
Timing Belt, Tensioner Pulley, and Front Cam Seal
Replace every 5 years or 50,000 miles on vehicles so equipped, water pump replacement also recommended as preventative attendant service, but not required, 40,000 miles or four years on the E30 325iX (1988-1991)
Engine Drive Belts
Replace O.E. or O.E.M. BMW poly-ribbed serpentine belts every 60,000 miles
Replace O.E.M. Continental or Pirelli or original BMW V-belts every 30,000 miles
Replace “auto store” quality V-belts every 15,000 miles
Engine Coolant Service
I recommend changing engine coolant at two-year intervals, using only factory BMW anti-freeze mixed 50-50 with distilled water (reason – BMW anti-freeze is phosphate free, phosphates cause aluminum oxidation, which blocks cylinder head coolant passages and causes head gasket failure, others may claim to be “aluminum safe” or “phosphate free” – make your choice, but I’ve used BMW anti-freeze exclusively in many cars and have never had an aluminum oxidation or head gasket problem)
The factory coolant change interval used to be every two years. It is now every four years.
Water and Fuel Hoses
Replace water and fuel hoses every 150,000 miles, highly recommended use of O.E. or O.E.M. hoses only, along with the original hose clamps or Wurth/Zebra replacements. The original BMW hose clamps are far superior to anything you’ll find in a U.S. auto store.
Power Steering Fluid
Replace every 30,000 miles. This is a very neglected operating fluid. Almost all BMWs use automatic transmission fluid in the power steering system, except for some E32 7 Series cars, which use Pentosin hydraulic oil. Nothing will balls up the works faster than using one when you should be using the other. Check the sticker on the reservoir, check the owner’s manual, and if you are still confused, take the car to a pro or e-mail me.
It is not necessary to evacuate the entire power steering system. I just open a line down by the pump.
I have had great experience using Red Line Synthetic Power Steering Fluid – 184,000 miles and counting on the original rack and pinion unit and pump on the vehicle I used to test this product. But I would not use it in place of Pentosin hydraulic oil where that product is specified.
Manual Gearbox Oil
Only synthetic oil should be used in BMW manual gearboxes, drain interval 30,000 miles
Red Line products are highly recommended (www.redlineoil.com). Questions or problems, e-mail me or dave@redlineoil.com.
All the BMW gearbox re-builders I know use Red Line MTL exclusively, regardless of model year or gearbox. The general consensus is, MTL is the better lubricant. However, the D4ATF product will require less shifter babying during cold operation. I use Red Line MTL in manual gearboxes except where I can’t trust the driver to shift properly when the gearbox is cold, in which case I use Red Line D4 ATF.
Automatic Transmission Fluid (ATF) and Filter
For older automatics using Red Line or other synthetic ATF, drain interval 30,000 miles. Old fashioned petroleum ATF, drain interval 15,000 miles
At various production dates in the mid-1990s, which vary according to model, BMW switched to their so-called “lifetime fill” ATF in automatic transmissions, as well as manual gearbox lubricant and differential oil. The reason for this, as far as anyone can tell, is marketing and not engineering – the idea being to foster the notion of the low-maintenance BMW.
There was no explanation of what “lifetime” meant, i.e., lifetime of the car, the component, or for that matter the driver. If it was the component, then obviously anything could be “lifetime fill”. The factory’s initial position is that these lubricants never need to be changed. Then, some time later, it came out that “lifetime” means 100,000 miles. Many dealerships are now recommending manual gearbox and differential oil changes be done at customer expense every 60,000 miles. Every independent BMW technician I know recommends a 30,000-mile interval, and many recommend Red Line synthetic oils (www.redlineoil.com), but not for automatics with “lifetime fill.”
Older automatic transmission models, which do not have “lifetime fill” should have ATF and filter services every 15,000 miles if using petroleum ATF; every 30,000 miles with synthetic.
However, the modern automatic transmissions are different. No one knows exactly what BMW’s proprietary ATF is, so no one knows if there are viable alternatives. We do know that BMW dealerships charge about $500 for an ATF and filter service, due to the price of the ATF. And that’s assuming you can get them to do the job, which is not often the case.
Under no circumstances would I recommend draining any previously unmaintained automatic transmission with much more than 50,000 miles. I have seen it happen too many times, where a well-meaning owner or technician performs an ATF and filter service on a neglected but well-shifting automatic, and then all of the sudden it starts slipping. I can’t explain it, but my feeling is the fresh ATF flushes a bit of sludge from a place where it was doing no harm to a place where it does do harm. Overfilling, under-filling, and cleanliness are also issues in ATF and filter servicing, but these should not be problematic for a professional BMW technician, dealer or independent.
BMW has “backed off” their lifetime fill mantra for automatic transmissions, currently recommending an ATF and filter change every 100,000 miles.
My inclination is to tell people to change “lifetime” ATF and filter every 30,000 miles. However the fact is, I've seen BMW automatic transmissions that were maintained break anyway. In that event, say it happens at 90,000 miles, you would like to have that $1,500 you spent on ATF and filter changes to put toward your new automatic transmission. And if I told you to spend it on maintenance you’re probably not going to be very happy with me. On the other hand, I have seen maintained automatics last 200,000 miles. I have also seen unmaintained automatics last 200,000 miles, although both are very rare. There's just no predicting with these transmissions. When you choose to buy an automatic transmission, you also buy into the vagaries of the darn things, which is one reason technicians hate them.
Whether to maintain a modern BMW automatic is up to you. I am washing my hands of automatic transmissions – I don’t like them, I don’t buy them, and I don’t mess around with them under the car. At the end of the day, for long-term durability, order the car with a manual gearbox.
At automatic transmission replacement time, we are confronted with the reality that the local transmission shop cannot rebuild BMW automatic transmissions, even those built by GM (BMW’s GM transmissions bear not resemblance to GM transmission in domestic cars). There are some domestic specialists who concentrate in BMW automatic transmission rebuilding, and you’ll see their ads in Roundel. However, I have no experience with any of the current domestic re-builders. My experience in the past is…well, I wound up buying a BMW factory rebuilt automatic transmission every time, and this is the course I recommend to readers – “back to the dealer.”
Some of you, having seen the light, may be interested in converting to a manual gearbox. This is always possible, but for most of us it won’t be less expensive than a replacement automatic transmission. This is because of all the other parts and additional labor required. And the newer the car the harder the job will be. It is certainly a doable swap, but there’s no cost savings even if you do the work yourself. The exception would be if you have access to a manual gearbox donor car for little or no expense.
Differential Oil
Recommend Red Line 75W-90 synthetic gear oil, drain interval 30,000 miles in any BMW differential
Okay to use Red Line 75W-90 in place of BMW “lifetime fill” gear oil
Brake Fluid
Recommend one-year brake fluid changes, or prior to each driving school or track event. BMW now recommends two-year brake fluid changes, but used to recommend a one-year interval.
Recommend ATE SL brake fluid for normal street use, ATE Type 200 or Pentosin Racing Brake Fluid for track work or very high performance use
Note
It has to be recognized that the benefits of good drive-train lubricant maintenance do not accrue until the car matures. The difference between the car that ran 15,000-mile oil change intervals and never had it's gearbox or differential oil changed (as per BMW instructions) and the one that ran high-end synthetic lubricants and had it's drive-line maintained in contravention of BMW's instructions, is the strong likelihood that the second car will be running strong at 200,000 miles whereas the first car will likely have a worn out drive-train. BMWs, and most modern cars, will run 100,000 miles just fine with zero maintenance.
So, if you're maintaining the car religiously only to sell it at 75,000 miles then you're a good guy for helping out subsequent owners. That's nice, but to realize the fruits of your diligence, you need to keep the car longer.
© 2002 Mike Miller
      09-05-2016, 03:28 PM   #9
overcoil
Drives: M235i 6spd
From the mercedes Benz club, the thinking was since the automatic transmission are so expensive and electro-mechanical, even with the transmission fluid bring pricey, 50k miles was the reasonable drain interval.
With the brakes since the ABS system are complex and good braking so vital, every two-year pressure bleeding is a good way to assure reliability and deal with moisture. Also, in the rain it's advised to go into empty area and work the brakes hard to get the ABS to work, actuators to function.
123Britt (above) if I knew you'd post the above I wouldn't had posted
P253.00
      09-05-2016, 03:55 PM   #10
Joe240
Joe240's Avatar
I see, thanks ScottSinger.
      09-05-2016, 08:38 PM   #11
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
Note
© 2002 Mike Miller
This is the essence of the Miller Old School maintenance system. How long to want to keep the car and do you believe in the Law of Kharma.
      09-05-2016, 10:36 PM   #12
Beartato
Beartato's Avatar
882
Drives: M235i
I see it kind of the reverse, which before free maintenance BMW would try to squeeze every penny out of its customers with recommended service, and now they're footing the bill so it only makes sense they'd fine tune the maintenance schedule to fit only what is really required. Really think BMW would cheap out on essential maintenance like this? I don't imagine BMW would be stupid enough to, seems careless. Think of all the N55 drivers who don't do all these pre-free scheduled maintenance items (the vast majority of them), are there a rash of failures out there? I suppose there's nothing wrong with being cautious though but I'm just not convinced.
      09-06-2016, 07:31 AM   #13
overcoil
Drives: M235i 6spd
I think in Europe particularly environmental factors have required extensive drain intervals and the fluids have probably been improved significantly because of this. But in order to get into very high mileage with healthy radiator and minimal metal wear through the drivetrain - for those results...
span1.00
      09-06-2016, 10:40 AM   #14
Beartato
Beartato's Avatar
882
Drives: M235i
Do you have any actual proof (not anecdotal or speculation) that doing additional maintenance outside of scheduled service actually prolongs any component in our N55 cars?
Not trying to be difficult, but the only justification for doing all the extra maintenance is the contrast between owner paid vs free maintenance itself.
      09-06-2016, 10:51 AM   #15
jpnh
jpnh's Avatar
1424
Drives: NA
Specific to the N55?
How could there be any such info given that the motor hasnt been around all that long
But given the fact that it IS still an internal combustion engine with fundamentally the same systems as most every IC engine AND that there is a long history of showing that regular PREVENTATIVE maint helps reduce wear/tear and corrosion within various systems (esp aluminum components) its safe to say that within reason following the recommended old school specs WILL result in a vehicle that is in much better condition after 100k miles than one that has followed the "New School" BMW recs
I will most certainly be following the time proven old school maint intervals since I plan on keeping the vehicle.......you get what you give
      09-06-2016, 11:45 AM   #16
Beartato
Beartato's Avatar
882
Drives: M235i
WILL result, huh? The only certainty here is the money you'll spend on the additional maintenance.
They've been using the N55 in various products since 2009, I think by now we'd see the end result of BMW scheduled maintenance as opposed to "old school" maintenance show itself in some fashion or another.
I guess this is where we differ: I trust BMW derivatives its maintenance intervals from laboratory testings on various components, the actual reliability history of cross-platform components and its own estimation based on the previous two points. I suppose you, and most of the others here who subscribe to the "old school" maintenance interval logic, perhaps in your inherent lack of trust with BMWAG, think maybe they took the above one step further and their bean counters removed items from that list? Or do you think BMW kind just put components and time intervals in a jar and matched up what number came out with what component?
I can understand both sides, but BMW isn't stupid. If they were ignoring vital/required maintenance it'd take less than a generation of cars to ruin their reputation. Considering how long BMW has been doing the "free maintenance", in addition to the run of the N55 so far, and factor in the vast majority of N55-driven cars aren't owned by forum dwellers who obsess over maintenance intervals, it's not illogical to conclude your factory maintenance intervals are fine. Additional maintenance, if so desired for your peace of mind, only hurts your checkbook so more power to you.
      09-06-2016, 11:56 AM   #17
jpnh
jpnh's Avatar
1424
Drives: NA
BMW like most companies make a calculated recommendation
Its quite telling that when the owners were responsible for maint that they recommended a much more rigorous regimen......now that BMW is on the hook for main on THEIR dime that regimen is much less frequent
As others have stated previously most of these cars will go 100k without too many issues but the question remains what condition will the minimally maintained vehicle be in at 100k VS the traditionally maintained vehicle
this is not a brand specific issue as most all vehicles are using similar fluids, use similar materials.
I've driven multiple vehicles to 400k miles and I can tell you from my own experience that regular preventative maint prolongs component longevity.
      09-06-2016, 01:11 PM   #18
Beartato
Beartato's Avatar
882
Drives: M235i
I guess the question is what particular items need special attention outside of the prescribed factory maintenance. The article posted earlier seems pretty on point after rereading it.
      09-06-2016, 01:22 PM   #19
jpnh
jpnh's Avatar
1424
Drives: NA
IMHO I dont think you can go wrong with the recs mike Mike Miller, BMW Roundel Tech editor that britt123 posted
Can you push some of them out a bit with likely little/no consequences? probably
Not sure I would do a diff/tranny drain and fill every 15k but I certainly wouldnt push it much passt 20k
theme and variation on other fluid changes
      09-06-2016, 06:20 PM   #20
xantdieselx
Kingslayer
xantdieselx's Avatar
411
Drives: 23' M3 Base
Thanks for posting 123Brit. I did a break in change on my 16' M235i at 1200 miles and am debating at what interval to change. I'm thinking 5-7.5k should be good. They reset the reminder last time which I wish they hadn't.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      09-13-2016, 01:46 PM   #21
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
BMW had some issues with extended oil changes. It seems that they got a little ambitious with their long mileage changes. http://f30.bimmerpost.com/forums/sho...d.php?t=868291
Here is another recommendation: http://blog.**********s.com/15000-mile-oil-change-myth/
It makes perfect sense to do a break-in oil change around 1,200 to 1,500 miles and to change the engine oil every 5,000 to 6,000 after that,it is cheap peace of mind. The engine oil in my M235i N55 runs at 220 to 240 degrees, that is bound to take its toll on the oil, not to mention the heat of the turbo's effect on it.
I have a Toyota Matrix beater that starts to have a noisy engine after about 4,500 miles on the oil, after an oil change it purrs like a kitten.
Of course if you are leasing you might not feel that the extra effort is worth it.
      09-13-2016, 06:22 PM   #22
123Britt
Drives: 15 M235i AT
Walnut Blasting - DI ENGINE
If you have ever walnut blasted a BMW DI engine only to do it again 35k later - your perspective changes. I was changing my N54 engines oil every 7.5k with M1 0W-40 and thought I was doing good enough. I soon realized that the N54 was poorly designed from an intake oil control resulting in build up on the I-valves.
Yes the N55 is better but still suffers from valve deposits. Thus it is important to use clean oil. When I changed my Valve Cover gasket on the N54, the internals looked super clean but the M1 0W-40 has a lot of VI improvers, a higher NOACK than 10 and even with an OCC & RB PCV valve, she would gunk up the intake valves very bad every 35k miles. (post 50k)
SO, I have learned and realized that the oil in a BMW DI engine must be changed often with oil that runs super clean. AKA SHELL oil from gas with an NOACK of 6.8 and runs super clean. Mike Miller has stated that BMW DI engines need to be run hard to help burn off some of the tar type gunk, OCI at 5k & with an oil that runs super clean (SHELL / PENNZOIL) 5W-40 runs cleaner that the Pennzoil 0W-40. REDLINE 5W-30 is another good one but lacks LL-01.
Tpeterson156.50
2addicts
