JL Audio JX360/2 360W RMS How about this 2nd amp for subs?
09-14-2016, 12:40 PM | #1 |
Rep 95
I'm trying to find a way to boost the Hi-Fi system subs w/o spending a small fortune and thought adding a second amp strictly for them might be simple, easy, and low cost? Does the 2nd amp idea make sense?
09-14-2016, 01:09 PM | #2 |
1911
Rep 13,103
The order of things to replace
The single worst thing about the Hi Fi system is the amp. But the speakers aren't far behind. If you notice there is practically no bass but if you turn it up the tweeters and doors become harsh and distorted to. The reason that people choose the Jl 600/6 is it does all channels, fits in the stock location , is compatible with the radio output and sounds good . The Bimmertech setup can squeeze more out of the stock speakers through use of DSP and time delay but it will be transformed by better speakers to. If you patch one part of the system without fixing the whole thing you may find yourself forever chasing patches to fix the other parts you didn't fix in the first place. This questions has been rehashed many times here the Jl 600/6 and the Helix 82dsp are proven and known good solutions. For most things BMW and low cost are mutually exclusive. Technic use to be the master of low cost solutions on here and he couldn't get it much under 600 if I remember right and those solutions are using component that may no longer exist and require some skill to install. HI Fi upgrades http://www.e90post.com/forums/showth...ighlight=level http://www.m3post.com/forums/showthread.php?t=540446 http://www.e90post.com/forums/showth...hlight=technic http://www.e90post.com/forums/showthread.php?t=532585 http://www.e90post.com/forums/showthread.php?t=833581 http://www.m3post.com/forums/showthread.php?t=443043 http://www.e90post.com/forums/showthread.php?t=324214 http://www.e90post.com/forums/showth...hlight=level+3 Last edited by ctuna; 09-16-2016 at 11:24 AM.. |
09-14-2016, 02:59 PM | #3 |
Rep 95
ctuna, is there a difference between the JL Audio XD600/6v2 6-channel car amplifier - 75 watts RMS x 6 and the XD600/6 - JL Audio 600W 6-Channel Class D Amplifier? Has that V2 designation changed anything. Wanting to make sure the Technic's harness fits also.
09-14-2016, 06:23 PM | #4 |
1911
Rep 13,103
the v2 has signal sensing
the v2 has signal sensing which means you don't
need a physical turn on signal. But that signal is provided by the Technic harness so its not a difference that would mean anything. |
09-17-2016, 07:30 PM | #6 | |
Rep 189
With its software as well you can set the gains higher for the underseats and leave the rest alone. I suggest this as its plug and play and you can do it yourself in under 45 minutes and be DONE with it!! Easiest and best solution in my opinion. Also, in my ears, it's has one of the cleanest signals too. I have a reference disc with zero data, played it and cranked the volume. NOTHING!! just my .02 cents
Thanks
Stylin20 |
