M2 Technical Topics > Suspension | Brakes | Chassis > stainless steel brake lines..
      09-24-2016, 10:56 AM   #1
BurpZilla
Avid Car Enthusiast
BurpZilla's Avatar
Drives: 2017 Alpine White M2 6spd
Hey guys! Does anyone know where I can get some stainless steel brake lines for my m2? getting track ready :-)
History will never be forgotten
1992 Red Acura Legend 4dr, 2003 Daytona Blue Nissan, 350z 6spd, 2007 Black Audi B7 RS4 6spd
Current Girlfriends
Alpine White BMW M2 6spd; 2015 Arctic White Yukon XL Denali
      09-24-2016, 01:35 PM   #2
Ex-MINI
BMW Newb
Ex-MINI's Avatar
582
Drives: 2016 LBB M2 DCT
These guys are sponsors
http://f87.bimmerpost.com/forums/sho....php?t=1268366
http://www.hpashop.com/Stoptech-F8x-...ech-SS-F8x.htm
      09-24-2016, 08:07 PM   #3
BurpZilla
Avid Car Enthusiast
BurpZilla's Avatar
Thanks!!
      09-26-2016, 10:21 PM   #4
HP Autosport
BimmerPost Supporting Vendor
Drives: F80 M3
Yep, M2 shares the same lines as the M3/4.
Good in stock!
      12-06-2016, 01:07 AM   #5
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Good in stock!
Are these for StopTech calipers? Or will they bolt on to OEM M2 calipers, also?
      12-06-2016, 12:24 PM   #6
HP Autosport
Drives: F80 M3
These are for OEM M2, M3 and M4 calipers.
      12-06-2016, 01:22 PM   #7
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Thanks!
      12-06-2016, 01:59 PM   #8
CommitConfirm
United Kingdom
475
Drives: The Bus
Why would you want to replace the factory lines with SS?
      12-06-2016, 04:24 PM   #9
HP Autosport
Drives: F80 M3
Better protection from road or track day debris is likely the number one reason I would do it, but others may have different needs.
      12-06-2016, 05:53 PM   #10
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Reduce cracking of rubber by exposure to crud, also reduce possible flexing/when stomping hard on brakes.
      12-06-2016, 06:33 PM   #11
BruceM
Drives: '17 6MT MG M2,930,Jag XKR 5.0
Tracking the car, especially in high heat conditions, will cause the brake fluid to heat and expand, which causes the rubber lines to expand, which mushes up the brakes. And mushy brakes are a no-no anywhere, but especially at the track.
Even though this won't be my primary track car, I've got SS lines ready to install. Cheap insurance.
      12-06-2016, 08:26 PM   #12
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Yup. Lines, RBF600, and pads should do it.
      12-07-2016, 12:10 PM   #13
CommitConfirm
United Kingdom
475
Drives: The Bus
I'm with you now... for moment there I though you guys meant replacing the factory hard copper line with SS.
      12-07-2016, 12:35 PM   #14
HP Autosport
Drives: F80 M3
SRF will be a better value in the long run and no need to flush it out after each track session unless you boil the fluid. A quick bleed at each corner and you are good to go.
      12-07-2016, 12:54 PM   #15
nd2002
nd2002's Avatar
179
Drives: 2017 M2
SRF cheaper? Local shop carries only the Motul.
I don't flush after every track event, just annually. Only bleed+refill before the event.
Used to love alternating ATE colors till the gov put the kibosh on the blue dye
      12-07-2016, 01:00 PM   #16
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Haha. No way... that sounds like a lot of work!
      12-07-2016, 01:12 PM   #17
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Huh, MUCH higher wet boiling point. DEFINITELY not cheaper. I might actually give it a shot next year. Motul does lose some of its oomph later in the year.
      12-07-2016, 01:25 PM   #18
HP Autosport
Drives: F80 M3
SRF absorbs much less moisture over time
      07-13-2021, 02:21 AM   #19
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Drives: 2018 BMW M2 LCI
Has anyone got a video they can share documenting how to do this stainless line swap? Or just take the old one and replace.... then do the bleed. That easy.
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
      07-13-2021, 04:12 PM   #20
3t3p
New Zealand
455
Drives: M2
Rubber lines still have steel in their construction far as I was aware?
Nvm think I'm thinking of aramid or Kevlar type fibres.
      07-29-2021, 12:53 PM   #21
jritt@essex
jritt@essex's Avatar
Drives: e90 335i, NSX, 997.2, 987.1
Since this necro-thread was given new life, I'll throw our Spiegler Stainless Steel Brake Lines into the mix. They have some really cool features like the rotatiting fittings, which releases tension on the lines. While our lines aren't the cheapest, they are made with the highest quality components and every set is properly tested and DOT compliant. You can learn more about Spiegler here: https://www.essexparts.com/brake-lines
You can find the specific lines for the M2 and M2 Comp here:
Front: https://www.essexparts.com/spiegler-...mw-m2-m3m4-f80
Rear: https://www.essexparts.com/spiegler-...m4-f80-f82-f87
m2
