DEF tank delete HOLE!
10-02-2016, 02:52 PM | #4 |
Rep 3,553
I know where a used trunk black plate is if someone is interested. I had to drill mine to weld in threaded rod for spare tire. I bought another one new to have an unmolested one if I put everything back to OEM.
TDI covered up this area with a close out. |
10-02-2016, 10:19 PM | #5 |
277
Rep 1,572
I'm cureently on travel with family from socal to Seattle and having a full size front wheel is nice but also a pain in the trunk lol.
10-03-2016, 09:50 AM | #7 | |
74
Rep 1,689
I somehow doubt that tank is made of fuel-resistant plastic. If it isn't, it could degrade and you'd have a potential car fire.
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
10-03-2016, 12:13 PM | #8 | |
Rep 3,553
1) require an appreciably longer threaded rod 2) would hang down farther and likely be visible. I wanted to not worry about theft. I didn't drill my threaded rod to allow a lock to be put on. I'm pretty sure no one will care/want a compact spare wheel so theft risk is low (and you can't see it). A nice BMW alloy with much larger tire would be a way different theft risk (both in value and visibility). Here is another idea if you must haul the full size wheel while on a vacation with family and lots of luggage. Yes, it is redneck for sure. Go get the receiver hitch from uhaul or the nicer one that Execuhitch makes. Buy a cargo basket that can be installed into the receiver. Use basket only when you need to fully load the trunk and put spare on the basket. I've been looking at a cheap one from harbor freight. My idea is for overflow baggage. Ever try to pack luggage for 3 women in our little trunk (even if spare tire isn't a factor)? So, far my answer is only 2 women's worth (and my little bit) will fit. I have thus far resisted doing the roof rack and Thule (or similar) luggage pod. I've heard it makes wind noise and hurts mileage. Now if I have the weird combo of needing to haul bicycles and excess luggage, uuu boy. |
10-03-2016, 01:27 PM | #9 |
50
19
Rep 230
When you remove the DEF tank out, can u still use the trunk black plate to cover the hole? and also can you still reuse the exhaust heat shield to cover the area? I dont care about filling it with anything....
10-03-2016, 02:03 PM | #10 |
Rep 3,553
Yes, black plate can stay if urea tanks gone.
You will have to creative to attach the corrugated shields back. They attach to the tanks. I figured out something but some of the fasteners fell off. Let's just say super glue was involved. There are two large studs on the bottom of black plate. I removed the large female cylinder looking parts and used a short nut and washer. I punched holes in shield to align with the trunk plate studs and secured the shields. The volume is deeper without the tanks so the shield is no longer long enough. I cut the shield in half to cover the port abd stbd sides. The spare covers the middle. I used a rubber mallet to reshape the aluminum to go up deeper into the cavity. I'm thinking a picture is worth a thousand words here. Car would need to be on a lift with spare removed for you all to see far enough away view. Last edited by BB_cuda; 10-03-2016 at 02:13 PM.. |
10-03-2016, 04:59 PM | #11 | |
277
Rep 1,572
10-03-2016, 09:15 PM | #13 |
277
Rep 1,572
Yeah it was last minute planning too. Strapped the spare down with the mounting points with a ratchet strap. We drove pretty much nonstop from la to Seattle Friday nighy. Cant imagine being stranded with a 8 month old.
10-05-2016, 03:14 PM | #15 |
Rep 579
10-05-2016, 04:34 PM | #16 |
Rep 2,410
Page 2 of this thread shows what I did for covering the hole. It may or may not be helpful to you: http://www.e90post.com/forums/showthread.php?t=936032
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
