Those with BPC tune....
10-04-2016, 09:52 PM | #1 |
Know's a guy that know's a guy...
5637
Rep 1,905
...and running spray, do you run the spray all the time, or intermittently?
10-05-2016, 05:39 AM | #3 |
Rep 460
You want a switch to shut it off... I'm actually updating my Hobbs controller to something better.
10-05-2016, 07:38 AM | #4 |
5637
Rep 1,905
I'm having a control unit installed as well, just curious to better understand usage rate under 'normal' driving conditions.
Also - do you buy the pre-mixed bottles or mix your own? |
10-05-2016, 08:39 AM | #5 |
Rep 460
The way I use it now is only WOT so it seems I go through a gallon or less a month (very little).
Progressively will probably consume more. I recently found a source for M1 methanol 5 gallons 100% $43. This makes it $4.30 a gallon (50/50) opposed to $10/g for other premixed solutions. *Also, when mixing use filtered water (I use home r/o filtration) |
10-05-2016, 09:24 AM | #6 |
Rep 218
I spray 250c at 16 psi and another 750c at 26psi with a Snow MPG MAX controller full time. But I installed a switch just in case I run out. Also because I still have nightmares from have my AEM setup that filled my engine with water twice. I use pro meth nozzles and 4.5 gallon pro meth fuel cell with 70 % meth. So it's tough to run out. Pro meth stuff is really nice. It took me a while to get the system how like it, but this works well for me.
10-05-2016, 10:06 AM | #7 |
Warrant Officer
375
Rep 1,341
I had my progressive 1000cc/min setup spraying full time from 15psi to 35psi. I went through about a gallon a week and got tired of paying $50/5 gallons of M1. I installed a switch on the 12V check wire to turn it on when I want to now. So far it's about a gallon a month now.
Deleted, ATM I/C and tuned by B.R.R.
10-05-2016, 11:46 AM | #8 | |
5637
Rep 1,905
Not distilled? Also - can you share the source for M1? |
10-05-2016, 01:51 PM | #9 | |
Rep 460
10-05-2016, 01:53 PM | #10 | |
Rep 460
http://www.endlesswaters.com/distill...purified-water M1 I pick up at my local wholesale fuel supplier in town. Already had a farm account with them so it made things very easy, they are a VP dealer. |
