M2 Technical Topics > Suspension | Brakes | Chassis > Camber plate recommendation
      10-05-2016, 07:57 PM   #1
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Looking for camber plate recommendations for my M2 from people that actually have them. Let me give some background. I have Dinan nonadjustable camber plates on my E36 M3 and E90. I also had them on my E82 135is. I loved these plates as all I needed was just enough camber to let me go to the track without wasting my front tires. On my E82 I used the Dinan camber plates and had the alignment set to -1.5 and it was perfect, I had a square setup and actually wore my tires evenly with rotation. No excessive outer edge wear on the fronts. It was a set and forget setup that I used on both the street and the track.
Ideally I could get the same for the M2 but I called Dinan and they said they would love to make them as these plates are still extremely popular sellers but the M2 strut towers won't allow it.
So with all that background. What recommendations do you all have for a set and forget camber plate.
      10-05-2016, 08:06 PM   #2
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
I'm using the Ground Control setup. Easy adjustment.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
      10-05-2016, 08:14 PM   #3
Pyrat 2
Pyrat 2's Avatar
I'm less concerned about easy adjustment since I want to set and forget. I guess I wasn't specific on my priorities.
Absolutely zero noise.
Factory suspension compatible.
Factory reliable and durable
      10-05-2016, 10:05 PM   #4
DrKevM5
DrKevM5's Avatar
Seems pretty quiet to me.
      10-06-2016, 10:44 AM   #5
craina
Drives: 2020 m2c
You won't find an adjustable camber plate that makes zero noise, its just inherent with the design. When you go from the stock rubber mount to a camber plate that is a series of metal bearings there is going to be increased NVH.
Appreciate 3
TripleU168.50
      10-06-2016, 09:18 PM   #6
paradoxical3
1008
Drives: BMW
I have ground control and haven't noticed any additional noise.
Pyrat 21417.50
      10-06-2016, 09:21 PM   #7
Pyrat 2
Pyrat 2's Avatar
Can you post the install/adjustment manual.
      10-06-2016, 10:13 PM   #8
paradoxical3
1008
Drives: BMW
I don't have the adjustment manual to post but it's not that hard, just jack the car up, loosen a few bolts, slide the plate, and tighten.
HOWEVER - I was planning on adjusting back and forth between track and street trim. On the M2, this is not a good idea. While the car was on the alignment rack, we took the time to align the car to -2.5 degrees camber with 0 toe, then adjust back to 0 degrees of camber for street and re-measure everything. Unfortunately, toe gets adjusted by ridiculous amounts when you adjust for camber. If you switch back and forth between camber settings your toe will be so out of wack that you will cause rapid wear on street and track. So I settled on a full time compromise of -2.5 camber and zero toe. I wish I could do -3 with a bit of toe in on track, but the wear on the street would be too great.
bollinm25.00
      10-07-2016, 06:17 AM   #9
dcgolfdr
Wheelsucker
dcgolfdr's Avatar
Drives: Truck
Do the plates work with stock suspension or do you have to go aftermarket?
      10-07-2016, 08:03 AM   #10
rjn
Drives: 2017 M2
Thanks for sharing. I was wondering about that. That's unfortunate, but not unlike past 3 series experiences. sigh...
      10-11-2016, 01:23 PM   #11
HP Autosport
BimmerPost Supporting Vendor
Drives: F80 M3
TCKR is a good choice in the set and forget type of plates.
http://www.hpashop.com/TC-Kline-Raci...Plates-F8x.htm
That is true. There is always an increase in NVH with nonoball camber plates. Some of us is just not as sensitive so NVH is all.
      12-20-2016, 02:01 PM   #12
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
I used both the GC and Vorshlag plates on my E30 and I have Vorshlag plates on my 1M.
Much like the 1M.. Camber plates are likely a necessory for guys that track their M2.
I prefer the Vorshlag plates, because in my direct experience with the older designs.. they do make less noise than GC plates..
it looks like Ground Control is on the scene and readily available for the M2 with an adjustable plate design.
http://f80.bimmerpost.com/forums/sho...6#post21008946
I'll agree with others.. asking for a Camber plate to have ZERO guaranteed additional NVH over stock is like asking for track pads that don't create dust.
TripleU168.50
      12-20-2016, 07:10 PM   #13
Twt
Twt's Avatar
634
Drives: 2017 M2
I put on my GC plates several months ago.....after 4 track days I have no complaints.
      12-20-2016, 10:22 PM   #14
ex12psi
Drives: bmw
i just finished installing the ground control camber plates as well and zero complaints.
happy with the GC's.
seanyx11234.00
      12-21-2016, 10:11 AM   #15
PrematureApex
Drives: N55 X1, N54 135, s54 m3
Maybe see if GC is going to offer a street camber plate for the M2, like they do other models.
You'll get a poly bushing vs. the spherical. Softer riding and quieter vs. the standard plate, although the bushings can wear out over say, 5 years, they are independently replaceable.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      12-21-2016, 11:28 AM   #16
Pyrat 2
Pyrat 2's Avatar
I bought and installed some TCKline plates. So far additional NVH is small and I'm happy.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      12-21-2016, 10:21 PM   #17
ex12psi
Drives: bmw
i had TCK camber plates in my previous e90 m3. they were good but developed a bit of clunking when front end went over bumps. very sensitive to the strut nut being torqued correctly. developed after a few hundred miles and several days of track use. if you do start to hear it, you might check the strut nut.
but maybe different for m2. this was back in 2011 so i'm sure things have changed.
      01-03-2017, 09:14 PM   #18
Fokusracing
Drives: Alpine '17 M2
Had Ground Controls installed last week. No noise at all. Set at -2 degrees, .16" total toe.
Anyone tinkered around with an alignment rack to see how much toe changes with 1 degree adjustment?
DaFish155.50
      01-04-2017, 11:32 AM   #19
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
who has the best price on the GC plates?
      01-04-2017, 01:06 PM   #20
HP Autosport
Drives: F80 M3
Excellent!
      01-04-2017, 02:48 PM   #21
Twt
Twt's Avatar
634
Drives: 2017 M2
I bought direct from GC
      01-04-2017, 07:12 PM   #22
Pyrat 2
Pyrat 2's Avatar
Originally Posted by HP Autosport View Post
Excellent!
Thanks. Prompt delivery from you guys back in October. Much appreciated.
m2
