Help Replacing DPF Differential Pressure Sensor
10-15-2016, 12:27 PM | #1 |
Rep 109
Any tips on replacing the differential pressure sensor from those who have done this?
I have removed the engine cover, microfilter cowl and the airbox. I can see the sensor and I can get my fingers on it but barely. Not sure what type of screw is holding it on as I can only see it at an oblique angle, not straight on. Bigger concern is how to release the wired connector; I see a white tab on the connector but it does not slide easily. I suspect I should be sliding the tab outward away from the body of the sensor, but not entirely sure. I am also concerned that I will not be able to get the pressure tubes off the old sensor as well as on to the new sensor; there is not much room in there and the tubes are not that long. Would it be easier to do from the bottom after removing the underside trays? Can the DDE cables be moved to get some more room? |
10-17-2016, 12:19 AM | #4 | |
Rep 2,615
DDE cables can not be moved much. Don't go from the bottom, you will not see much as it is fairly high up. You may wish to try removing the differential pressure tubes off the DPF connections if the ones on the sensor are tight, which is a good thing, really. For the connector, you slide the grey tab towards you, then push down and pull towards you. They are similar to the connectors on the pressure converters if my memory serves me well. If you can't unscrew the sensor, then you have a good excuse to yank the whole thing and treat it to some new vacuum lines and may be pressure converters. But, why do you think that your sensor is dead? |
10-17-2016, 11:29 AM | #5 | |
Rep 109
Not sure the DPF Differential is the problem, but it was cheap enough to give it a shot (so long as I can actually get it installed!). I will unbolt the vacuum block next time I try and see if that gives me enough freedom. I was hoping someone would confirm working from underneath; at 6'4" and 275 pounds, my arms are a lot longer than my hands are small/dainty. |
