10-17-2016, 04:12 AM | #1 |
757
Rep 1,835
Drives: 2020 X4M CS
Tuning question for an expert regarding N02, and Ignition timing?
Not sure if I posted this ? in the proper sub-forum...Question regarding N02/Meth integration and JB4. Need a map, or if JB4 can't control ignition timing a method to slightly retard timing??? Or will a115AKI, 16 psi, Frigid IATs, and even require a significant reduction in advance?
More specifics in original question here: Meth/N02 integration. JB4 map for slight reduction it timing advance? Better way?
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
10-17-2016, 10:13 AM | #2 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Yes wrong forum, you need to post it on JB4 forum
http://www.n54tech.com/forums/forumdisplay.php?f=33
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-17-2016, 01:05 PM | #3 | |
BimmerPost Supporting Vendor
24203
Rep 190,807
As mentioned above, first step would be to check out the BMS forum and read about the JB4 You should not use the customer map until you fully understand what each settings does.
FSociety3812.50 |
