air scoops
10-21-2016, 08:17 AM | #5 |
Rep 934
I tried to delete it but no happs.
Anyways I ordered some Macht Schnell scoops yedterday, and didn't think to research it but I probably should have ordered a water/meth controller instead. I'm still running a Hobbs switch, oh well... |
10-21-2016, 08:19 AM | #7 |
Rep 504
I dont know whay there is such a hate for scoops. They add HP and Puerto Rican 335d has proved it. Plus they get you laid.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
10-21-2016, 08:44 AM | #9 | |
Rep 456
10-21-2016, 08:52 AM | #10 |
95
Rep 308
Drives: 2011 335d M-Sport, Nav/Blinds
HAHA Red scoops cost me a hole in my condenser and a $925 repair bill !!
Although on my daughter's car we have some ECS ones that DON'T rub in the back and do look BITCHIN !! |
10-21-2016, 11:49 AM | #11 |
Rep 3,489
Drives: Montego Blue 335d
jajaja you guys aint shit. ,mines are still on and they do work properly jajajajaja
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
10-21-2016, 01:13 PM | #13 |
Rep 697
Do they work?
Lol, must say, I had them on my 135i mainly for aesthetic purposes since I had a red interior. Of course I was curious if they would provide any benefit or not.
On the 135i, I felt it was pointless, as the air was already channeled nicely into the intake, forced by the twin turbos. I really don't think I felt a noticeable difference. There are a few independent dyno graphs from the skeptics of these products, however, it is on an N/A V10 M5 and V8 M3, claims ranging from 4-14hp. Seems they are effective at higher speeds to channel air for N/A engines. Yet to see any hp+ claims with dyno for turbo charged cars. |
10-21-2016, 01:41 PM | #14 |
Rep 3,489
135i_vs_ I concur w you its noticeable at higher speeds as far as dyno I never did do it.
10-22-2016, 07:15 AM | #17 |
Rep 3,489
Yep red ones and no codes haters jajaja
10-23-2016, 12:32 PM | #18 |
Rep 281
The limitation is the TINY holes which are in the horizontal plane. Their surface area (or port size) to pass air is significantly smaller than the 3" diameter intake tubing.
Also the air has to take a two 90 degree bends in rapid succession. One is un-radiused or virtually instantaneous--the transition from outside, horizontally oriented, laminar-flow air to quickly vertical, then a radiused transition to horizontal again into the airbox. This is to keep bugs, large debris, and heavier objects out of the airbox. I believe it was also designed this way to take outside, pressurized, laminar flow air and transition it to turbulent flow (increased massflow rate) and for sound abatement. If you can open up these holes to exceed the port flow area of the tubing behind it, then perhaps your scoops could begin to make a difference. Last edited by nicklockard; 10-24-2016 at 10:53 AM.. Reason: edited 'faster moving' to increased massflow rate. |
10-24-2016, 10:52 AM | #21 |
Rep 281
10-24-2016, 11:51 AM | #22 | |
Rep 2,410
Lots of testing and data in this thread: http://www.e90post.com/forums/showthread.php?t=1179619
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
