Low coolant temperature
10-21-2016, 02:53 PM | #1 |
Rep 436
325d 11/2007
After driving at about 110km/h for close to 60 km - the coolant temperature still was not higher than ~63 degrees C. I have an error on the aux waterpump, can that be the culprit of the low coolant temps? Or am I looking at a new thermostat? I ordered a DPF regen before leaving home - but according to the pre-DPF temperature it never happened. I supposeit is because of the low coolant temperature. |
10-21-2016, 03:31 PM | #2 |
Rep 215
Drives: E39 M5, F15 35d
I found a broken thermostat in mine when I got that warning. Unfortunately I don't believe US cars came with the aux water pump, so I'm unsure about that,
10-21-2016, 07:58 PM | #4 |
Rep 2,210
The aux pump circulates through the heater in the cabin I believe. It is possible for that to contribute to low coolant temps if it malfunctions but I would think you would notice as it would have to have a tradeoff of uncontrollably warm temps in the cabin.
10-21-2016, 08:37 PM | #5 |
277
Rep 1,572
10-22-2016, 01:57 AM | #6 |
Rep 432
Apparently, the "additional water pump" circulates the coolant through the heater core after the car is shut off. So you can hit the REST button, and it circulates coolant so you still have heat with the car off while you are out of the car briefly.
I have the Aux pump error code as well, but its not related to your low coolant temps, your T-stat is definitely bad. |
10-25-2016, 09:16 AM | #9 |
Rep 183
With a brand new thermostat,you should get 85ºC~89ºC under normal driving conditions.Thats what i noticed right after replacing thermostat on my X5-35D.Before i was getting 72~75.And i noticed rise in fuel economy right after that.
88ºC is what stamped on a thermostat. Last edited by ninja_zx11; 10-25-2016 at 09:36 AM.. |
Greck59.00 |
10-29-2016, 09:11 AM | #10 |
Rep 222
Found out about bad stats thanks to this forum, having them replaced asap. Interested in how the economy will be after the replacement. These are already great cars economy-wise but the more the better, right?:P
Anyway will make a thread about my new 335D soon just need my acc to be verified=) This forum is awesome for gathering info btw. Been reading it every day for last week. |
10-29-2016, 05:08 PM | #11 | |
13
Rep 47
First Indy I brought it to wouldn't do it because check engine was not on. Second Indy wanted $990 to do it and recommended to take to the dealer instead because they were not diesel certified. Sigh..... |
10-29-2016, 05:22 PM | #12 |
Rep 1,157
That's ridiculous. The part is really cheap, and from what I have heard, replacement isn't really that difficult to do. Perhaps someone with better searching abilities than me could link a DIY and you could give it a go. Pretty much any time you take these cars into a shop, the final cost will be about $1000.
10-30-2016, 12:10 PM | #13 |
Rep 222
Ouch, sounds harsh.
Well i have a friend who has a friend who works for small company that prepares sport cars for amateur sport drivers so no problems there.. We will see about the prices but they promised to be reasonable. |
10-30-2016, 01:18 PM | #14 |
Rep 196
Many discussions on the E70 site:
http://www.bimmerfest.com/forums/sho...9&postcount=15 |
10-30-2016, 02:50 PM | #15 | |
13
Rep 47
10-30-2016, 05:45 PM | #17 |
Rep 3,551
+1, with cooler out the way, job was fairly simple. I did loosen the mount points of the plastic water pipe as it winds it way around drivers side of engine. This was to give for flexibility of line that connects to thermostat. I did job from top except for the catch pan below for coolant spilling.
10-30-2016, 06:36 PM | #18 | |
277
Rep 1,572
10-30-2016, 11:40 PM | #19 |
Rep 296
Drives: E90 335d | i3 REx
Careful with that plastic water pipe. Easy to crack when you're putting things back together and you're frustrated that things aren't slipping in too easily.
2011 E90 335d M Sport | KW V3 | M3 Bits (arms/bushings/sways) | JBD | Apex ARC-8 w/PSS
2015 i3 REx | Solar Orange | Tera World | Tech |
11-05-2016, 09:25 AM | #20 |
Rep 37
11-05-2016, 03:53 PM | #21 |
Rep 436
Still haven't had the time to change it yet - but yesterday I spent quite some time in stop'n'go traffic. The temperature came above 80 - and then it started the high temp regen. (600-650) I had to keep driving for it to finish, while it generated temps rose to 92. Pressure before the DPF was @ 22mbar before and ~14mbar after.
..Next step - to replace the thermostat tomorrow along airfilter and cabin filter. It got a new oil filter and new oil today |
11-05-2016, 03:56 PM | #22 | |
389
Rep 1,623
