Resetting adaptation of the increment wheel
10-25-2016, 02:49 PM | #1 |
Rep 183
Resetting adaptation of the increment wheel is not working on my 2009 X5 35D.I am using ISTA version 3.53.13(this version includes increment adaptation) with ICOM A2. I-level on my X5 is E070-14-11-501 which i believe has a increment wheel adaptation function.
Also while doing mass air meter adaptation reset,i am not seeing any old learnt values.It just shows 0,0 Did anyone get success in resetting these adaptations? Thanks |
10-25-2016, 04:44 PM | #2 |
Rep 1,192
I'm getting the same value for the MAF adaptation.
Are you sure your I-level supports increment wheel adaptation reset? I thought it was more late last year (2015) that it was introduced. |
10-25-2016, 04:57 PM | #3 | |
Rep 183
According to this post,my i-level should include incremental wheel adaptation but who knows at what i-level BMW actually implemented incremental wheel adaptation.Would be great if someone can confirm. |
10-25-2016, 06:33 PM | #4 | |
Rep 1,192
10-26-2016, 12:21 PM | #5 |
Rep 183
Will check the date of last programming on DDE and will report back.I know the date when my X5 went in for the complete software upgrade at the dealer.
10-26-2016, 10:43 PM | #6 |
Rep 266
http://www.bimmerfest.com/forums/att...5&d=1449798061
This is how I got Bmw to update my I level to the most Current version for free. Only good for x5's |
10-29-2016, 09:56 PM | #7 | |
Rep 183
It means culprit was the Rheingold version that was not able to reset it.Problem is lots of people compile newer Rheingold using old data. Also tried to determine measure plan using latest ISTA-P and found that there was no DDE update available.Only update available was for CAS in the new integration level.So does it mean that my DDE is at latest level which was last updated on Jan-2015 ? I have attached the measure plan.Mik325tds could you please look at the measure plan.Thanks |
10-30-2016, 08:39 AM | #8 |
Rep 1,192
That's correct. If the DDE doesn't show up in the measurement plan, it already has the latest SW. You're all good.
I didn't even think of the problem with newest ISTA version but old data. Good find! |
