Some help? Stage 3 issues
10-26-2016, 02:06 AM | #1 |
Rep 57
Hey guys,
My 335D was feeling underpowered so I took to to the shop to be dyno tested. It has a Hybrid turbo, stage 3 ecotune map, EGR / DPF delete, wagner IC. Ecotune claim around 420bhp but on the rollers it made 370bhp which is significantly under. We ran some data logging on the car and everything seemed completely fine. Fuel rail pressure was good, fuel temp was good, boost was a constant 2.5bar, inlet temp was low compared to others etc I can post up some detailed figures if needed. We then ran a smoke test on both hot and cold sides and that came out good too. Any idea what I should try next? Im completely baffled now and really dont know were to go! Thanks in advanced! |
10-26-2016, 06:16 AM | #2 |
Rep 460
You can add more power by...
1) Optimize the tune (dyno or mail in) 2) Methanol injection (30whp, dial it in correctly) I run the same type of turbo and like you, needed more. I will say those turbos can handle 420whp + and yield 41.2mpg on long trips! |
10-26-2016, 05:51 PM | #5 |
Rep 3,553
2.5 bar=36.xx psi. Isn't the whole point of doing a hybrid to increase the pressure? I recall a certain member who went for hybrids and blew up his forge pipe (inlet to IC) up from increased pressure. He switched over to a stronger pipe. I recall he was in the 40 something psi range. I could be mistaken.
EDIT: Tell Stan hi |
10-28-2016, 04:32 PM | #7 |
Rep 215
Drives: E39 M5, F15 35d
This. OP, you're mixing up crank hp versus wheel hp. Most automatic 2WD cars will experience an 18-20% drivetrain loss (automatic AWD would be closer to 25%, manual trans 2WD closer to 15%). So 420whp would measure out to around 340-350whp, which means you're likely making more than 420 at the crank.
10-28-2016, 04:37 PM | #8 |
389
Rep 1,623
^ hybrid turbo set up should be making more than 370bhp.
OP is listing brake hp figures, not whp. Most dynos in Europe use bhp. So, 370bhp is rather low for a hybrid car. |
10-28-2016, 04:58 PM | #9 | |
798
Rep 1,633
10-31-2016, 10:15 AM | #10 |
Rep 215
The ZF6HP28 may be 13%, but it's not the only component in the drivetrain. You've still got the driveshaft, differential, CV joints, wheel bearings, etc etc etc...
11-01-2016, 02:28 AM | #11 | |
389
Rep 1,623
BPC posted a stock dyno of 236whp. BMW advertised BHP is 265hp. You do the math... Additionally, drivetrain loss changes the more power you make. If a stock car loses 13% (34.45bhp loss) a highly modified car making 100-200bhp more isn't going to lose 50-60bhp. Last edited by 335dsleeper; 11-01-2016 at 02:38 AM.. |
11-01-2016, 07:42 AM | #12 | |
Rep 984
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
11-02-2016, 03:35 PM | #13 |
Rep 57
370 is the power calculated at the crank. The whp was lower but I forget how much by. This whole time the car has been at the tuners and he's completely baffled as on paper it is working fine! His now come to the conclusion that the injectors are not giving enough fuel and an upgrade to later lci ones should get it up to power. Does this sound right? If this is the case then I'm not sure how ecotune can advertise at 420bhp when it could never produce that amount . N.b the tuner has a lot of experience in tuning diesels. The last 335d he mapped with the exact same turbos made 440bhp on his rolling road and therefore a good benchmark. The only difference is the latter being a lci?!
11-03-2016, 01:10 AM | #15 |
Rep 57
Was that tested on their dyno or a independent one? I've had mine tested at 2 different places now and both came back with the same results apart from the ecotune one who claimed 416ish bhp.
11-05-2016, 03:14 PM | #16 | |
Rep 5,623
Are you saying they over estimate their figures? |
11-11-2016, 02:36 PM | #17 |
Rep 5,623
Just to add to this i did some runs at a drag strip earlier this year and trapped 112 or 113mph, which is about right for the power ecotune say. I think remapped only 335Ds are at 105-106mph.
And im sure trap speeds are better at showing power than a dyno. Take it to a drag strip. |
11-12-2016, 03:54 AM | #18 | |
389
Rep 1,623
11-12-2016, 07:53 AM | #19 | ||
Rep 5,623
Edit: found it and posted up |
11-12-2016, 12:32 PM | #20 |
798
Rep 1,633
