AT 335i for HPDE
10-26-2016, 09:41 AM | #1 |
Rep 175
AT 335i for HPDE
I did the Porsche driving experience last week here in Atlanta. 1.5 hours with a 911 on their handling circuit, among other things. Unbelievably fun.
So I get home and start doing some research on track days and learn about HPDEs. I want to start participating in these in the spring. So a little background before I get to my question. I have a 08 335i. Prior to this car, I had always owned MTs, including an E36 325i (loved that car and hope to buy an E36 M3 sometime in the next couple of years). When I bought the E90, I was having a hard time finding a CPO manual with the options I wanted, so I bit the bullet and bought the AT 335i. For daily driving, it is a good transmission. I drive it in manual mode exclusively, and am satisfied with it. However, I have always had some regret. Which leads me to my question. Reading on the forums, I am finding that the E90 ATs with N54s run into cooling issues on track days. So my question is this, at what point does this become a problem. Will I have a problem with this at the HPDE 1 level? Has anyone done Road Atlanta or Atlanta Motorsport Park with an AT N54 and, if so, any issues? Any insight would be appreciated. |
10-26-2016, 11:06 AM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
All things on the internet can be explained in a sexual analogy.
Wondering if you're going to have problem with your 335i AT on a track before you even attempt a DE, is like wondering if you're going to get a girl pregnant before you even go on your first date. You don't even know if you'll end up having sex. Or if she's on her "safe" dates. But yes, IF you two end up having unprotected sex, chances are pretty good you'll get her pregnant. So why take the risk? Fix your lack of cooling for the AT transmission. Or better yet, take that E36 M3 you want to buy because that is a better platform to start with.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
10-27-2016, 07:54 AM | #3 |
Rep 91
You sound like you are a novice to track days. Don't feel bad about it and don't be intimidated. You are gong to have fun.
You can have a great time with a 100% stock car. Please make sure all maintenance is up to date. Here is a basic check list: ?Any oil leaks? ?Fresh brake fluid? ?more than 50% on brakes and tires? ?Any suspensión problem ? ?do you have a helmet? |
davidwarren187.00 |
10-27-2016, 08:22 AM | #4 |
319
Rep 378
I agree go and have fun. They will have a tech inspection a few weeks prior to event so make sure like said above, the tires you will use are in good condition, good tread no bubbles, make sure you have flushed brake fluid within the last 12 months, pads are at a min half. Check engine bay and battery nothing moving around. Not a bad idea to change oil prior to event. I have seen a lot of posts on the oil cooler vs non oil cooler cars and oil temps over the limit at track events. More than likely in the green group you will not experience the dreaded limp mode but be aware it can happen.
I would suggest if you have not already , do a few autocross events prior to first track day not a must but will give you an idea as to the adhesion limits of your particular car and its tolerance to aggressive driving. Off ramps are not the place to learn this. Again just a suggestion. I bet the Porsche event was fun but you will have a better time doing track days in your own car and certainly make some like minded friend along the way. Most important piece of advice, Keep the Shinny Side Up! |
10-27-2016, 08:38 AM | #5 | |||
Rep 175
My car is actually in the shop now, getting my oil pan gasket replaced and a new cooling system (radiator sprung a leak). So I should be good on leaks. I will probably give this a go in the spring, so I planned to deal with my brakes and my front tires then. A couple of screws recently forced new rears. Quote:
davidwarren187.00 |
10-27-2016, 12:47 PM | #6 |
Rep 510
I have attended more than a few HPDE events with my 6AT 335i. Cooling is going to be your number one problem, if any.
What are the temps going to be like the day of the track event? Independent of the transmission, the 335i suffers from high oil temperatures, especially at the track! Do you have the OEM oil cooler? - this is a must at the very least, without one, you will almost surely run into limp mode due to high oil temperatures. I would recommend a brake fluid bleed after and before the event, and go easy on the brakes so you don't end up overheating your rotors and glazing them (I've done this on street pads with poor breaking techniques on my end). Let the car idle for 5 minutes after each event to keep the fluids flowing before shutting her down while they're extremely hot. You'll have fun! I recently retired the 335i for the track and am tracking an e36 M3. Boy, the light car approach to racing is much more rewarding, it makes our 335i's feel like pigs! Good luck out there.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
10-27-2016, 02:04 PM | #7 |
Rep 3,251
I logged the trans temp on my car during a few HPDE, it hovers at around 110C during the 20-30mins session when I am driving flat out. Could the temp be lower, sure. But is 110C/230F dangerously high for the synthetic oil used in these ZF 6hp21 (btw, I ran redline D4), hell no... And my car pretty much have all the performance mods that you can think of aside from aftermarket turbos and inlets... on top of that, I am far from slow in the intermediate and advance groups that I typically drive in.
Rather than messing with the transmission lines to cure a non-existing problem, I would look into getting an aftermarket oil cooler and radiator instead... Of course, there are plenty of other things to worry about before that too, i.e. brakes, tires, suspension setup, and that thing sitting behind the steering wheel. Just to clarify, trans temp is not what's killing these ZF box, even at +600hp level, and those who said so never had any proper data to back up those claims. Lighter cars are better for track, no doubt. But some of us want something that can be used daily as well, which IMO e90 has the right balance for. No matter how you put it, E36 is a pretty dated platform and given the same mods, e90, particularly ones with N54 or S65 engine, will be much faster on track...
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization Last edited by Cloud9blue; 10-27-2016 at 02:12 PM.. |
Taskmaster2465.00 |
10-31-2016, 08:42 AM | #8 | |
Rep 175
10-31-2016, 10:34 AM | #9 |
Rep 534
I have yet to run into Cooling issues with regards to the trans. With that said, even when I first started attending HPDE I boiled the brakes and overheated the oil. My recommendation would be to put some high temp Brake fluid, Decent track pads, and get an oil cooler. That will allow you to take advantage of each session and maximize your seat time at each event.
Frozen Black Widebody E92 : VRSF CP, N54Tuning Downpipes, Tial BOV, DCI, MHD Flash, Aquamist HSF-3 Meth kit Dual Nozzle, Megan Racing Toe Arms,Megan Racing Camber Arm, Megan Racing Trailing Arm, IND Delrin Subframe Bushings, M3 Control Arms,Fortune 500 Series Coilovers, Square 18x11 Apex Ec7 w/ 315/30/18 Hoosier R7's
11-01-2016, 10:17 AM | #10 |
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
OP don't stress. If this is your first time out, odds are you will be taking it easy on the track. Just made sure your tires and brakes are in good shape. Bring a helmet and have some fun.
If you make this a more common occurrence, then you can look at improving your cooling along with a host of other weakpoints that may expose themselves (brakes, tires, suspension). Until then, go have some fun |
11-12-2016, 07:44 PM | #11 |
Rep 212
N55 but, I've done 18 track days this year, some in near 100 degree heat and never a problem with the tranny, and I have over 400hp.
2011 335i Sport, M3 control arms front/rear, ECS Tuning rear trailing arms, Bilstein HD's, StopTech BBK, Drexel LSD, Dinan camber plates, FBO's with Cobb Stage 2 tune, Corsa exhaust, 18x9 D-Force, 255/35 R-S4's
