anyone put back swirl flaps back ?
11-01-2016, 05:49 AM | #1 |
Rep 78
so as i mentioned before, i was told swirl flaps are leaking and they were blanked to which I wasn't convinced reading that users experienced power loss and fuel increase, and i can attest those.
now, i want to put swirl flaps back, but as i am reading, i will have to buy new manifold intake? anyone has done this? |
11-01-2016, 06:24 AM | #2 | |
389
Rep 1,623
11-01-2016, 06:52 AM | #3 |
Rep 128
My swirl flaps just failed, in the last 2 months of warranty. I was told that I had to get a whole new intake manifold as this was an integral part. I did notice power loss and fuel efficiency loss about 2 days before i got a CEL. If you watch the MPG gauge it should be pegged at the low end most of the time, even under light acceleration when it would normally be in the 20-30mpg range. Good luck. My SA told me it would have been $1500-1800 without warranty.
11-01-2016, 07:35 AM | #4 |
Rep 3,489
Drives: Montego Blue 335d
I guess Im going thru this crap now, I bought the AArodriguez EGR Race pipe and the Swirlflap covers from him, I will find out this weekend WTF is actually happening to my car. My mechanic got under the car and heard no leaks. Im getting MISERABLE mileage and power, went to a different dyno Sunday and LOST 100 ponies, SOMETHING is wrong i could feel it and BAM the dyno did not lie.
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
11-01-2016, 07:36 AM | #5 |
Rep 984
If they're properly coded out I don't see why it would cause power loss or mpg loss. Obviously if they are faulty and/or you remove them without properly coding them out then the car isn't going to run right.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
11-01-2016, 07:39 AM | #6 |
Rep 3,489
MasterC17 Im coded out completely. But with the new plugs I believe it will get better HOPE its not the preturbo (crossing my fingers)
11-01-2016, 08:03 AM | #7 |
Rep 3,556
PR, you need to specifically ask tuner if flaps were tuned to be open at all times. This isn't necessarily part of the "full deletes" as a default.
kydiesel35166.00 |
11-01-2016, 08:38 AM | #8 |
Rep 3,489
BB_cuda will ask Lenny that today, gracias
11-01-2016, 10:23 AM | #11 |
Rep 3,489
Hoping its not the turbos
11-01-2016, 11:03 AM | #12 |
2125
Rep 3,368
Sounds remotely similar to what Johnnybravo and Andrew went through and narrowed it down to injectors which felt like no low end boost, even though there was no code present. I'm only guessing and hoping that is not the case for you!
11-01-2016, 12:34 PM | #13 |
Rep 3,489
I just added a bottle of SEA FOAM in my car went for 5 mile spin, I concur with you dmanb2b it might of been injectors clogged, car is running way better cause as i step on it my traction control now comes on before that it wasn't doing that. Gracias
11-01-2016, 03:43 PM | #15 |
Rep 3,489
Inxguy i buy diesel from the Shell gas station every week i doubt it but could of been
11-01-2016, 07:55 PM | #17 |
NY BRAVEST
47
Rep 231
11-02-2016, 06:53 AM | #18 |
Rep 984
What plugs are you replacing? Glow-plugs aren't going to affect running after start-up.
11-02-2016, 08:39 AM | #19 |
2125
Rep 3,368
Good to hear!
11-02-2016, 11:00 AM | #20 |
Rep 3,489
MasterC17 swirlflap plugs from AArodiriguez. Car is running better but I need to flor it, traffic has been hell down here with all the rain , need to do a long distance run to clean out, I emptied the whole bottle of SEA Foam in the car we'll see what happens
11-02-2016, 11:50 AM | #21 |
Rep 3,556
PR, we have a couple threads going here sort of in parallel. Did you say you were getting the carbon cleaning while intake is off for swirl flap blanks? If so, can you get pictures of the ports please? Thanks
11-02-2016, 01:49 PM | #22 |
Rep 3,489
Will do amigo BB_cuda. my mechanic has the walnut blasting but does not hv the part to clean Diesel intake, he will contact the local BMW dealer since the head mechanic is our racing friend to see if they can loan us the part. but i will keep everyone posted ok
