335d Thermostat replacement DIY?
11-01-2016, 02:03 PM | #1 |
9
Rep 38
So I have a 2010 335d. Coolant temps are 65-75°C, never higher than 75°C.
It seems that every online DIY, Bentley, etc. references the non-diesel thermostat. Does anyone have links / info to change the thermostat? |
11-01-2016, 02:15 PM | #2 |
Rep 504
Using search helps. BTW following are the threads that i found searching the forums:
http://www.e90post.com/forums/showth...ght=thermostat http://www.e90post.com/forums/showthread.php?t=1008568 Also try: Link
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
11-01-2016, 02:17 PM | #3 |
Rep 281
I'm about to do it myself. Looks like it's right under the vacuum canister. I read here it's a much easier job if you remove the EGR cooler first to gain access. A search of youtube vids turned up some polish video which doesn't seem too far off the mark, and some X5D how-to vids as well: https://www.youtube.com/results?sear...m57+thermostat
Biggest difference being theirs have the secondary EGR t-stat which North American models don't. So ignore that part. |
11-01-2016, 02:26 PM | #4 |
9
Rep 38
Thanks for the link.
I'd searched in this forum, and the main DIY forum without any luck. I hadn't thought to search the UK forum though. |
11-02-2016, 07:45 AM | #5 |
389
Rep 1,623
It's a very simple job. It looks a bit intimidating at first but, once you drain your coolant, its rather straight forward. Pull the EGR cooler like nicklockard suggested, just be careful with the erg coolant lines. They can become brittle and crack. Pull the cooler and the 4 10mm bolts are right there. Swap it out, reinstall the EGR cooler and top off your coolant. done and done
11-02-2016, 09:22 AM | #6 |
Rep 3,556
Per yozh's unfortunate experience, for cooler removal be careful with the bolts that attach to exhaust manifold. He broke off one of the OEM bolts when he was loosening them. He had to drill it out. I dressed those bolts with antiseaze when putting them back in.
11-02-2016, 11:48 AM | #7 |
Rep 109
I documented my experience here:
http://www.e90post.com/forums/showthread.php?t=1191391 So I replaced my thermostat on my '09 335d on Sunday of this past weekend (72K miles on the odometer). |
11-06-2016, 12:05 PM | #9 |
9
Rep 38
Job done.
I was four hours start to finish, with a couple stops to look a couple things up. The job was "basically" as advertised with a few differences. Most guides seem to be from Euro cars that have the EGR thermostat that we don't have. They also seem to have the ATF reservoir on the passenger side and some other slight air duct differences. I replaced about half the engine coolant, I would have liked to have drained it, but didn't want to get too involved with intercooler, etc. There is a lot of grime / soot on the passenger side pipe of the intercooler, and on the top side of the under engine tray. I'll need to get that sorted at some point also. |
11-06-2016, 07:08 PM | #10 |
Rep 281
I concur with TdiWanted's summary. Took me about 3.5 hours to complete job. I also replaced a vacuum diaphram and wanted to replace red boost hose o-rings (unscucessful).
Highlight on TDIW's point number 6: there is a bolt (10mm I think) just underneath the EGR valve which holds the rigid "Y" shaped plastic pipe. If you just loosen it by 6 threads or so using open ended wrench, without removal, it makes pulling that heater connection off of the old thermostat housing (and installing onto new one) a bit easier. Gives just a tad of clearance and wiggle room needed. I would not recommend removing it, because replacment would add a lot of time. There is NO clearance to re-thread it back in. I lost ~5.5 L (didn't pre-drain or anything). I refilled it to a slightly higher coolant mix ratio for higher boilover protection. Went on a test drive after burping system (very easy), car hods 92-95C. My brand was the 'genuine BMW' which I believe is a Behr sourced part. I did not use ramps or remove bottom pan (don't have tools for it), or I would probably not have lost as much. Last edited by nicklockard; 11-06-2016 at 07:14 PM.. |
11-07-2016, 06:13 AM | #11 |
Rep 1,288
Looks like this job is in my future too. Coolant temps hovering around 70 degrees max.
Thanks for the diy tips. Update: I did this job last night. Not hard at all just tedious and takes time to get everything else out of the way. Tip, get 4 new 10mm bolts for the tstat. They thread into soft aluminum and the old bolts looked rough. I wish I had fresh bolts last night, I reused them but am not happy with they they felt threading in. I also used loctite blue. Car is not fully back together yet. I'm doing the glow plug module tomorrow. Fun. |
