11-03-2016, 04:01 PM | #1 |
Rep 535
G30 wheel bolt pattern?
Now that the German order sheet is out, does anyone know what the wheel bolt circle is for the G30? For the F10, It's 5-120mm, 72.6 hub and 35mm offset. I heard some speculation that BMW was going to 5-112mm for it's next cars. Anyone know what has happened? I'm hoping that I will be able to use my spare set of F10 wheels.
11-03-2016, 06:38 PM | #2 |
1566
Rep 29,202
G10? Do you meant he new 7 series G11/G12? If so, it has the new 5x112 bolt pattern.
The new X1 and the 2 series Active Tourer + Gran Tourer also have the new 5x112 bolt pattern. I've seen the G30 in real life and the bolt pattern looked smaller, so I'm 99% sure it will have the 5x112 bolt pattern.
11-07-2016, 02:19 PM | #6 | |
Rep 293
11-07-2016, 03:43 PM | #7 | ||
1566
Rep 29,202
The 17x8 and 18x8 are ET30, and the 19x8.5 and 20x8.5 are ET33. Staggered rears are ET44.
N26Ghost496.50 |
11-08-2016, 08:36 PM | #8 | |
Plenipotentiary
2614
Rep 3,046
PCD 5x112 CB 66.56 Began with i3/8 and all CLAR based cars (G11/30 and newer). It saves a tremendous amount of weight in the axles and wheels. No previous gen wheels are compatible for 5/7er. |
Almaretto2374.00 |
11-09-2016, 11:06 AM | #9 | ||
1566
Rep 29,202
And I wasn't sure about the CB number as I've seen both 66.5, 66.6 and 66.7.
N26Ghost496.50 |
11-09-2016, 11:12 AM | #10 | |||
Plenipotentiary
2614
Rep 3,046
02-02-2017, 07:06 AM | #13 |
Rep 1,128
No. The bolt diameter is smaller now to save weight. I have BMW F10 winter wheels and tires package and they wont fit the G30.
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3 Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del |
08-16-2017, 09:43 PM | #14 |
Rep 4
is there any difference between 66.5 and 66.6 for the CB? And do you know the offset number?
08-17-2017, 09:00 PM | #16 | |
Plenipotentiary
2614
Rep 3,046
Offset is dependent on the wheel dimensions. For aftermarket, engine, drivetrain, and suspension options can have different clearances on the Gxx cars. |
10-15-2017, 12:58 PM | #17 |
Rep 293
12-11-2017, 08:17 AM | #18 | |
Rep 1
Since I believe all 5ers are M14x1.25 bolts? |
12-14-2018, 01:26 AM | #19 |
Rep 19
Hi, could I ask if you’ve actually tried this because my local tyre shop tell my the switch to 112 PCD started with the F10 so wheels from the previous 5 series should fit. I was about to buy a used set from eBay!
12-14-2018, 06:42 AM | #20 | |
1566
Rep 29,202
01-18-2019, 08:10 AM | #21 | |
Rep 77
In your opinion, is it worth buying a set of snows that are 5 x 120 and using adapters to make them fit on my car? Is this a good or bad idea? Thank you. |
