AGAIN F@$ck
11-06-2016, 08:49 AM | #1 |
Rep 1,362
AGAIN F@$ck
So after getting my car back after 2 months because of cbu and overheating!
New head New turbos New I/c New radiator New t/s New scr New nox sensor Now low end boost gone Ses reduced power And still overheating when I'm stopped ( 97-101 degree celsius) |
11-06-2016, 01:09 PM | #5 | |
Rep 1,362
Nothing changed Coolant temps doesn't stay at 86 as it should be. When I stop more than 5-6 mins, coolant goes up, I go on the highway, it takes a good 6-7 mins to get the temp down. |
11-06-2016, 03:07 PM | #6 | |
Rudolf/German/Compression Ignition Specialist.
53
Rep 168
with a new rad and the fan verified working the water pump is a prime suspect. Most german water pumps use plastic impellers and after time they can break and disintegrate. General symptoms of this are exactly what you describe, hot at a stop, get moving and the temp drops down again.
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
11-06-2016, 03:18 PM | #9 |
53
Rep 168
as far as low boost goes I would be diving into the vacuum lines and the boost controler itself, if you have some sort of scan program, go for a drive and see requested boost vs actual boost. I think you need a new dealership... If they took the time to actually do a proper diagnosis instead of throwing parts at the problem you would have a good car and far less complaints.
11-06-2016, 03:19 PM | #10 | |
Rep 1,362
Dropping my car to the dealer tomorrow morning ??? |
11-06-2016, 04:00 PM | #12 |
Rep 1,191
Those temps are actually normal. I think it is doing this in order to keep the temps in the DOC up to keep it working.
Turn on your AC and see if it goes down to 83 then. That's at least what my car does. This may just be the reason why they didn't provide a water temp display. With the electronic thermostat they can now control the water temp and move it when it is needed. Edit: Nonsense. The thermostat in this car is not electronically controlled as @335dwanted points out below. My apologies. However, I have read many posts where people were concerned that the cooling fan comes on around 100°C. So maybe all of our thermostats are bad? Last edited by Mik325tds; 11-07-2016 at 11:42 AM.. |
11-06-2016, 04:23 PM | #13 |
Kind of a Big Deal
167
Rep 857
That is the best explanation yet I have seen.
11-06-2016, 06:14 PM | #14 | |
Rep 109
Mik325tds805.50 |
11-07-2016, 07:28 AM | #16 |
389
Rep 1,623
^ you shouldn't be driving your car, especially in traffic. You're going to do further damage. I hope you at least cranked your heat as hot as it'll go to avoid damaging the head/ head gasket.
11-07-2016, 07:34 AM | #17 |
Rep 3,489
Drives: Montego Blue 335d
I concur with 335dsleeper they can try to VOID any warranty by you driving it under that condition, be careful amigo
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
11-07-2016, 07:42 AM | #18 |
Rep 1,362
11-07-2016, 07:44 AM | #19 |
Rep 3,489
oh ok
11-07-2016, 10:00 PM | #21 |
NY BRAVEST
47
Rep 231
