Aquamist HFS3 water/meth install help needed
11-21-2016, 09:18 AM | #1 |
Rep 246
After much research I can't find any install information specific to the 335. Can someone chime in if they have any details specifically to the 335 wires I need to locate? Map, injector - pin. Also, want to use as much fail safe as I can so wondering if the pink wire can be implemented. (I'll put up a picture).
11-23-2016, 10:06 PM | #5 |
24
Rep 372
No you can't use the pink wire there is no option for map switching based on voltage input. Use the hsf4 wiring diagram to figure out any other wires you need to tap.
Thought I joined a car forum but all we ever talk about is alcohol, meth, and LSD
11-24-2016, 01:49 PM | #11 |
4ut0strd4
47
Rep 223
I actually have the same kit and have been considering setting it up standalone and getting rid of my procede entirely since it's just a pain to deal with. I believe the procede and meth are set up in conjunction, so I'll take another look at it. I'll see if I can get a picture or more information on how it's set up, maybe it will help somehow.
11-28-2016, 08:28 AM | #14 |
Rep 246
Aquamist
I found this. It notes the 335 but any other directions I've found don't really note using the green connection. I'm confused that Aquamist said they don't have any instructions for the 335 but then I find this that notes the 335 right on it. I have everything run and in place, including the green cable. I'm literally an hour away of being done if I had concrete install instructions.
11-30-2016, 10:08 PM | #17 | |
442
Rep 18,331
THe pink wire is then connected to procede flow wire and it will change maps when there is methanol flow. You have to configure it on the aquamist board to allow for a pink wire to output voltage. I believe you have to soder a specific connection on the circuit board. I have looked into this because Aquamist no longer sells a standalone flow sensor and in order to have their new flow sensor with Procede I would have to get the entire system in the future if my flow sensor takes a dump. As of now there is not one vendor who sells a flow sensor that is capable of handling a meth volume more than 50/50. Aquamist hardware is the best on the market Last edited by cn555ic; 11-30-2016 at 10:18 PM.. |
FSociety3812.50 |
12-02-2016, 04:42 AM | #18 | |
Rep 1,184
N55 has solenoid direct injectors, 12v as for port injection |
