Slight diesel smell in cabin
11-22-2016, 08:04 PM | #1 |
Rep 62
Hi folks,
There seems to be a slight diesel smell in the cabin. It isn't heavy like I can't breathe or anything but enough to annoy. What part usually fails to cause this? Or is it normal? Anyone think it would be covered by the 70k/7 year emissions warranty? 2011 335d |
11-23-2016, 08:46 AM | #5 |
Rudolf/German/Compression Ignition Specialist.
53
Rep 168
egr cooler, leaky injector, boost leak, crack in the exhaust, intake not on properly, list goes on and on..
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
11-23-2016, 09:47 AM | #6 |
Rep 2,615
Add the following to the list:
-differential pressure sensor and its two tubes off of DPF; -exhaust pressure sensor and its connection to the manifold, especially, the rubber portion of the connection. |
11-23-2016, 08:13 PM | #8 |
Rep 62
Hi Folks,
Took the engine cover off and found a slight leak on the left side of the engine. Any idea what it is? Also, any tips on getting the engine cover back in and lining up all the fasteners correctly? |
11-23-2016, 08:55 PM | #9 |
Rep 51
Major, what a small world, I just replaced that line Saturday. The oil runs over the turbo and gives off the smell.
The line was 65$ from BMW dealer. Good luck |
11-23-2016, 09:29 PM | #10 | |
Rep 62
Would you happen to have the part number? Was it hard to change? Any tips? |
11-23-2016, 10:36 PM | #11 |
Rep 51
Sorry buddy on the part #, but BMW located it fast.
As for install just remove the heat shield and two bolts, easy. I did spray the engine down with cleaner after, but I got cleaner smell coming in now. Have fun, Kent |
11-24-2016, 12:31 AM | #12 | |
Rep 2,615
Just make sure you differentiate between the burn oil smell and raw diesel smell. Last edited by Yozh; 11-24-2016 at 12:38 AM.. |
glitdi53.00 Chief Orman671.00 |
11-24-2016, 12:35 AM | #13 | |
Rep 2,615
you need four (4) new copper crush washers 07119905041 Husker has them for a good price: http://www.bmwdirectparts.com/oe-bmw/11427795971 If you are good with tools you can just do the change by unfastening the top bolt on the turbo heat shield and do it that way. |
11-25-2016, 07:29 AM | #14 |
Rep 4
I have a 35d (essentially same engine) which had a similar issue. In my case, one of the upper turbo bolts had fallen off, and another was extremely loose. You can read my experience here:
http://www.bimmerfest.com/forums/sho....php?p=9503808 Of course, the loose turbo bolts might not be your issue. On the other hand, I discuss how to get the turbo heat shield off to get to the turbo oil line. Hope that helps. |
11-25-2016, 09:14 PM | #16 |
Rep 266
11-25-2016, 10:33 PM | #18 |
Rep 2,615
They are great. Prices for OEM stuff are the best. Shipping sometimes may take a tad longer cos they may have to go source parts. However, for some things Bosch, etc. you can find a Bosch pn and get non-BMW labelled part for cheaper. I think ECS carries them.
12-03-2016, 04:31 PM | #19 |
Rep 62
Alrighty, just replaced the line. It was a little tricky so I ended up removing the air filter and housing. I didn't removed the furtherest bolt that holds the heat shield as I managed to pull it up just enough to get the bolt off (also just looking at that made me not want to go through the trouble). The whole area was covered by a light amount of oil so I hope this solves the problem.
Question for folks, is this specific oil line the one that usually fails or could it have been a couple of them? |
12-10-2016, 12:24 AM | #20 |
Know's a guy that know's a guy...
5637
Rep 1,905
So - with full ABC delete, EGR block - why would a slight smell still be present with heater on..?
12-10-2016, 10:58 AM | #21 |
Rep 432
Smell your tail pipes?
Some have said the down pipe connection can leak slightly as well, and you should put copper anti-seize on the metal gasket. I didn't and I get quite a noticeable smell right away with the recirc off. |
12-10-2016, 08:27 PM | #22 |
Rep 245
What do you mean, connection with SCR cat or engine-dpf?
