Issues after injector swap
11-26-2016, 06:09 PM | #1 |
Rep 106
So I just got done replacing my injectors. Now I'm having studdering at 2500-3000 RPMs and have codes for "Charge Air Cooler Temperature Sensor Circuit High" and "Turbocharger/Supercharger "A" Underboost Condition" Anyone have any solutions? Thanks
11-26-2016, 08:18 PM | #2 |
NY BRAVEST
47
Rep 231
Hmmmm, weird. I replaced all of mine, but didn't have that come up. Did you register the injectors and re-do the adaptations? Did you run ISTA D? Maybe 1 or 2 of the injector connectors isn't seated making contact not shooting fuel?
11-27-2016, 11:51 AM | #4 |
Rudolf/German/Compression Ignition Specialist.
53
Rep 168
So let me get this straight...you swapped an injector and your getting a boost code and a maf code?
You sure they are connected? I sure don't think they are... if you swapped the injector yesterday, I would check connections on everything you took off.... Its a good place to start.. keep it simple.. an injector code and boost codes are two completely different issues...and you are getting boost codes... You left something off or not connected right... Also did you code your injector? I am guessing not..
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
11-27-2016, 12:00 PM | #5 | |
798
Rep 1,633
Did you do something in addition to replacing injectors? |
11-28-2016, 11:50 AM | #6 |
Rep 106
So the codes cleared up, I think it was cuz somehow my boost line for my WM got disconnected.
The reasons I replaced my injectors was because I was getting injector codes and stubbling at around 1200 rpm and idle |
