M2 Technical Topics > Suspension | Brakes | Chassis > Replace brake discs everytime you change brake pads?
      12-01-2016, 01:16 PM   #1
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
This was an interview with one of the engineers about the steel brakes of the M2/M3/M4... I find it very strange what he says about changing the discs each time when your track pads are worn out. With my AP racing discs on my Z4M is do around 6x brake pad changes until the discs arrive at their minimum thickness and need a change
There is a minimum thickness that a discs needs to have...I can not imagine that after one set of track brake pads you need to change your OEM M2 discs because they are to thin?
      12-01-2016, 05:20 PM   #2
M+M
M+M's Avatar
New Zealand
227
Drives: M2 DCT MPerformance coilovers
I wouldn't think they need changing that frequently either. Certainly unlikely to be down to minimum thickness. So unless they are warped and have the shakes just change pads and carry on
      12-01-2016, 06:00 PM   #3
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Maybe he recommends this because he doesn't have to pay for them on his car?
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
Appreciate 3
      12-02-2016, 04:10 PM   #4
CommitConfirm
United Kingdom
475
Drives: The Bus
Maybe he's got shares in the company who makes them!
BAN_M2C4154.50
      12-09-2016, 02:41 PM   #5
Ulmi
Drives: 1M
FYI: I ran through a set of BMW Performance Brake pads and after one set of front pads the rotors were down to minimum thickness.
      12-09-2016, 04:22 PM   #6
Spinnetti
Drives: Various
Germans love to have you replace the pads and rotors together. That's fine when they are matched to wear together, but soon as you change that the logic goes out the window (and dubious even stock). As long as you meet minimum thickness and there are no fatal cracks or high spots you are good... People often think rotors "warp", but that is really uneven wear caused by inconsistent metalurgy in the casting where the softer bits wear more than the harder bits leaving a lumpy surface. I once had a brand new rotor hop like the wheel was falling off due to a hard spot that looked normal to the eye. Get some ST43 brake pads and never worry about track pads again.... I usually get 30hrs of racing out of a set of fronts and I race it like I stole it (this is not on a BMW though, so YMMV)
      12-09-2016, 05:08 PM   #7
David1
David1's Avatar
795
Drives: 09 E92 09 X5
If your at minimum thickness they are done for track use. Street use maybe.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      12-09-2016, 11:15 PM   #8
M+M
M+M's Avatar
New Zealand
227
30 hours racing is very impressive durability for pads. What rotors are you using now?
      12-10-2016, 06:08 AM   #9
Franzino
Franzino's Avatar
Belgium
860
Wow damn....then it's getting expensive... My rotors from my AP racing kit last around 5-6 sets of front Pagid pads. What is the price of a front set of BMW rotors?
      01-04-2017, 11:54 AM   #10
CosmosMpower
CosmosMpower's Avatar
2049
Drives: F87c, GT3, MK7 GTI
BMW has always replaced rotors with pads but I think it's completely unnecessary. No way a set of OEM street pads will chew through a set of rotors.
      01-04-2017, 12:26 PM   #11
Franzino
Franzino's Avatar
Belgium
860
Never did that with my BMW who still had OEM rotors and OEM pads... Are they crazy!
      01-04-2017, 01:43 PM   #12
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
I always replace my street rotors with pads. Last time I changed them I measured them and they were past minimum thickness.
http://f30.bimmerpost.com/forums/sho...4&postcount=24
      01-04-2017, 02:50 PM   #13
Spinnetti
Drives: Various
Especially considing this is on a Big Assed Lexus LS400 with stock brakes running up at the front of the field. So many forum "gurus" seem to like to spend a lot of money with little benefit. I use the cheapest ebay/Amazon rotors I can find and change them as frequently as they need it, which tends to be the same frequency as expensive rotors.. Then, just for fun (no real value or need) I CNC cut them to make them look fancy. Favorite is to wave cut the outer perimeter like on the RS Audis which reduces weight a bit and exposes more surface area at the hottest part of the rotor (which does add cooling value). I've never run pads a full 30hrs, but have lots of sets of pads at about 40% left - kind of false economy to have to pit in a 24hr enduro to save on pads so I swap them out... I end up using them for 15 - 24hrs (depending on race length), and the rotors last a long time (I've got ducts to the center of the rotors too).
New
https://www.amazon.com/photos/share/...Vyu2wRyAbKpUFC
...After 15hrs of hard use and some rain thrown in.
https://www.amazon.com/photos/share/...cyXsj3PnPahlfT
      01-04-2017, 04:14 PM   #14
M+M
M+M's Avatar
New Zealand
227
Especially considing this is on a Big Assed Lexus LS400 with stock brakes running up at the front of the field. I use the cheapest ebay rotors I can find, then just for fun (no real value or need) I CNC cut them to make them look fancy. Favorite is to wave cut the outer perimeter like on the RS Audis which reduces weight a bit and exposes more surface area at the hottest part of the rotor (which does add cooling value). I've never run them a full 30hrs, but have lots of sets of pads at about 40% left - kind of false economy to have to pit in a 24hr enduro to save on pads... So I use them for 15 - 24hrs (depending on race length), and the rotors last a long time (I've got ducts to the center of the rotors too).
New
I also run cooling ducts to the center of the rotors on my rally car. Still wouldn't get near that longevity. Must be too much left foot braking overlap while on throttle !!
m2
