My new car, P20EE - DEF injector cleaning pics
12-12-2016, 11:37 AM | #1 |
Rep 38
Drives: 2011 335d
A few months ago I bought a 2011 335D with 50K. I did a lot of research on the BMW diesel issues but decided to get one anyhow. I figure if I run into issues I'll just get a tune. This will be my 4th bmw (previously had a 94 325, 96 530 and 97 540 6spd). I wish they made the 335d with a stick. That would make it almost perfect.
The car has just over 53K now and my SES light came on. I took it down to the local parts store and they pulled the codes. P20EE was listed twice. Over the weekend I put the car on jack stands (spare 2X6's came in handy, this car is low) and tackled the DEF injector cleaning. When I got under the car I removed the small panel covering the area of the DEF injector. It was really nice not to have to take the whole underskirt off. 4 of the screws were Security Torx but I have a set and was able to remove them without having to break out the vise grips. In this pic I have already removed the DEF injector. Forgot to snap a pic of it before taking it out. I disconnected the DEF injector and removed it. The electrical connector has a tab on one side you squeeze and it pops off with a little wiggling. THe DEF line has 2 tabs, one on each side that you squeeze and it slides off easily. No DEF fluid leaked out. The injector had a lot of buildup on it but the exhaust was clear. I wired up a 9v battery and had my son spray it down with warm water to flush it out while I held the injector and the the wires onto the connector to keep it open. It cleaned up nicely. I put it all back together and have driven it for about 50 miles. The SES light has not gone out on its own. Assuming cleaning the injector solved the issue should the SES light go out on its own or do I have to reset it to clear the code? I have a Carly scanner coming tomorrow. Anyhow, I love the car. It's Vermillion Red with tan interior. It not the M package but it has the sport and nav. Hopefully it will last a while. Last edited by koden; 12-12-2016 at 12:02 PM.. |
12-12-2016, 11:54 AM | #2 |
Rep 1,157
None of your photos are showing up for some reason. If you used Imgur, make sure the links you put are direct to the image. Also, you'll have to clear the code for the light to go away and stay away, assuming that the cleaning fixed the issue. Look like it was a relatively easy fix for one of the weaker portions of this car.
12-12-2016, 12:02 PM | #3 |
Rep 38
Drives: 2011 335d
Ok fixed. Looks like if you want to post pics inline they also show as attachments at the end of the post. Sorry.
12-12-2016, 12:05 PM | #4 |
Kind of a Big Deal
167
Rep 857
Great writeup! Just guessing but you probably need to clear the codes. I have iCarly for Android, which I don't especially recommend except for occasional use as it's fiddly.
12-12-2016, 12:09 PM | #5 |
Rep 38
Drives: 2011 335d
Thanks for the heads up. Mine is for android also. If I find it buggy I'll return it and look at another solution. I liked it because it doesn't require wires.
12-12-2016, 12:57 PM | #6 |
Kind of a Big Deal
167
Rep 857
12-12-2016, 01:15 PM | #7 |
Rep 38
Drives: 2011 335d
I looked at the software to download from the play store. I did not realize you had to pay an extra $60 for the "pro" version of the software to actually do anything and then an extra fee to be able to reset the codes. The recent reviews of the software are not good either. I canceled the order. I'll have the parts shop reset the codes on the way home and look for a better wired solution.
12-12-2016, 01:32 PM | #8 | |
Rep 1,157
12-12-2016, 03:15 PM | #9 |
Rep 38
Drives: 2011 335d
Yea, I'm about half way through reading the 9 page thread on it.
12-14-2016, 02:06 PM | #10 |
Rep 697
12-14-2016, 02:22 PM | #11 |
Rep 38
Drives: 2011 335d
I stopped by the local napa and used their scanner to reset the codes. It's been about 300 miles and no more light so hopefully that was the only issue.
Thanks for the help. |
01-20-2017, 07:16 PM | #12 |
Rep 38
Drives: 2011 335d
P20EE showed up again today. Car has not been driven much in the last couple weeks due to snow. I'm going to reset it but if it comes back it looks like I have to start throwing parts at it. It's only got 54K so maybe the dealer will cover it under the federal emissions warranty. |
01-21-2017, 12:09 AM | #14 |
Rep 38
Drives: 2011 335d
Hmm. Tomorrow I will see if I can get into the hidden cluster menu and check the coolant temp. Thanks for the tip.
01-21-2017, 03:34 PM | #15 |
Rep 38
Drives: 2011 335d
After a 30 minute drive I pulled into the garage, shut car down and got into the menu. The temp was 85C with engine off and dropped to 80C after idling for a few minutes. I think the thermostat is ok.
Does the Exhaust fluid go bad? Maybe the car has sat undriven for a long time before I bought it from the dealer. |
01-21-2017, 04:16 PM | #16 | |
2125
Rep 3,368
01-21-2017, 04:20 PM | #17 | |
Rep 1,157
01-21-2017, 06:01 PM | #18 |
Rep 245
Welcome to the club) http://www.e90post.com/forums/showthread.php?t=1313436 Emissions issues are endless...
01-21-2017, 11:01 PM | #19 | |
Rep 2,615
Concerning the Urea. It has about a half year shelf life and that diminishes fast with higher temperatures. You should be ok in OR, but if you feel it may be old, I would flush the tank and refresh the fluid. Walmart has it cheap. |
01-23-2017, 10:32 AM | #20 |
Rep 38
Drives: 2011 335d
I monitored the temps driving in to work today. In 20 miles of driving mostly city and a short sting on the freeway the temp stayed between 78 and 82C.
I have always gotten 24-25mpg with the car in mixed city and freeway driving (I have put about 4000 miles on it since I have had it, it is at 54K now). |
01-26-2017, 01:28 AM | #21 | |
Rep 2,615
01-26-2017, 12:35 PM | #22 |
Rep 38
Drives: 2011 335d
I have not timed it but it seems to warm up pretty quick. I think the thermostat is getting a little tired and I plan to replace it but I don't think that it would be the issue with the P20EE. I am going to drain and refill the tanks with fresh fluid. and see if that does anything.
I have an OBD2 cable coming in the next day or 2 so I can try and read the bmw specific codes on the laptop. Maybe that will shed more light. |
