No boost (1 PSI)
12-16-2016, 10:29 AM | #1 |
Rep 111
No boost (1 PSI)
Hi all,
This last week my car lost all power, the only thing that changed was that I moved and am using different 91 now (Shell vPower). The amount of power lost seemed too much to be related to bad gas, so I got the MHD logger and started logging. I am currently seeing a target boost of roughly 16 psi, and an actual boost value of 1 psi. A few months ago I had the VRSF 5" FMIC installed, which worked fine for a while there. Before I bring my car away I'd like to narrow it down. So far I've seen two answers, either somewhere in the FMIC/chargepipe or a vacuum leak. I opened the hood and looked at the top connectors of the FMIC and the chargepipe to throttle body connection, all of that looked fine. Of course it could be disconnected on the FMIC side. I was wondering, can you determine from the logs if its a vacuum leak? The wgdc number changes but I don't really know what to look at since this is the first log I'm inspecting. What do you guys think? Btw, it does not throw a SES which kind of surprised me. http://datazap.me/u/aqid/no-boost-s1-v71
2007 335i e92: Full option • Avant Garde M310 • MHD Stg2+ • Mr. 5 intake • VRSF DP • VRSF FMIC • Dtec v7 Angel Eyes • iJDMTOY 6k HID
12-16-2016, 10:42 AM | #2 |
Rep 111
Also, it seems like my rail pressure is low compared to others. What do you guys think about that?
12-16-2016, 10:54 AM | #3 |
Rep 606
dude, get that boost leak test going. it's pretty simple and if you got any leaks you'll hear em. that's my suggestion for your first move. I hope that's the issue cuz thats a quick fix.
12-16-2016, 11:27 AM | #4 |
Macgyver
208
Rep 942
Go back and recheck those connections . You might start over spinning those turbos trying to build boost with a massive leak. Also check your vacuum hoses to the vacuum canisters then to the boost solenoid a down to the actuators.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
Aqid22.00 |
12-16-2016, 11:46 AM | #5 | ||
Rep 111
Since the move I don't have a place to work on my car anymore so I'm afraid I'm going to have to bring it to an indy shop. I'll just have them check the intercooling piping first, as that seems to make the most sense to me.
///Mposter208.00 |
12-16-2016, 11:50 AM | #6 |
Custom User Title
50
Rep 247
stock dv's?? those things are worth a check, stock cp? maybe cracked.. any extra noise even revving with the hood up you would hear a leak of this magnitude. connections at the ic? if nothing is over obvious looking or sounding, leak test would bête way to go. valve cover gasket possibly..how many miles on the car?
just brainstorming here |
12-16-2016, 12:00 PM | #7 |
Rep 111
Yeah stock dv and cp. From what I can see from the top both of those look fine. I assume that when you loose all boost its not some tiny hole, but more like something is completely disconnected/cracked. Didn't think about revving it with the hood up, I'll do that later. Can only see partial connections at the IC (the top part of the hot side connector really). I have a feeling the problem might lay there as that is the only change in the last 3-4 months (installation of the IC). 95k miles on it btw.
12-16-2016, 12:43 PM | #8 |
Custom User Title
50
Rep 247
95k, hmmm how long you been tuned for? check those dv's, they are VERY easy to remove and inspect. Like I was sayin, that's a massive leak, youll hear rushing air somewhere im sure of it at a standing rev.
12-16-2016, 07:00 PM | #11 |
Rep 111
Thanks guys! Going to take that tip and see if I can hear it with the hood open. I currently can't take the underside panel off as I don't have the space to do it anymore after the move. I used to go to a DIY garage with a lift, so I don't own a jack or jackstands. But I don't think they have that concept here in Colorado Springs. So I'm going to have to find something else in the meanwhile, maybe bring it away or buy the jackstands and jack. Btw, ran stock + stage 1 for about 10k miles. About 3k since intake/dp/fmic. Installed in that order with about 1k miles in between each.
02-03-2017, 12:51 AM | #13 |
Rep 111
So I brought the car in to have the FMIC inspected, they said everything looked fine. I read the 30FF thread here on e90post and found that a lot of people were having issues with the vacuum lines that run underneath the engine cover due to heat. A lot of those people also reported an increase in WG rattle, which was something I was having too. So I inspected those hoses, but both of them looked fine and it seemed like someone already changed them since they were cloth wrapped silicone tubes. I then took the hoses of the vacuum canisters to see if I could hear the vacuum, and when I got to the bottom side the right one just tell off. I found some glue at the end of the hose which was weird, so I took the canister off and found that the previous owner/mechanic had glued the vacuum hose to the canister because the nipple had broken off! Ordered a new canister, which I got in today. Clipped the piece with the glue off of the hose, attached it and everything was fine and dandy. Immediately back at full boost. Went from that straight to misfiring though. Was going to order spark plugs and go down the route of spark plugs -> coil packs -> injector. But now I'm thinking of it, maybe its from driving for two months without any boost on the turbos and somehow it adapted to some different values and now I have to reset adaptations?
02-06-2017, 11:07 AM | #15 |
Rep 111
Alright reset all adaptations and changed the spark plugs, still misfiring on #4. Ordered a new coil, will install that on Tuesday. I noticed it doesn't misfire in 1st and 2nd gear, only in 3rd gear above I'd say 50% throttle position.
02-06-2017, 11:20 AM | #16 |
3441
Rep 79,211
More load and heat in upper gears.
02-08-2017, 12:42 PM | #17 |
Rep 111
Yep, after replacing sparks + coils the misfire is gone. Car pulls strong again! I think my problems are solved. Yaay. It's been two months since I've had full power, forgot how fast this car is!
3rd gear pull: http://datazap.me/u/aqid/mhd-stage-2...-9-10-11-14-22
02-08-2017, 05:20 PM | #18 | |
Rep 2,013
335i e92 TPC 19Ts
02-09-2017, 04:12 PM | #19 |
Rep 111
Do you think that because its spooling too slow? (2k rpm to at 3.1k rpm before full boost)
