Help: U0106 Lost Communication with Glow Plug Control Module
12-17-2016, 04:13 AM | #1 |
21
Rep 38
2010 BMW 335d with 77k miles. SES light came up, shown glow plug control unit cylinder 5 malfunction. Purchase a replacement and took it to a shop to install it. The SES light pop up right away with new code U0106 and P064C code. The mechanic double check connection and had no idea why. I search the code and indicated it is very likely a power issue or unlikely a defective unit although i cannot rule out. Does any one know how to fix this or does anyone know if there is a fuse controlling the power supply to the glow plug control unit? The car has been running rich with poor mpg and lot of carbon deposit at back bumper.
thanks |
12-17-2016, 08:34 AM | #2 |
Rep 1,288
What's your running coolant temps? Thermostat failure seems to be common which leads to glow plugs operating too often and eventually burns them out. Coolant temps should be over 85c.
12-18-2016, 11:03 AM | #3 |
Rep 504
I Had to replace the glow plug controller to fix this when i had that code. Just for the heck of it, i replaced all glow plugs as well at the same time. As Mark mentioned, also keep an eye on the thermostat - it might be failing as well.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
12-19-2016, 01:18 PM | #6 |
Rep 432
If the code came after he changed it, it wasn't plugged in correctly or you got a bad part. Why even buy the part used though? Its $105 with lifetime replacement warranty from FCPEuro
12-19-2016, 02:01 PM | #7 | |
Rep 1,288
I did mine without pulling the intake manifold, but I have the scars on my hands to prove it. It is very TIGHT quarters working down there. Please double check your operating coolant temps. The root of this is likely a bad thermostat. That's my wager. |
12-19-2016, 09:12 PM | #9 |
21
Rep 38
12-20-2016, 08:49 AM | #10 |
Rudolf/German/Compression Ignition Specialist.
53
Rep 168
Have your mechanic actually do some diagnosis work...
1) take a digital multimeter and check for resistance in the glow plugs, compare resistances... Pretty much every glow plug I have ever checked is about 1ohm. 2)If that doesn't work get a hold of a wiring diagram and start checking the wiring...shouldn't be much to check. I believe the wire from the glow plug to the module is about it...If power before glow plug module was shorting you would most likely have all plugs out. You have eliminated the glow plug control module, you probably have a perfectly operational spare now...
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
12-20-2016, 12:08 PM | #11 | |
21
Rep 38
thanks |
12-20-2016, 09:20 PM | #12 | |
53
Rep 168
Proper diagnosis is cheap! You know whats not cheap? BMW Parts....
01-07-2017, 03:17 PM | #14 |
21
Rep 38
I got it fixed now. I thought i read here someone said we should use GSE102 module, that is an incorrect part for 335d.
http://www.e90post.com/forums/showthread.php?t=1131874 My mechanic ordered GSE108 module and replaced all glow plugs, it solve the issue. |
